Question about Epson Stylus Sx438w
How to install Epson Stylus SX438W scanner
Am receiving error message 'cannot communicate with scanner' after upgrading to Windows 7 x64bit from x32bit
    Master:
  • 560 Answers
Check to see if you need a bidirection cord connecting the 2 units.
Posted on Nov 16, 2014
Error message 'cannot communicate with scanner'
Check to see if you have the correct cable installed between the 2 units
Nov 16, 2014 | Epson Stylus Sx438w
Does not print
Epson sylus notorious getting getting corrupted software
1st Uninstall all Epson stylus printer software prividing you have instalation disk
Disconnect Printer
Restart computer and check to make sure under control panel / printers that there is no primary printer in there if there is delete it
2nd give printer power cable /communication cable good clean and check the printer port on computer isnt damaged.
3rd turn computer off reconnect printer have software ready but only if it is required most window systems have enough data with them that it will recognise new printer and install auto but if it asks for disk you will have it ready.
4th turn computer back on see if it notices new printer if not not to worry put disk in and install software,which will normally take you through a connect cables and power and install guide after that it should do a test print, if this comes out everything should ok again, but just check in control panel/ printer, and make sure its marked as default printer
hope this helps
Aug 12, 2014 | Epson Stylus Sx438w
Epson sx438w e-02
did you check paper feed driver unit sensor in paper fixing fil or board
Feb 19, 2013 | Epson Stylus Sx438w
I have windows vista. epson stylus cx4200 will print but does not scan. installed windows 7 64 bit drivers but not successful. need help. thanks
Download & install the "Epson Stylus CX4200 All-in-One Printer" @ Drivers and Utilities Combo Package
Windows 7 64-bit compatible, Windows Vista 64-bit
epson13071.exe - 20.9MB
- posted on 07/07/09
This file contains everything you need to use your Epson Stylus CX4200 with Windows Vista 64-bit.
This package consists of the following items:
•Printer Driver v6.5
•Scanner Driver v3.04
•Epson Status Monitor 3
•Epson EasyPrint v3.10
Uninstall your previously installed AIO drivers before installing the downloaded installer.
Hope it helps.
Jun 02, 2011 | Epson Stylus CX4200 All-In-One InkJet...
I am unable to scan with epson stylus SX105. It says, "cannot communicate with the scanner. Make sure the scanner is on, correctky setup and connected with no errors in the scanner. If using an...
Did you ever get a resolution to your problem? I have exactly the same problem with same error message - and very loud clicking noises coming from the scanner. Powering it down - allowing it to "cool" for 5 minutes will get probably 1 or 2 documents through the scanner before the error message reappears. But this is only a workaround rather than a solution.
Jan 22, 2011 | Epson Stylus Multifunction Inkjet Printer/...
I have upgraded my system Os from XP SP3 to Windows 7, after that when I installed Epson Stylus CX2800, everything was working fine except Scan program
Get a windows 7 driver for the printer or an update from epson, un-install the old one then reinstall the upgraded software.It did the same with my Lexmark,but I did get the newer driver from Lexmark and it worked out fine.
Dec 05, 2010 | Epson Stylus Multifunction Inkjet Printer/...
I have an epson stylus photo rx500, but have lost the installation disc and have no smart panel function so cannot scan or copy and espon are useless and say it was a bundle and newsoft supplied the...
You do not actually need Smart panel to use the scanner. Epson scan will allow you to scan and save to the PC etc. To install the printer and scanner download and install Epson Scan and Driver from the following page. http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=SF8cgjsfr7MDXMcEkJfQFa89pC7QCDCv&tc=6#7
Jan 17, 2010 | Epson Stylus Photo RX500 Printer
My Epson CX3900 prints fine. It's when I try to open Epson scan that I get an error message "Cannot properly communicate with scanner"
if the unit is directly connected via USB, another program or prev installed scanner software is using "the path" to communicate with the scanner. Can only use one scanner at a time with windows.
Nov 25, 2009 | Epson STYLUS CX3900 All-In-One InkJet...
Epson C88 communication error 600
yes you have to go to control panel and remove the drivers and install the drivrs again ok
Dec 09, 2008 | Epson Stylus C88 InkJet Photo Printer
Epson Stylus Sx438w Logo
99 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
