Question about Ovens
How to test oven control board on a Frigidaire FEF366DBE?
Oven popped and blew breaker while using last night. Cook top works while neither the bake or broil elements do. Both visually checked and have continuity..Control panel still works and am able to set oven temp and the clock works, however will not heat up.
  • Official Brand Answer
  • 2,267 Answers
Hello Shawn Lloyd, thank you for your post!
I see that your Frigidaire range blew the breaker to your home out and now the oven will not heat up properly. There is not information provided in order to test the control panel I would recommend having a professional technician for proper diagnosis and repair. The technician will be able to use appropriate tools in order to verify the control panel is working properly. -Matt
Posted on Nov 19, 2014
I have a white frididaire oven model # FEF316B5D was cooking pizza then blew breaakers and now it is completly dead. Breaker is on but now power from oven
sounds like your bake element element has failed. Parts are readily available on line or call for service
May 27, 2018 | Ovens
Frigidaire plef398dca
Hello Bill Robbins - From what you are describing it sounds like a wiring failure or a communication break failure between the power board and UIB has occurred. Error code F5, typically indicates that the EOC will need replacing. A certified technician will need to test the wiring harness between the ESC, UIB and EOC.
Jan 21, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Why has both top elements stop working at the same time
Hello kimberlymaso - If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works; contact a professional to diagnose the EOC (electronic oven control).
Sep 25, 2012 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire Gallery oven large element stopped working
Hello -
If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works, contact a professional to have the EOC (electronic oven control) diagnosed.
Sep 19, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire stove oven problem
Sounds like the control board needs to be tested for any communication errors and possibly replaced.
Aug 24, 2012 | Frigidaire Ovens
Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
May 04, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Oven not working
It sounds like the element/s have blown, especially if the fan is still working o/k.
You cannot always tell by looking at them if they are faulty or not.
Only way to be sure is to test them with a meter.
Hope this helps.
Please rate my solution.
Thankyou.
Jan 18, 2010 | Frigidaire Ovens
I turned on my oven on my Frigidaire Range and heard a popping sound. This blew the breaker. I turned the breaker back on and the stove top works but the oven, broiler and bake do not work at all. The...
To be certain the elements are o/k you need to test them with a meter. I suspect one of them has failed.
You normally cannot always tell if they are o/k simply by looking at them.
Hope this helps.
Jan 11, 2010 | Frigidaire FEB27S5A Electric Single Oven
Bake or broil does not work
if an element itself had shorted it would not stop the other from working and you could inspect each element and see blistering as evidence.the pop you heard has to be in common with both elements but not the cook top[burners]so thats going to be the wiring in the back of range, or switching,[thermostat,clock timer or oven selector switch,depends on which model you have]you will have to pull range and remove back pannels.you will find an obivous burn't connection.too repair all new connections must be clean and tight,or will burn again.
Jan 24, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Ovens Logo
105 people viewed this question
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
