Question about Cycling
Is there a reset code for sunlite bike lock - Cycling
Sunlite bike cable lock. I opened the lock and now cant put the male end back into the lock because I forgot the combination
Well, the lock is not any good if you don't know the combination, but for a barrel-type combo lock, if you accidentally turned the numbers while open just push the male end in and turn the 1st ring until it goes in slightly. Then turn the next ring and so forth until it's all the way in. Now you can see the combination.
Apr 14, 2017 | Sunlite Cycling
How do I reset a sunlite bike lock?
Is it a key lock? combination with a dial or combination with levers?
Nov 16, 2014 | Cycling
How do I install a sunlite canvas & alloy qr basket onto my bicycle?
Baskets are usually very easy to install. Perhaps you should take it back to the bike shop and let them install it
Sep 03, 2014 | Sunlite Canvas & Alloy QR basket, red
How do I open the lock if I Forgot combo.
You could spend hours trying every combination, or cut the lock off and buy a new one.
Aug 20, 2014 | Sunlite Cycling
Trying to install Sunlite HD tourer rear carrier #45772. on a Rand 18 speed. There are no holes for front brackets in frame. Do you just drill the holes?
Never drill holes in a bike frame unless you have a death wish. "Rand 18-speed" doesn't tell us much. Most cheapo bike frames have a 'brake bridge' with a hole on the center for mounting accessories like fenders. Many racks can mount with a single rather than double front supports.. Lacking that, call a bike shop or web search for "bicycle seatstay rack clamps" to adapt the rack to attach to the seat stays.
Sunlite also makes a seatpost rack mount http://www.bikebagshop.com/sunlite-rack-mount-seat-post-clamp-p-1146.html?gdftrk=gdfV22203_a_7c1316_a_7c5544_a_7c11461678151 which looks like a more elegant way to solve the problem.
Sep 13, 2011 | Cycling
Just purchased my sunlite lock but the directions where thrown out by the retailer.....how do i set my lock combonation? I have it on all zero's now and it is unlocked...thanks
We just got a sunlite lock and figured it out. After it is unlocked with 0000 and the lock opened, the end spins to a "set" position. Set the numbers you want, spin the end back, and lock will be set to those numbers.
Jun 30, 2011 | Sunlite Coil Cable Resettable Combination...
What to do with the extra parts?
What extra parts? Sometimes there are different brackets, screws etc to fit other types of bikes. Is that what you are asking?
Sep 26, 2010 | Sunlite Bike Rack Rear Alloy Welded...
Sunlite deluxe child carrier...lost instructions
I just received the manual via PDF. Doesn't look like I can attach a file to this, so contact me with your email address. It is for the regular carrier, but they go together the same.
Mar 16, 2010 | Sunlite Bike Rack Rear Alloy Welded...
Same problem - new Sunlite bike speedometer but no instructions.
I don't believe J&B importors the producers of your Sunlite bike have instruction manuals online but you can contact them throught the following link.
http://www.jbimporters.com/web/contact_us.php
Hope this helps!
Jul 18, 2009 | Cycling
Cycling Logo
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
