Question about Nokia Lumia 520 Windows Phone Black
A yellow box is around my lock screen and wont let me unlock it how do I fix it
When ever I touch the screen it says items and none of my buttons work
IS THERE A WAY TO ADD NOTES FOR A SPECIFIC ORDER TO THE KITCHEN RECEIPT? THAT WAY IF THERE IS SOME RANDOM REQUEST, WE CAN GET THE ORDER RIGHT FOR OUR CUSTOMER
hi elissa,
one way is to create an item with no price in the none department. check boxes for modifier and prompt description. uncheck box print on receipt (unless you want the note on customers tab). set it to print to kitchen. Now create a quick button under touch screen configuration with the function fixed item. label it kitchen notes. enter the item name that you created earlier and save.
sysadmin@ccybernet.com
Feel free to email me with more details if need be or if you want my help.
Aug 28, 2013 | Pc America Restaurant Pro Express
My arcos no working teh touch screen so bad because for example u press a dive k d q etc
I believe you are trying to say that your touch screen isn't working. Your touch screen is probably locked. Its similar to a button hold lock, when this is activated, you can't press any buttons do anything unless you unlock it. To unlock the touch screen, press the ON/OFF button (don't hold the button for a long period of time. A message will appear on your screen asking for your conformation (approval) to perform the task. If that doesn't work, tap the TOOLS option, then select SETTINGS, and choose SCREEN. Once you've done that, choose the "Touch Screen Calibration" button and follow on-screen instructions given. If the second solution doesn't work, the "Touch Screen Calibration" option can be forced by using a feature called 'System Recovery'. To do a system recovery, Press and hold the Power button, then the Volume + button as soon as possible until you see a white screen, as system recovery is beginning. While this is happening, you will not be able to use the touchscreen to navigate between items. In order to navigate between items, you will have to use the Volume + & Volume - buttons and use the Power button to validate your selected task. The system recovery feature gives you a lot of options. Select the "Touch Screen Calibration" option and follow on-screen instructions given. I hope this activates your touch screen again.
Mar 22, 2011 | Archos 7 Digital Media Player
LG touch phone. Touch screen keeps blanking out, it that the touch screen will not work. Screen shows everything but the touch of the screen does not work. I have took out the battery and replaced it. It...
when phone is idle, the auto lock feature locks out the screen. you can set the time when lock engages or disable completely. To unlock, press top right corner button or use touchscreen options by sliding finger up from bottom to top or press unlock button on bottom of touchscreen
Feb 19, 2011 | AT&T Cell Phones
My sumsung d980 touch screen is not working
You will have to get the digitizer replaced. Y
Oct 28, 2010 | Samsung SGH-D980 Cell Phone
How do I send notes to my kitchen printer
You first need to create a new inventory item.
1. Create a standard item in the INVENTORY Maintenance.
2. Call it NOTES and put it in the NONE department.
3. Uncheck all boxes under OPTIONAL INFO, the OPTIONS tab.
4. Click the ADDITIONAL INFO tab, uncheck all boxes but PROMPT DESCRIPTION.
5. Under PRINTERS, add the kitchen printer.
6. Save the inventory item.
7. Go to SETUP, TOUCH SCREEN CONFIGURATION.
8. Click on one of the 16 buttons in middle of page, an unused one. It should turn green.
9. On bottom half of page, set it to a FIXED ITEM.
10. Set caption to KITCHEN NOTES.
11. Check box to display button.
12. Picture can be left blank.
13. In ENTER ITEM NUMBER, type NOTES, the new item you created.
14. Click SAVE AND EXIT.
15. Log out of RPE. When you log back in, you should have a KITCHEN NOTES button. You have a limit of 30 characters. However you can hit button as often as you like to continue your message to kitchen. This should not print on customer's receipt.
B Mattern
Aug 29, 2010 | Pc America Restaurant Pro Express
My bottom screen wont work on my iphone and wont slide to unlock how to fix
Ensure that you are using a recommended screen guard. Check for damages on the touch screen. Be sure that you are using your finger and not a pen or something. If none of these things work take it to the nearest apple store for repair.
Nov 12, 2009 | Apple iPhone Smartphone
Have htc diamond phone tried to set a lock code ad cant unlock it
i suggest you call your cell phone provider and they should be able to reset the pass code....because similar thing has happened to me.
Apr 27, 2009 | HTC Touch Diamond2 Smartphone
Unlock kenmore 665.69682992
This is a Whirlpool model, so one of these methods should work:
- Press and hold the Cancel button for 3 or 4 seconds.
- Touch and hold START/ENTER for 4 seconds.
- Touch and hold START for 5 seconds
If none of these works, contact Sears.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 11, 2008 | Microwave Ovens
Nokia Lumia 520 Windows Phone Black Logo
75 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
