Hi.my laptop has developed 2 thin lunes across the screen and my keypad wont work.please can u help
  • 28 Answers
It is a pixle issue with your screen and can only be fixed by replacing the screen.
Posted on Nov 16, 2014
  • marie green Nov 16, 2014
    Will it be expensive 2 replace?nothin on my keyboard works either
pcblogger
  • 44 Answers
SOURCE: lcd display
Try connecting your laptop to an external monitor.Connect it with a vga cable to your monitor and press Fn+ monitor key(I don't know what it is for acer) to switch displays.If there are no lines on the external monitor then the problem is due to the notebook lcd.If there are lines then it is due to a driver.Reinstalling the driver should fix that then.
Posted on Aug 24, 2008
ssebata paul
  • 159 Answers
SOURCE: line across screen
scane for virus and reinstall the operating system
Posted on May 30, 2009
  • 111 Answers
SOURCE: white thin line running across horizontal on my hp laptop
You got a bad LCD screen. no immediate resolution aside from getting the LCD replaced. if your system still has warranty call Dell for replacement.
Hope it helps!
Posted on Feb 18, 2010
SOURCE: thin black vertical lines across width of laptop
some pixels are dead or you might have problems with the video card take it to the service to have a look
Posted on Aug 17, 2010
Testimonial: "K -- thanks for the info"
  • 11 Answers
SOURCE: HP Pavilion dv6000z 15.4" Notebook Laptop PC (AMD Turion 64 X2 Duo Core TL-50 1.60GHz, 1GB RAM, 100G... (d6000z) PC Notebook: a thin verticl line across the screen...
it might be due to static on the notebook
turn off the notebook and then remove the battery from the notebook press and hold the power button on the notebook for 4-5 sec and then put the battery back and then turn on and check
if the line is still there check it in the safe mode or in BIOS if its still there then replace the screen
Posted on Nov 23, 2010
White line across screen
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Take it to a repair shop.
Apr 05, 2014 | Sony 46 KDL46EX523 LCD TV
My wyse laptop turns on but my screen stays black
try undo things..if problem solved then,try use different cards
May 17, 2012 | WYSE Winterm V90LE Thin Client - Thin...
White thin line running across horizontal on my hp laptop
Hope it helps!
Feb 18, 2010 | Dell Inspiron 9100 Notebook
A horizontal thin black line has appeared across screen.
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Jan 27, 2010 | JVC PD-42V475 42 in. HD-Ready Plasma...
My KDL46X3100 has developed two thin black lines
It is problem of LCD Panel that will be replaced.
Please check with dealer / store for extended warranty option.
Aug 07, 2009 | Sony Televison & Video
Black line running horizontally across TV screen
A line on an LCD, either horizontal or vertical usually means the video driver board is defective or the screen is defective, does it show up as black even on a dark screen? That means a line of LCD "shutter"s is not working and there is a problem that cant be fixed by a reboot or channel change. Bummer.
Feb 17, 2008 | Televison & Video
Line across my laptop screen
The graphics part of the laptop is going out. Recommend just replacing the laptop, it would be cheaper.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Jun 10, 2017 | Computers & Internet
Horizontal 'pinstripe' lines on all channels
sound like the screen control on the flyback is set just a little too high. the flyback has the red wire attached to the tube. the flyback has 2 small adjustable controls. if you look close enough 1 is marked focus & on is screen. turn the screen slightly to the left & look at your picture. the screen is like a master brightness & if it's up too high you will see what is called retrace lines. good luck.
Jan 16, 2007 | Daewoo DTQ-20N3FC 20" TV
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
