Question about Craftsman Snow Blower 26 In. 208CC Dual-Stage
Check oil level on 26" snowblower
Owners manual has two different ways to check oil level, one with fill cap unscrewed, and one with fill cap screwed down tight. Which is correct?
  • 721 Answers
There is no difference. It just takes a little longer if you screw down the cap. If your level is correct screwing cap in should not change results more than about 1/16 of an inch. GOOD LUCK FRIEND.
Posted on Nov 22, 2014
On a 1973 Ariens Snowblower with a 7hp Tecumseh motor what is the proper way to check oil level? Do you screw the dip stick all the way in or let it sit on top of the oil fill hole?
To check the oil you screw the dip stick as far as it will go. Before you start take the stick out and wipe it off then insert and screw it in to the bottom then take it out and check it.
Jan 26, 2015 | Garden
How to change oil in a Honda Reflex Scooter
Things You'll Need
  • Socket wrench
  • 17 mm socket
  • Drain pan
Instructions
    • 1 Move the Reflex to a level, well-ventilated work area and lift it onto its center stand. Start the Reflex's engine. Let it idle in place for 3 minutes, then stop the engine and let it cool for 10 minutes.
  • 2 Unscrew the oil filler cap from the right engine cover, which is located near the rear swingarm below the right passenger foot peg, by hand.
  • 3 Unscrew the oil screen cap, located directly below the oil cap, using a socket wrench and a 17 mm socket. Drain the engine oil into a drain pan for a minimum of 5 minutes.
  • 4 Pull the oil strainer screen out of the oil screen port by hand. Spray the inner face of the strainer screen, facing the engine, with a parts cleaning spray to remove sediment or particles trapped in the strainer. Push the strainer screen into the engine.
  • 5 Replace the oil screen cap O-ring with a new O-ring. Screw the oil screen cap into the engine by hand. Tighten the cap to 14 foot-pounds, using a torque wrench and a 17 mm socket.
  • 6 Fill the engine with 1 quart of 10W-30 API SG motorcycle-grade engine oil, using a funnel. Screw the oil cap into place by hand.
  • 7 Start the Reflex's engine. Let it idle for 3 minutes, then stop the engine. Check the oil level, using the dipstick built into the oil cap. Add 2 oz. of 10W-30 API SG motorcycle-grade engine oil into the engine, if the oil level is below the dipstick's lower level mark. Do not add oil into the engine, if the oil level is at or near the center of the dipstick's upper and lower marks. Screw the oil cap into place by hand.
  • Jun 27, 2014 | Honda Motorcycles
    Transmission dipstick location
    the dip stick is located in engine compartment if you stand in front of car with hood open the dip stick is to your left on side of trany, if this car is stick shift and not automatic then theres no dip stick its checked from side of trany by removing a plug and fill until oil runs out a little a lift would be the way to check it, the car must be level
    NOTE; some models have a tube with dip stick and some a cap that unscrews on top of trany and when checking fluid you dont screw in just stick in hole to check level when done then screw back in and tighten,heres a diagram to help you find it.c083006.gif
    Aug 25, 2010 | 1991 Honda Civic
    POWER TRAIN
    No, It sounds like you are low on oil. there is a fill cap on there somewhere, might be a bolt, plug, but you can check it and fill it hyd oil. I had an old Wheelhorse, never had a problem with the hydrostat, worked great. Check it out, hope this helps.
    May 04, 2010 | Husqvarna Lawn Tractor - 54in. Deck, 26...
    I would like to know how to do my own oil change. If possiable where do i put it and how much also what kind? and the transmition oil also... thank you for your time
    oil capacity will be in your owners manual, should be marked for a drain and fill and for a drain and fill WITH filter change. as to the oil grade. seasonal temperatures mean different grades, generally newer cars (ie 1998 or newer) generally just like a 5W-30, i usually go with a 10W-30 though anyways (no cost difference usually). your manual will also tell you what size filter you need. ok, first you should loosen the filler cap on top first just so we get airflow in the block. on the bottom of the engine is the oilpan, it will have bolts all around the edge of it (dont touch these) and one right on the bottom of it, sometimes just off to one side, put your catchpan under this bolt and remove the bolt, the oil will now come out (make sure your pan can hold at least 10 litres as some engines can hold ALOT of oil. using your oil filter wrench, remove the oil filter (cylinder shaped usually near the oil pan). careful since it will also be full of oil. once everything is drained. replace the plug on the oil pan (do NOT forget the gasket if your plug has one). using fresh oil, take your finger dip it into fresh oil and run it along the rubber gasket on your new oil filter and screw it on BY HAND till it feels snug, then go 1/2 to 3/4 of a turn more. down the filler cap ontop pour in 3/4 of the capacity of fresh oil that is stated in your owners manual, let it sit for 30sec-1min and check your dipstick 2 times for an accurate read. continue filling and checking till you meet your full mark on the dipstick keeping in mind that once the level gets onto the stick 1 litre can make the difference between a low and full level read. once you reach full, close the filler cap, run the engine for 1 minute, shut it off and check the level 2 times again, it should have gone down slightly since the filter is now full aswell, check and fill to full mark again and you are done. be sure to dispose of your used oil and filter in a safe way, most automobile service centers can take the used oil and filter and dispose of it for you safely.
    Feb 25, 2010 | 2008 Dodge Charger
    Where do i put oil in my 1984 thunderbird
    My friend, if you do not know where to put the oil, you probably have no business working on your own car. Read your owner's manual throughly. But I will answer your question. You add oil to the engine at the oil fill cap, which is normally located on the valve cover. It is a large cap that will usually have OIL written on the top. You also check the oil level at the oil dip stick. You must have the vehicle parked on a level surface and the engine must not have been run for at least 30 minutes or you will get a false reading. Over-filling is just as bad as under-filling. Do not add oil unless you have checked the oil level properly and you know for sure what you are doing.
    Sep 28, 2009 | 1984 Ford Thunderbird
    How do you check oil level? what is the correct way to do it?
    un do the oil cap ond there is a stick on it to measure it
    Jul 30, 2009 | 1999 Honda V-Twin Magna
    I have a 2001 yz125 and i didnt get a owners manual with it,i need to know how much oil i need to put in the bike thanks for the help!
    On the right side of the bike on the side of the motor there is a black screw 8 or 10 mm unscrew it out fill with oil till it leaks out of the screw hole put screw back in and your set make sure the bike is level strait up and down.
    Apr 27, 2009 | 2003 Yamaha YZ 125
    2003 vulcan 750-how/where to check engine oil level / noisy
    there should be a little window just below the oil fill area that says high and low, that's where you gauge the level of oil you have. it's not a dipstick, and not very precise, but that's it.
    Mar 06, 2009 | 1994 kawasaki VN 750 Vulcan
    Oil level
    Hi saturnin
    That's the best way to get it right. Do what the manual tells you to do.
    To check the oil
    1. Put the bike on level concrete on the center stand
    2. Check the oil with the dipper in the oil fill hole.
    3. Check it hot 10 mins after turning off the bike by unscrewing the oil fill plug, wipe the stick, and just dip it without screwing it back in, and check it for level.
    4. Pour in small amounts at a time to top it right up to the mark, but never ever over fill it.
    5. Screw back in the plug/dipper.
    Hope this helps, am happy to answer any other questions you may have about it. Cheers!!
    regards
    robotek
    Nov 15, 2008 | 2004 Kymco Venox 250
    Craftsman Snow Blower 26 In. 208CC Dual-Stage Logo
    88 people viewed this question
    Top Craftsman Garden Experts
    Wade Mobley
    Wade Mobley
    Jim Parker
    Jim Parker
    Dennis Key
    Dennis Key
    Are you a Craftsman Garden Expert? Answer questions, earn points and help others
