I have a Goodman phkj036-1f and the unit sounds like its kicking in and then right back out and not putting out any heat. A/C works like it should but heat doesnt
    Master:
  • 602 Answers
Sounds like the blower motor is wired to the load side of the A/C contactor relay/. In this condition the blower will only run when the compressor is running which is ok for a heat pump but if you are running electric heat only the blower motor needs one wire to the line side and one to the fan relay. That way the blower will run with heat or a/c. When the blower wont run the heat strips thermal protection will cycle them on and off
Posted on Nov 17, 2014
the dr
  • 447 Answers
SOURCE: central heat unit not blowing
Is your unit a Split system where one unit is inside (attic, garage, utility room) and another outside?? Is the outside unit unit running?? Is your thermostat electronic or the regular slide mechanical type??
Posted on Jan 18, 2008
burzerko
  • 254 Answers
SOURCE: goodman heat pump wiring
ok Let me see if this helps if not please comment back with the t-stat model and make as well. The Y terminal on the t-stat needs to be connected to the Y terminal on the heat pump board. If this does'nt fix it your thermostat may have something different going on so please send me the model and make of the t-stat. Also if you know does this unit have outside temperature sensing probes, and or an automatic defrost cycle?
Posted on Jul 06, 2008
SOURCE: my goodman cental heat & air unit quit working last night
check to i see if there power to condenser. check to see if there 24 volts to condenser.checkt the disconnect box for power located out side by the condeser you should have 220volts at that box. check to see if your stat is set on cool.
Posted on Jun 20, 2009
  • 69 Answers
SOURCE: Goodman AC fan working but not cool air.
0204 built the second week of 2004 sound like you have a loose or burnt wire in the a-c and arcing when the unit comes on. turn the breaker off next time you fix an outlet
Posted on Aug 03, 2009
hvac1960
  • 2133 Answers
SOURCE: My Goodman gsh103301ab. The fan in the outside
If it's in cool mode, the outside fan definitely should run to remove the heat. If it's heat mode the outside fan will start only when pressure build up. If it's problem with condenser fan definitely the breaker or fuse will be blown when the amphs increased.
Posted on Dec 09, 2010
Goodman package unit will not. Come on in heat
sounds like a defective thermostat. try a replacement.
Jan 23, 2013 | Goodman Manufacturing GPG1342090M41...
I have an issue with my goodman splitt system. It is a 2 ton unit. 2 days ago the heat would come on and when the temp came up to my setting the heat kicked off, but the blower kept running. it does not...
what is the fan setting at? If its set to on then it will rum all the time if its set to auto then it should only run in heating or cooling mode? It is located on your tstat
Dec 30, 2010 | Goodman Heating & Cooling
We have a goodman split unit, It was below freezing the other morning and the unit had a squeaking sound when it started up. Now it has warmed back up, the unit is sounding as if it's trying to kick off...
The symptoms seem to be related to the main blower motor and/or it's capacitor. Turn the system off for a couple of minutes and then turn just the fan on while the thermostats heat setting is in the off position. If the lights still dim then replace the motor and capacitor. The clicking noise is the fan relay.
Dec 17, 2010 | Goodman GMS807034ANA Heater
My goodman gas furnace is not kicking on. the light on the unit is saying that it should be working but it is not. there is no pilot light, the fan is working the heat is not
If you are not getting any codes from the board, then the furnace is not getting a call for heat from the thermostat. A wire may have come off, the thermostat not properly wired, or a break in the stat wire. On a call for heat, you should have 24vac between W and C on the circuit board. This will let you know if you are getting a call for heat all the way back to the furnace.
Oct 01, 2009 | Goodman GMS90703BXA Heater
Fan not running on Heat Pum
That does not sound normal at all, I have a Goodman Heatpump and the Fan on the Evaporator (outside unit) should run as soon as it starts up!
The only delay you should be seeing is when the unit starts, the fan in the AHU starts 5 seconds after and runs for about 1.5 minutes after shutdown.
Sep 19, 2009 | Goodman CLQ36AR49 Air Conditioner
Goodman gmp050-03 heater
Either yourself or a Heating specialist will have to replace the gas valve.. Once installed you will plug unit back in which will reset power board and should work fine
Dec 23, 2008 | Goodman GDS80904BNA Open Flame Heater
Back up system inadequate?
Your home inspector is bonded and required to stand behind his work. That being said, it appears that your heating unit is inadequate. Therefore, you should tell your realtor that you want a new heating system installed as part of the sale.
Call your inspector and ask him how you should proceed. You hired him to work for you and give you sound technical advise. If he is not doing these things for you, call an attorney.
Jul 17, 2008 | Goodman CKL49AR49 Air Conditioner
Goodman heat pump wiring
Jul 06, 2008 | Goodman CLQ36AR49 Air Conditioner
Goodman ac / heat pump
I just had a new unit installed and I am surfing for troubleshooting tips too. My unit is doing the same... cools well heat sucks. my problem has been isolated down to the reversing valve... It is constantly energised which means it is constantly in a/c mode even when kicking on the heat strips... We disconnected a line at the thermostat and it is working well as a heater now. You may want to check yours to see if it is actually kicking over into to heat mode... -rob
Nov 25, 2007 | Goodman CLQ36AR49 Air Conditioner
Heating & Cooling Logo
70 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
