My new hitachi 50hyt62u keeps flashing red and blue light
My new hitachi 50hyt62u which ive only had 2 weeks keeps flashing red and blue light, Hitachi logo comes on tv then just goes off, is there anything i can try to get it working or does it have to go back
4 Suggested Answers
memturbo
  • 226 Answers
SOURCE: Hitachi 43UWX10B TV went off constant clicking
it could be an internal corruption problem, but I doubt it. This problem is usually a serious power failure and generally very expensive. Sorry to say.
ONE: First, reset the tv by unplugging the power cord and let it remain unplugged for at least 4 hours. When you plug it back in the internal codes will come up as factory default settings. It may reset the power control section, but I doubt it; maybe 10% chance.
TWO: Look for a fuse on the back side of the set. It would be a black round knob with a fuse inside when you unscrew the cap. The fuse is usually about 1.5 inches long and 1/4 inch in diameter with metal on both ends and glass tube in the middle. Replace it with the exact same rating. It will probably blow again when you put in the new fuse (90% probably) and you will have to find out what is causing the failure.
THREE: If nothing seems to make any improvements, you will need to have a trained tech come to your home for a house call. If you can find someone who has experience with your model or similar chassis from the same manufacturer you will be better off.
IS THE SET WORTH FIXING: Yes, generally speaking, big projection sets are built to last 10 to 20 years. If you like the set and it has been a good product for you it would be worth fixing. The cost of repair will likely be in excess of $200 plus the house call. But that may not be a bad investment to keep it running for another few years.
But, in the long run it is a decision you will have to make.
Technically speaking, the cause of power interrupt failures are caused by heavy power drawing circiuts such as the projection tubes, power supply and high voltage sections. The projection tubes are very, very expensive to replace, but the others are not so bad.
Hope this helps you get started on the right solution.
Thanks for sending in your question and let me know if you will need further commentary.
Posted on Mar 29, 2009
dollycampbel
  • 87 Answers
SOURCE: HITACHI L42VK04U Red Flashing Light
power supply issue
Posted on Dec 17, 2013
  • 656 Answers
SOURCE: my hitachi 1998 projector big screan wont come back on red ligght flashing in from whgat might be the problem ?
Try disconnecting the power cord, then reconnect the power. This reboots the set.
Posted on May 29, 2014
How do I change language setting on hitachi 50HYT62U B
just keep navigating the menu on the tv. it MUST be in there somewhere, it was probably overlooked. It's usually in settings/options tab, or in initial setup screen. hope this helps
Feb 23, 2015 | Hitachi Televison & Video
Hitachi
Mine did that and the red light was flashing it was the lamp. Best place to get one is ebay
Aug 03, 2012 | Hitachi 42V715 42" HDTV
Hitachi p50h401 the power light keeps flashing
If you have a flashing red light, try this first: The flashing red light is, according to the Hitachi service manual, an indication of exactly one problem. It is that the fan (internal, blows air over the power supply heat sinks) has failed. In my case, it failed by continuing to spin (very confusing), but put out a signal (3V on the white wire of the fan harness) that it has failed (I had to look up the data sheet on the fan to figure this out). A new fan from Arrow $10 fixed the problem. If you suspect your fan, spinning or not, you can safely short the white to the black wire to see if your TV remains on after being turned on (solid red light), and then try turning your TV on (blue light) to see if it works.
Oct 17, 2011 | Hitachi P50H401 50 in. Plasma HDTV
I have a 50vs810 dlp. The blue and red lights flash in sequence when I turn it on.When they stop flashing the red light for the lamp is on. The yv has no volume and no picture. Is it just the bulb or does...
More than likely, it is the bulb. My hitachi 50v715 would come on(light up and show picture) 3 to 30 sec's with out the lamp indictor even lighting up. Put a new bulb in and works great. So I would try a new bulb. Look in your manual for the bulb number. Buy an original hitachi bulb they last a little longer.
Nov 05, 2009 | Hitachi 50VS810 50" Rear Projection HDTV
Tv no picture 50vf820 red blue lights on?
Yes you should order a new lamp and replace it. if you are not real handy with tideous electronic tasks, consider buying the lamp in am enclosure for an additional $30
Apr 29, 2009 | Hitachi 50VF820 Projection TV
Red light flashing-not reading ink cartridge
I have the same proble, except that the red light keeps flashing and nothing happens...
Oct 15, 2007 | HP PhotoSmart 7660 InkJet Printer
Televison & Video Logo
219 people viewed this question
Top Televison & Video Experts
Electro Med Services...
