NikkaiA76FT digital reciever keeps turning tv off why
When watching cable tv we are not getting any sound from the speakers. We do get sound from all the speakers when watching a dvd or listen to the stereo. I have a Yamaha HTR 5660 receiver. All the cables...
Your best bet is to hook all your video components directly to TV, using your TV's menu to choose what you want to watch, and then hooking reciever to TV via digital optical out from TV to digital optical in on reciever. From what I read, your reciever has 6 digital optical inputs. Anyway, try running, at least, your cable box to TV, best by HDMI, the run digital optical out to reciever. Make sure you go throught he recievers menu to make sure you have he right channel selected for audio.
Jun 25, 2011 | Yamaha HTR-5660 Receiver
Set up for panasonic tc-50ps24 tv with hd cable box to home theater and dvd recorder
Man the best i can tell you to do is to keep everything strait starting with your video and then your audio. If your running Hi def you might can possibley run S-Video being that your DVD recorder may only have the input and out for that. If so you would take your video being S Video run it into the Home Theater Reciever and then go monitor out of the reciever into the DVD recorder. Keep in mind you must run S Video into your Home theater then to your DVD. More then one cord may likey go into your Home theater but only one should come out to go to the DVD player and then to the the TV but thats just for your Video. Now for your sound you have a few options. You can run anlalog to the Reciever or run from the Digital side either Coax or Digital Optical and again this is for your sound and is marked on the reciever. Your better sound will be Digital but you can still run analog if you want to do so. It may be easier for you to understand that anlalog is unsually in mono and not stero which means your sound will not have the defination you may want but never the less you will still have sound.
Jan 04, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
CAN NOT RECIEVE ANY CHANNELS JUST KEEP RECIEVING \...
First make sure the TV is in TV mode (press mode on the set, or TV/AV on the remote).
Once in TV mode, press MENU and use the navigation buttons (arrows and ENTER) to choose the set to factory default mode.
Also make sure you have a working signal by trying another TV on the antenna or cable coaxial wire.
If these steps do not work, call the Haier hotline listed in the manual: 1-877-337-3639
May 20, 2010 | Haier HLT71 7 in. Portable TV
My beko 20'' lcd tv picture keeps bouncing . when it is turned on. what could be the cause? The picture is fine for a few minutes then starts jumping
Is this tv getting free air signal?Have a better antena like a roof antena or digital antena.If it cable,satalite or telicom signals.Turn off the reciever box,than turn it on again for the signal to reboot and update the software to work better.
Nov 06, 2009 | Televison & Video
Connecting LG 42PG20 TV to Samsung HT-Z320 receiver
output on TV cable digital reciever to home theater digital reciever in via an optical cable.lower the volume on the TV cable digital reciever to get the most out of the surround sound system.
Oct 15, 2009 | Samsung HT-Z310T Theater System
I have a vr-405 5.1 channels reciever, I have it hooked to nanlog out on tv per tv manual,tv speaker r off,there is a dvd/vcr hooked into video 1 and it works on tv speaker, where do i hook into the...
try to be a little more clear on what you are trying to do.do you have it connected to hdtv and cable box if so run hdmi cable from cable box to tv and then run optical cable from reciever to cable box you then must turn reciever to cd/dvd to listen to it leave reciever in auto mode go into cable box menu under audio and select dolby digital
Feb 21, 2009 | Kenwood VR-405 Receiver
Recieving no digital channels in my LCD TV
hi there alot of the updates for the system should automaticly download via ariel to the tv to keep you up to date some times if the strenght of the signal isnt srong enough then you might not get the update they send out , one thing i have found is that if you use an ariel booster then this makes the signal stronger this helps particularly if you have more than one tv set up with the same ariel, you could try unpluging all ariels to other tvs making sure the ariel lead you are using has no conections in it as this also gives you loss of signal if there are multiple conections in the lead runing from the ariel to your tv set hope this helps some
Cheers ;)
Feb 05, 2009 | Toshiba Regza 42C3030DB 42 in. LCD TV
Digital or Analog>
I believe this tv has a built in digital tuner. To verify this, using your remote attempt to change the channel to say 3-1 or 3.1 if you have a digital tuner this is how a digital channel will show up. Also if you go into your menu under channel scan you should see a choice named dtv. And finally on the back you will have a coax connecter named dtv. The latter is not always true. If it does turn out to be standard format tv, you can still purchase a digital set-top box that will decode digital for you. Keep in mind that you must have a good uhf off air signal in your area to recieve digital signals. Good luck.
Feb 20, 2008 | Televison & Video
No digital to reciever??
This tv will only output the sound from a digital tv channel through the optical output when using the tv's digital tuner. So if you are connecting a DVD etc it will not output through the optical output on the tv. ONLY digital chanels through the tv's tuner will give you sound. Refer to the tv's owners manual for more info.
Dec 27, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Installed surround sound, no picture on tv
I could not get my TV to recognize an S-video signal from my reciever either. I ended up just bypassing the reciever and running the video straight from the cable box to the TV. It might be a better option anyways as some quality is lost if you run it through the reciever.
Mar 20, 2007 | Onkyo TX-SR602 Receiver
 Grubhead
Grubhead
