I have a GE washer that does everything except spin most of the time. Occasionally it will spin but it's very slow to start and takes a long time to get up to speed. While testing, if you open and c
I've looked at and swapped a number of parts. This started after the wife washed a outdoor rug without beating it and everything got plugged up with sand, started a few months later. To try and get it going, swapped out a used motor and timer, a capacitor, lid switch and belt. Disassembled the pump and cleaned it out. I'm out of ideas, any help is appreciated.
  • Paul Haus
    Paul Haus Nov 17, 2014
    Right now I'm wondering if there's something still between the inner and outer drums. Have not figured out yet how to remove the agitator. Most everythings else of consequence has been changed. Also found the reference to opening and closing the lid, so far no change.
    Master:
  • 560 Answers
Check YouTube for video solutions.
Posted on Nov 16, 2014
SOURCE: GE washing machine, wont spin
Same problem (but without any smell). You should try to reset the two computer boards in the washer. You do this by 1) unplugging machine and wait for 30 secs; 2) plug in machine; and 3) open and fully close the lid at least 5 times. This resets computer boards, which can get messed up by power surges, etc.
Posted on Sep 04, 2008
Maytag317
  • 1136 Answers
SOURCE: Whirlpool LSR8233eq top load washer won't spin most of time
Hi, It sounds like your spin basket drive is going bad. Even tho you cleaned the brake, the pads get worn down enough they will not grab. The only other thing I can think of is the bloch that sits on top the basket drive shaft and lockes the inner tub. Sounds like you have done/checked everything else.
Please let me know if I can assist you further.
Vic
Posted on Jun 20, 2009
  • 4044 Answers
SOURCE: whirlpool commercial washer stopped running mid
If the timer and lid switches are funtional and the machine is filling and shutting off correctly that only leaves the motor. Have the motor tested or replace it. Even though the timer is running it is possible that it is still at fault. If you have access to another timer try switching them to make sure it isn't the timer. This does sound like a faulty motor and I would start with that assumption.
Posted on Oct 30, 2009
  • 289 Answers
SOURCE: GE top loading washing machine (WBSE2090A0WW) stops spinning
it sounds like you know how to remove the frount panal,remove the frount panal.put unit in spin,look to see if belt is turning,if it is not than you have a bad cluch.
Posted on Dec 29, 2009
  • 1937 Answers
SOURCE: Kenmore washer 11020712990 series 70 top loader, does not spin.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump
removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If it will drain but won't spin the problem is likely in the transmission. "Neutral Drain Assembly".
See the Whirlpool / Kenmore Service manual for top load direct drive washers.
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
When ours had the same problem (wouldn't start spinning unless the lid was raised and lowered again) we looked at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) and noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again. (Third time was the charm.)
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
You don't have to remove the drum.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside.
Remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft), remove the 8 screws carefully the transmission holds 15Oz of 80-90 weight gear oil (non detergent gear oil from a local auto parts dealer), remove the clip holding the main spin gear on and check the plastic
cams.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
Posted on May 02, 2010
Ge washer whre5550k2ww tub wont spin
It may be the rotor position sensor. i used you tube tutorials. There are many washers that are the same, but different brand names. Matag, whirlpool, kenmore elite oasis, all the same and parts. I got lucky and a cleaning hack. It was to clean between the tob and thre shell. This is located up under where you cannot see, use a mirror and look wherr your detergent, fabric softer and bleach dispensers are. And i found a tutorial on diagnosting code that will do it for you. I think it was holding a cycle 5x for 5 seconds and it will tell you. Whats wrong, Good Luck
Jun 27, 2016 | GE Washing Machines
WSM2480 Clothes Still Wet After Slow Spin Cycle
It's possible that the tub didn't drain properly in the allotted time and the remaining water is slowing your drum from coming to maximum extraction speed.
Jan 10, 2014 | GE WSM2420D Unitized Spacemaker Washer /...
Washer will do everything but spin out and agitate belt good can rotate with hand but on the belt will not spin on pulleys air coupler is good and threads are excellant any advice
Since spin and agitate are the two times the transmission is used, that is what I would look at that. The agitate is the slow cycle of the transmission and the spin is the high cycle. Can you physically view the belt, i.e. that you have things opened up?
Jun 08, 2011 | GE WDSR2080D Top Load Washer
Hello my ge washer spins real slow and will agitates real slow? it does drain the water but when it goes into spin and rinse spins real slow
The problem may be either the clutch or worn belt. I am including a link to a repair manual to better help you in repairing and diagnosing the problem.
www.appliance-repair-it.com/GE-washer-not-running.html
Aug 05, 2010 | GE WBSR3140DW Top Load Washer
My ge washer wont spin by itself. i have to take
it sounds to me like your motor is defective, maybe, just the start switch, but best to replace motor...Bruce
Oct 10, 2009 | GE WDSR2080D Top Load Washer
Won't aggitate but will spin
the lid switch could cause this problem as well as the timer.i do not think you need to replaced the agitater at this time
Sep 16, 2009 | GE WDSR2080D Top Load Washer
Kenmore Washer Tub banging on fast spin
there are some springs that help hold the tub even as it spins also make sure that the washer is level check front to back side to side and corner to corner if it is unlevel they will be out of balance in high speed spin
May 07, 2009 | Kenmore 23822 Top Load Washer
Everything is working except the spin cycle
Sounds like the spin coil/brake solenoid is burnt out or broken. This is a coil situated on the motor plate under the machine with a lever attatched to it. When the machine goes into spin cycle, this solenoid pulls the brake away from the outer drum to allow the drum and agitator to spin together. The shaft that goes into this coil should move in and out freely. If tight, replace spin coil/brake solenoid.
Oct 31, 2007 | GE WSKS2060WWH Top Load Washer
GE Washer Spin Cycle Problem
gnarly, do you have the updated motor, harness and start cap? If it goes into spin and does this chunk a chunka chunka bit. Take a meter to the white and white/red wire going to the motor. If you have a steady 120V, replace the motor with the new kit. What the motor is doing is jogging between high to low speed. Catriver..post back.
Oct 17, 2006 | GE Profile WPSR3120WWW
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
