Question about Vehicle Parts & Accessories
How to remove a stripped spark lug from a 1999 dodge ram 15004wd
Plug is stripped cant get it out it just turns
    Problem Solver:
  • 10 Answers
If you have a slightly smaller socket, not a hex socket but a pointed socket, you can drive it on with an extension and remove the plug. I that does not work, your local parts house may have a loaner extractor set that has a socket designed to drive on and bite into the plug to remove. It may require breaking the stem off the plug to get an extractor socket to fit, but not a problem If you happen to break the plug off at the threads, you may have to drill out the hole and re-tap the threads (this is a higher skill process) being careful not to ruin the hole. However, this was more common on fords where the threads were too long on the plug and became corroded preventing removal. Hope this helped. Good luck
Posted on Nov 16, 2014
The pickup has no spark was going down the road and it just stopped running
Search Results
    "No start" Due to Pickup Coil Failure Inside Distributor ...
    repairpal.com > Problems > Toyota > Camry
    The pickup coil inside the distributor can fail and cause a no-start condition. ... checking reveals not only no spark at the plug, but also no spark going into distributor. ... the car runs great but only for about 10 miles. then it shuts down as if there is no ... The plugs have a weak spark when checked against the engine block.
    Car dies randomly, It turns over but no spark - 1989-1994 ...
    https://www.ifixit.com/.../Car+dies+randomly,+It+turns+over+but+n...
    iFixitf your engine cranks normally but will not start because it has no spark, or it stalls ... A bad pickup inside the distributor (on engines that have a distributor), a stripped ... Really old post but could you please tell me how I would go about checking if my ... When it all got down to it, one of the timing belt idlers had worn out and ...
    Dodge Ram 1500 Questions - 1994 dodge 5.9 just shut off ...
    www.cargurus.com > Questions > Dodge > Ram 1500
    CarGurusApr 12, 2012 - 1994 dodge 5.9 just shut off and wont start back up there is no spark or ... hall effect (magnetic pickup) in the distributor? ... So I ran power back to the wire and repaired the broken wire and she fired right up and is running darn good again. ... Ihave a 2000 dodge ram 1500 it died going down the road it is ...
    No Spark - 4.3L S10 Pickup - CarGurus
Dec 14, 2015 | Cars & Trucks
How to remove sprocket and clutch from ms250 stihl chainsaw
Removal>
  1. Remove the clutch drum/chain sprocket
  2. Remove the air filter
  3. Take out the shutter.
  4. Pull boot off the spark plug.
  5. Unscrew the spark plug.
  6. Close the decompression valve, if fitted.
  7. Push the locking strip 0000 893 5903 into the cylinder. (Piston Stop)
  8. Unscrew the clutch from the crankshaft clockwise (left-hand thread).
Installation>
  1. Screw on the clutch and tighten down to 50 Nm (37 lb.ft).
  2. Install the clutch drum / chain sprocket .
  3. Remove locking strip from the cylinder.
  4. Insert spark plug and tighten down to 25 Nm (18.5 lb.ft).
  5. Fit boot on the spark plug.
  6. Fit the shutter so that its lugs engage the recesses in the handle housing.
  7. Install the air filter
Feb 22, 2015 | Garden
How to remove a stripped out spark plug from a 1999 dodge ram 1500 5.2 liter
Pain in the rear end. but it can be done. Remove the head. and pound it out. Use a helicoil the re thread the hole. If you have to do this, redo the heads, if it has above 170,000 miles , replace the engine. Not worth the head job. But if it were mine. I'd replace it if it had anything above 130,000 miles.
Nov 16, 2014 | 1998 Dodge Ram 1500 4WD
What is the spark plug gap for a 99 dodge ram 4 by 4
  • Engine:3.9L V6
  • Spark Plug:RC12YC
  • Gap .035" (0.9 MM)
Feb 10, 2011 | 1999 Dodge Ram
Front drivers side tire is flat, and I can't remome it??
THERE IS JUST BUILD UP IN THE LUG HOLES. TURN WHEEL ALLTHE WAY RIGHT HIT THE INSIDE OF RIM WITH HAMMER AS YOU TURN THE TIRE & WHEEL TO DIFFERENT POSTIONS.
Jan 27, 2011 | 2001 Dodge Neon
Sputtered & died
this happened to me on my 1999 dodge ram and it ended up being the fuel pump
Apr 08, 2010 | 1996 Dodge Ram
1999 Dodge Ram 1500 cargo van will not start
If it cranks good but won't start, have a helper crank it while visually check for spark at the spark plugs. If spark everywhere, use a gage and check proper fuel pressure. Also, check fuel injector pulse.
If your missing several system, an example, at the ignition coil and fuel injectors, engine cranking, check the dark green wire with orange tracer for voltage? If no voltage that leads back to asd relay. I'm not saying the relay is faulty. Your computer has to see both the cam and crank sensor signals or it may not ground the asd relay. The asd relay supplies voltage to several systems.
Mar 12, 2017 | 1999 Dodge Ram
Misfire on #6 and #8 cylinder 1996 Dodge Ram 1500
strip heads off again and remove the valves and check the seats ,regrind the valves and fit new springs and seals ,also check the cam lobes for deformation (wear)
Jun 22, 2009 | 1999 Dodge Ram
Vehicle Parts & Accessories Logo
35 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
