Question about Tascam Dp-03 Digital Portastudio sd/cd
How do i record live vocal and guitar using internal condensor mics? i'm having difficulty understanding the setting instructions in window. don't want to multi-track just yet.
    Social Butterfly:
    An expert who has shared 10 answers on their Facebook wall.
    Habit-Forming:
  • 114 Answers
Can you call an expert to help you
Posted on Mar 14, 2016
4 Suggested Answers
SOURCE: tascam us 144 sync problems with cubase le
Hey lea,
i have a similar setup (Cubase LE & Tascam 144) and each time i start up Cubase i have to make sure there is no digital input going to the tascam. once cubase is started up but no project loaded i plug in my spdif from my DAT machine and then open my project and all is fine. does that answer part of your question?
i have a different problem though, i'm trying to record my DAT tapes which are recorded at 32khz and cubase doesn't recognize that sample rate properly. it'll record no problem, and play them back fine, but exporting always creates mismatched sample rates in the exported file. sucks big time and i have got no idea on how to fix it either.
Posted on May 03, 2008
  • 6 Answers
SOURCE: recording on cubase
Remember when recording in 24-bits, you have 8 bits EXTRA over 16-bit recording, per voltage sample.  This means that for each voltage step that would be recorded in a 16-bit recording, a 24-bit recording will take 256 steps!  In other words, the fidelity is MUCH greater, so even if your levels seem low, that can be OK, since you have around 100 dB of headroom to play with, and can increase the signal many times with acceptable fidelity.  What you DON'T want to do in digital recording is CLIP, which is a virtually unrecoverable fault in the recording.
Posted on Sep 06, 2008
  • 8 Answers
SOURCE: using a Tascam US 122 with Cubase SX, when
Make sure the switch is set to "mic/line" and not "guitar"
Your input level will be set by the "input L" or "input R" knob, depending on which side you are using. Start with them all the way down and then sing into the mic, turning them up until you get a signal about halfway up the bar in Cubase. That should give you plenty of headroom for clean vocals.
It may be difficult to get a good sound if you have one of those cheap mics that has a "1/4" jack instead of a 3-pin XLR jack. You might want to go to your local music/pro audio store and invest in a "condenser" microphone, which is good for vocals in the studio.
Posted on Mar 01, 2011
Hi i want to record guitar and vocals using my mz n510 what do i need
Just plug a mic into the mic input or the mixer into the line input. Watch your levels!
User manual http://www.minidisc.org/part_Sony_MZ-N510.html
May 01, 2012 | Sony Net MD Walkman MZ-N510 MiniDisc...
Using a Tascam US 122 with Cubase SX, when recording vocals red light (clipping) on the Tascam and in the Cubase mixer, I need to know how to set levels on Tascam, so there will be no clipping on vocal...
Feb 26, 2011 | Tascam US122 Audio/MIDI Interface with...
Hi. I am using the Tascam 2488Mkii in a very simple set up. I love the sound of the single effect reverb. I just want to record my vocal and accoustic with that effect (recording via microphone)....
If you own a small practice guitar amplifier with reverb, mic the amplifier and hook your guitar and microphone into it and run it into the board. You will get a better sound
Nov 28, 2010 | Tascam 2488 Portastudio Multitrack...
I am having trouble getting the trim set right. i have audio tech condensor mics, one for vocal and one for guitar, i have them in inputs a and b and the phantom power on. but i cannot find a level where...
Make sure you do NOT have a monitor speaker that is active! If you have a monitor speaker, it is POSSIBLE that there is a SUPERSONIC feedback going on that you cannot hear. This would saturate the system and distort your recording. Studio mics have a lot of gain and a wide response.
Dec 09, 2009 | Fostex Mr 8hd CD 8 Track Recorder with CDr
I need to output guitar and vocal separately. No matter how I hook it up guitar comes thru the vocal channel
Hi there. Use the "pan" pots to assign the guitar to left channel and all other pans to right channel. Also, turn all effects off or down all the way. (Effects return all the way down.
Thanks
Paul
May 03, 2009 | Digi-Tech Digitech Vocalist Live 4...
Cannot record both mic and electric guitar in daw
Disagree with previous post. The GTrack is designed to record vocals and a mono insrtument at the same time. That's its main selling point. It should also allow monitoring of both the vocals and guitar alongside the playback from the computer. In your computer's Control Panel, go to sound preferences, select the usb microphone and click on advanced tab. It is likely yours is set up to record 1 channel at CD quality - this is how many ship for some reason. Set it to 2 Channels CD quality.
In Sonar, set your track input as USB Left for the vocals, and USB Right for your guitar.
Mar 31, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
NT3 or NT1A?
Either mic will work for piano, vocal and guitar.
Jan 02, 2009 | Rode NT3 Professional Microphone
Tascam DP-02cf
You've got two inputs on the DP-02 so you can record two sources at once.
Depending on how you want the electric guitar recorded (mic the amp, or direct line in) you can in the first case plug your guitar mic into one of the mic inputs on DP02 and plug your vocal mic into the other mic input. You also have the option of plugging the guitar directly into the DP02 (using the hi-z input - I believe it is labelled 'guitar' or something on the DP02. I any event I believe it's the one on the left). This way you only need one mic for use recording the vocal part.
To avoid any 'bleed' between channels you can use the headphones while recording this way and you'll avoid having the unamplified guitar sound coming through over the vocal mic.
Once you have the mics or guitar and mic plugged into two inputs, you need to assign the inputs to a channel (track) to record on. You do this by pressing the select button for the input and then pressing the select button for the track where you want to record the input. Do this for both inputs so that they are recording on different tracks. Then arm the tracks for recording by pressing the record button for each track and the lighted buttons will flash above each armed track. Then just press play and record and you'll be recording. You can go back and redo it as many times as you like and record over what is there, or preserve a take and assign a new track (or tracks) for another take. You've got 8 to play with.
Hope this helps.
bd.
Sep 01, 2008 | Tascam 2488 Portastudio Multitrack...
Can not record vocal and guitar at the same time
The monitoring switch should not affect the recording at all. Maybe you have a defective mic?
Does it record from the line input if you set it to Line In mode?
Mar 27, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
Tascam Dp-03 Digital Portastudio sd/cd Logo
74 people viewed this question
Top Tascam Computers & Internet Experts
Ben Armstrong
Electric Dime
Electric Dime
Are you a Tascam Computer and Internet Expert? Answer questions, earn points and help others
