Question about Dryers
How do I access dryer blower on my bosch Nexxt 500 Series dryer. Ia it the front or rear.
hunter19_46m
  • 7482 Answers
SOURCE: The dryer (Bosch Nexxt 500) makes a loud grinding
The noise could be your drum rollers need lubricant or replacement.
When the drum rollers get flat spots on them they will make a bumping/thumping type of noise.
The grinding noise sounds to me like the drum rollers are in need of lubrication.
Posted on Sep 26, 2009
SOURCE: Bosch nexxt 500 series dryer
I had the same trouble after moving to a new house, I first thought I had a voltage problem. It turns out that the heating coil has a high temp re-setable switch in side the back - lower right side. the sencor has 2 screws, I took it out and cleaned off the lint and now have dryed 5 loads with 0 issues. looks like a flaw in design that would allow lint to get in the heating coils!!!!! I think I'm going to look for a new dryer before I burn down the house!!
Posted on Dec 28, 2009
heatman101
  • 43501 Answers
SOURCE: Bosch nexxt 500 plus dryer does not heat up. I
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Apr 28, 2010
Ranglo
  • 1194 Answers
SOURCE: Bosch Nexxt 500 series dryer, E:01 and lint light
This indicates the sensor near the lint filter gets too hot. This is usually caused by bad air flow.
Try running the unit without the vent hose attached. If the problem goes away the problem is in the ducting.
You may need to have it cleaned out. May be lint filter is clogged due to the use of dryer sheets or fabric softener. You can try to clean the filter with Windex.
If neither one of this suggestions resolves the issue there may be a problem with the sensor, there may be heat escaping somewhere within the dryer. This is only resolved by technician.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Posted on Jun 27, 2010
Macmarkus
  • 2605 Answers
SOURCE: I have a Bosch Nexxt 500 series dryer. Today I was
Hello, Welcome to FixYa. There are a couple of scenarios which may prevent the dryer from starting with Bosch, but based on your post it is most likely the emergency shut off/belt switch. It is located by the motor and in the event of too heavy a load or a broken belt it shuts the unit down & prevents any restart...until it is repaired or reset. To save time and back and forth dialog, I`ll mention what to do about it. **Unplug the dryer before attempting any repair tips suggested here please...safety first** This will require you to remove the back panel. Once you've remove the rear panel, It is located next to the belt pulley and all you need to do is push it to the right ( from the back ) Let me know if you require further assistance to do this. Keep me posted how you make out or if anything is not clear. I'm presently on my iphone, but I can post more info with pictures to guide you if necessary...but please let me know. Thanks for choosing FixYa and good luck. Regards, Macmarkus :)
Posted on Dec 21, 2010
Bosch nexxt 500 series dryer how to reset
Turn off the main breaker for a few minutes then turn it back on.
May 23, 2014 | Bosch Nexxt WTMC 3300 Electric Dryer
Need to replace the foam strip that seals the front door on my Bosch 500 Nexxt series electric dryer....do I do this from the front?
Most likely yes. Get a good adhesive for it though and make sure it is dry before you close the door and before you use it.
Aug 12, 2013 | Bosch Nexxt 500 Dryer
Bosch nexxt 500 elec dryer has no heat to it
There is a switch located on the duct from the heating element. Which you are not able to reset, you have to replace it if it's defective. Do a continuity test on it and if there is no continuity then the switch has to be replaced.
Jan 04, 2012 | Bosch Nexxt 500 Dryer
Bosch nexxt 500 series dryer runs but stopped heating blows cold air and tumbles but just have no heat.
The heater element has failed,if electric dryer,. The element should be accessed at the rear panel.
If Gas heater...same but gas burner has failed to ignite.
Hope thes helps you
This help is free...Please find time to rate me.
Jun 28, 2011 | Dryers
Dryer won't start
If you look on the motor that turns the drum (at bottom), you will see two wires coming into what looks like s tan box with two spring loaded thumb tacks on either side. the thumb tacks are pushed if the tension arm on the drum belt kicks out. You can reset it by pushing the opposite thumb tack. WATCH OUT BECUASE IT WILL START AS SOON AS YOU RESET IT IF IT IS TURNED ON, use two people if possible.
Apr 13, 2010 | Bosch Nexxt 500 Dryer
Is it possible to reverse the doors on a Bosch Nexxt 500 series dryer? If yes, does it require a kit from Bosch?
yes ,it is possible,you don't require a kit from bosch,however,you will need to disassemble the machine.if you are not confident,get someone who is.
Oct 16, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
The water won't drain from my Bosch Nexxt 500 Series Washer machine
I solved the problem by using a sump pump to drain most of the water, then I removed the cover plate on the lower front right of the machine to get access to the drain plug. Upon removing that, some water flowed out but not too much, I found a sock jammed in there which wasn't allowing the drain or spin cycle to work properly.
Interestingly, the machine's manual says that the cover plate is only to be removed by a Bosch authorized service repair representative. Saved about $150 by simply doing this myself.
Sep 16, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
How do you clean the drain in a bosch next 800 series washer?
Almost all Bosch machines have a manual drain trap that usually can be accessed from a small door in the front panel. Open the door and you will see the trap access.
Jun 05, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Dryers Logo
51 people viewed this question
Top Dryers Experts
