Question about Sharp VC-A588U VHS VCR
Setting the recorder mode
How do I change the recorder mode from SP to EP?
  • kand Nov 13, 2007
    I don't have the remote to this vcr. Is there any way to change the recorder mode manually?
  • kwokie2 Dec 11, 2008
    how to manually change the mode speed on vcr
    Problem Solver:
  • 10 Answers
Usually with the remote. see answer to the top question.
Posted on Nov 13, 2007
  • video guru Nov 13, 2007
    There is no way you can change the recording mode manually
    if there is no control on the front of the VCR itself. (it may be
    hidden inside a little door) if you have a older VCR that lets
    you program it from the VCR itself you can set a timer on it
    and and set it at ep speed that way. That's the only way you can do it. Or find a remote, a cheap kind that will
    let you program the VCR from it. But there's probably no use
    to buy an expensive remote because new vcrs with remotes are so cheap now in my my area anyway around $30 here.
    an expensive $80 remote might have a direct programable
    button to set the vcr speed . but that's a waste of money
    when you can buy a new vcr for less.
    but note programing them is a hassle if you make one small
    mistake it probably won't come on. make sure you check
    it at least 3 times. (then it still might not come on for some reason) thats why they made dvrs) its easier to just be home to see if its
    recording the show or let the VCR record the whole tape full and
    set it early and you see that it is on if you see it recording
    you know that it will recording for the 6 or 8 hours in ep speed.
My plug has been changed how do I get ep off of my unit
Which plug did you change? "EP" stands for Extended Play. A VHS recorder has three speeds. EP is the slowest. A standard 2-hour tape will record for 2 hours at the highest speed (SP), 4 hours at the middle speed (SP) and 6 hours in EP. There is a trade off. The faster the tape moves past the recording/playback heads, the higher the picture quality and visa versa. So EP gives you long recording time at a cost in quality.
I doubt that the unit being in EP mode has anything to do with the cable. You did not say what brand and model recorder you have, but in general, the speed is adjusted with a switch on the front panel (older models) or via your remote control.
Jun 22, 2015 | Televison & Video
Changing sp mode to ep
Are you asking how to change the record speed to extended play? This is usually given as a choice when programming a recording. You use your remote to scroll through various options on the input screen and you should find that you can choose between sp/ep/lp (standard, extended and long play)
Apr 08, 2015 | Televison & Video
I am trying to record a program in EP mode but when it records it returns back to SP mode. How can I set the tape for EP without it returning to SP?
Most VCR's have a default recording setting for recording speed or other settings. It's just a question of finding the right menu. Have a good look around the menus. However the VCR might default to SP after recording in EP, however the playback should switch to EP when playing.
Jun 09, 2010 | Televison & Video
Changing from SP to EP
Camcorders have a software setting in their menu for picking the modes. Refer to your manual, or look around the menu on the cam.
Mar 19, 2010 | JVC GR-AXM17U Camcorder
VCR LP/EP compatibility
Vdumitre -
No, not usually. If you've recorded a tape at LP and put it another machine that doesn't have LP, it usually won't play properly. Some machines that have only SP/EP will do this, but they are got scarce as more manufacturers dropped the LP speed. Your best bet is to buy an older one from a thrift shop or a garage sale, making sure that it will play LP. Then, copy your older LP tapes to SP or EP (Run the OUT from the LP unit to the IN on the SP/EP unit, and choose "record from line in", "aux", or "rear input").
Thanks,
videoman7
Aug 05, 2009 | Sony Televison & Video
Change VCR settings from SP to LP or EP
Hi;
I have a Panasonic VCR with a different, but I know how to 'fix' your problem on my m/c. The remote for my m/c has a "REC MODE" button; operating that button changes from SP to EP etc. Check it with the "Program" button on your TV screen.
harrisonmx3
Apr 27, 2009 | Panasonic Televison & Video
What does sp and ep stand for when setting the record timer on the vcr
SP = Single Play (normal 1:1 recording)
EP = Extended Play (normally allows two, four or even eight times the normal or Single Play length to be recorded, according to make/model.) Picture quality in EP will not be as good as SP.
Apr 19, 2009 | Televison & Video
Dubbing from VCR to DVD
Dont use xp mode. Here are the definitions:
SP is short for Standard Play. Standard play allows you to record information onto the tape the way it was intended, with no quality loss. By default, VCRs and camcorders will record your footage as standard play. On a standard VHS tape, recording footage in SP mode will yield 2 hours of video.
LP is short for Long Play. Long play allows you to record much more information at the expense of quality. It accomplishes this by reducing the speed the tape is run through the VCR. As the tape speed decreases, the quality will also decrease. You’ll notice this effect when comparing a tape recorded at LP versus one recorded at SP, especially after years of storage. The LP tape will appear more blurred, have more tracking and color issues than tapes recorded at SP. A VHS tape recorded at LP can hold roughly 4 hours of video.
EP/SLP is short for extended play. Extended play is similar to LP, but actually provides you even more recording time. EP was primarily used to document long, continuous events without the need to change video tapes every 2 hours. Due to the fact that the video is not of optimal quality, many times this setting was not used in order to preserve the quality of your footage. Tapes recorded at EP usually are the most problematic after years of storage, displaying a wide variety of tape damage symptoms including color loss, audio loss, frame skipping, and tracking issues.
Sep 02, 2017 | LG LH-C6235 System
Sony VCR plays/recordes in EP mode but not in SP mode - need schematic
sounds like it needs a good cleaning, you will notice this problem in sp first when needs cleaned. however if you had done this I would go over it again and if not then change the video head
Nov 19, 2007 | Televison & Video
Open Questions:
See all Sharp VC-A588U VHS VCR Questions
Sharp VC-A588U VHS VCR Logo
122 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
