Service mode option for 11105 PS V3/3 - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 74,459 Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Posted on Nov 17, 2014
How can I open the service menu?
Press the helpful button and check link below for various models
First power off your TV using the remote, then press following buttons quickly on your TV remote:
Display (or i+) + 5 + Volume Up + Power
It'll show the hidden service menu on your TV screen.
Once you enter into service menu, you can press Menu (or Options) button again on your remote to switch between various service modes such as Digital, Chassis and VPC.
To navigate between available options press 1 or 4 buttons. To change or modify their values press 3 or 6 buttons.
To save your changes, just press Mute + 0 (or Enter) buttons on the remote.
To restore settings to factory defaults, press 8 + 0 (or Enter) buttons.
PS: For some new models the above mentioned method might not work. You can try following key sequence to access service menu in those new models:
While TV is on, press Left + Right + Mute + Center button + Mute + Menu buttons.
Hidden Secret Service Menu Codes for Sony Samsung LG and Philips TV
TV Service Menus Hidden features you didn know about
Jan 31, 2016 | Televison & Video
Tip
Samsung rest code Service codes Samsung: E900...
samsung rest code Service codes Samsung:
E900 software version: *#5002*8376263#
E900 full reset: *2767*3855#
Service codes Spice:
S404 enable COM port: *#42253646633# -> Device -> Set UART -> PS -> UART1/115200
S410 engineer mode: *#3646633#
S900 software version: *#8375#
S900 serial no: *#33778#
Service codes Philips:
S200 enable COM port: *#3338913# -> Device -> Set UART -> PS -> UART1/115200
Service codes "Chinese" models:
default user code: 1122, 3344, 1234, 5678
Engineer mode: *#110*01#
Factory mode: *#987#
Enable COM port: *#110*01# -> Device -> Set UART -> PS Config -> UART1/115200
Restore factory settings: *#987*99#
LCD contrast: *#369#
software version: *#800#
software version: *#900#
Service codes BenQ:
software version: *#300#
test mode: *#302*20040615#
Service codes Pantech:
software version: *01763*79837#
service menu: *01763*476#
reset defaults (phone/user code reset to default): *01763*737381#
Service codes VK-Mobile 3xx, 5xx:
software version: *#79#
software version: *#837#
service menu: *#85*364# (hold #)
Service codes VK200, VK2000, VK2010, VK2020, VK4000:
service menu: *#9998*8336# (hold #)
reset defaults (phone/user code reset to default): *#9998*7328# (hold #)
on Feb 09, 2008 | Samsung SGH-E900 Cellular Phone
Tda 11105/AO1 IC service mode
Type in the IC number in the search box at the top right of the display window, to get gathered some pages which has the details of practical experiences to the author of that site.
Aug 10, 2015 | Televison & Video
How can i Set Haier tv, my haier 14'' CRT change With 21'' CRT so vertical Hight is short, how can i adjust vertical hight.. IC "Trident TDA 11105 PS/V3/3/AP3
You can check it by reducing the value of the resistor, connected to ground at one end of the deflection yolks' vertical scan out windings. Usually, this resistor will vary a value of 1.2 Ohms to 2.2 Ohms. But, if you reduce this value too much, to say at about 0.15 Ohms or so, there is a possibility of damaging the vertical scan output IC.
So, do this very carefully. It is a trial and error process.
Check it with gradual reducing this value of this resistor; by 0.25 Ohms at a time. Wish you success. I hereby advice you, assuming that the horizontal width of the picture is OK.
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
May 05, 2014 | Haier Televison & Video
UOC Chassis TDA 11105 Standby LED not working and system EGT not working
Check the horizontal scan output transistor have collector-to-emitter leak. De-solder out it from the circuit, and switch On the set. If standby light glow now, make sure that it is damaged, and replace it with a new one.For more information go to http://electronicshelponline.blogspot.com/
Dec 02, 2013 | Televison & Video
IS THERE A PROGRAM TO ALLOW STAR TREK PINBALL TO OPERATE ON WINDOWS VISTA?
WIndows Vista allows you to run it in compatibility mode for previous Windows versions such windows XP. I suggest you try it and see if it works. To do this, Right-Click on Pinball.exe and click properties
In the properties window there is an option called compatibility. CLick on that tab. Once you click that you will see an option called run this program in compatibility mode for... Click the checkbox next to that and choose Windows XP service Pack 2 from the list
That should most likely do the trick. Give it a shot and let me know so that we can try something else. PS: Bad rating = No Further help!
Sep 16, 2011 | Interplay Productions Star Trek: Pinball...
Ink absorber full (E 27).how to reset
  1. Enter the service mode SERVICE MODE - pressing buttons Menu, Copy, Scan, Copy, Copy
  2. Choose TEST MODE.
  3. Select 8 PRINTER TEST TEST MODE.
  4. Choose 3, EEPROM CLEAR
  5. Select 0, INK COUNT
  6. Press the Set button.
  7. Click Stop / Reset button (return to item 3), and again press the ON / OFF
Rob
PS Thanks for ratings.
Mar 02, 2011 | Canon PIXMA MP190 All-In-One InkJet...
No picture for ps3,i went to service menunand did something wrong
You probaly turned hdmi on or off i dont know what your settings is,
you can turn your system settings back to factory default using the Safe Mode.
Step 1: Turn off the PLAYSTATION 3 by holding the Power button on the front of the unit till the Power light is red.
Step 2:
  1. Touch and hold the Power button, you will hear the first beep, meaning the PLAYSTATION 3 is powering on.
  2. Continue to hold the Power button and after about 5 seconds, you will hear a second beep, indicating the video reset.
  3. Continue to hold the Power button and after about another 5 seconds you will hear a third beep and the system will power off (Power light is red).
Step 3:
  1. Touch and hold the Power button, you will hear the first beep, again for the PLAYSTATION 3 to power on.
  2. Continue to hold the Power button and after about 5 seconds, you will hear a second beep for video reset.
  3. Continue to hold the Power button and after about another 5 seconds you will hear a quick double beep. At that point release the Power button. If you succeeded in activating Safe Mode, you will see a message on the screen saying, "Connect the controller using a USB cable and then press the PS button."
  4. Connect a USB cable to the controller and the PLAYSTATION 3 and press the PS button to enter Safe Mode.
  5. Then you will see the Safe Mode menu.
    safemode2.jpg //
Step 4: We recommending performing the safe mode options in the following order until one of the options works for you. If one of the options work, do not continue onto the other options.
  1. Restore Default Settings
  2. Restore File System
  3. Rebuild Database
  4. Restore PS3 System
Oct 04, 2009 | Sony Playstation 3 (PS3) Console
How do I look up what firmware im running on an ir5055
you need to go into service mode and then under copier/display/version
will be under there what version you have (service mode additional function key press that once then 2 and 8 keys together then additional functions key again will put you in service mode)
P.S to get out of service mode just hit reset button a few times
regards
Canon Tech
Sep 28, 2009 | Canon imageRUNNER 5000 Copier
Reset
The reset option I think that you are refering to is not available if the mode dial is set to any of the settings from full auto down (this is called the basic zone)
The reset option is available when the mode dial is set to any of the settings above the full auto mode.
Hope this is of use to you.
Sharpman.
ps, what was the original question, I may be able to assist
Dec 10, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
