Question about Konica Minolta A034012 Magicolor 1650en Laser Printer
My printer says "Belt Error" how can I fix this?
    Master:
  • 424 Answers
The printer detected incorrect
image position on the image
transfer belt.
Check the cyan and black
toner cartridges and replace
them if they have run out. Page 171 of Konica Minolta Magicolor 1650en Laser Printer Manual...
Posted on Nov 16, 2014
IRC4080i printer. How do I correct error code E000007-0001?
Error Codes Relevant to Fixing/Pressure Belt Displacement Control
E007 Fixing belt displacement error
0001: Upper belt displacement fault. (Either the upper belt full displacement or the belt displacement sensor
fault.)
0002: Lower belt displacement fault. (Either the lower belt full displacement or the belt displacement sensor
fault.)
0101: Upper belt HP detection error.
0102: Lower belt HP detection error.
Note:
Adjust the fixing/pressure unit HP with the following service mode at the installation or when replacing the
fixing (pressure) belt.
COPIER > FUNCTION > FIXNG > FX-UHP-S
> FX-LHP-S
Points to Note When Replacing Fixing Unit
By executing the service mode, the alarm code is closed and the total rotation time is cleared. Thus, this mode
must be executed when replacing the fixing unit.
If the mode is not executed, the following symptoms will occur.
-The alarm code is not closed.
06-0002: Fixing unit life alarm (Caused by the belt displacement)
06-0004: Fixing unit life alarm (Caused by the torque up)
-Although the total rotation time of the replaced fixing assemble does not reach to the message threshold, the
machine wrongly recognize that it reaches to the threshold and displays the message.
Be sure not to execute the mode except at the installation and the fixing unit replacement. If not, an error
message may not be displayed when the fixing unit reaches to its life.
Sep 10, 2015 | Canon Office Equipment & Supplies
Error code E000007-0101
"Fixing belt home position detection error.
Replace the fixing belt HP sensor. Replace the fixing deviation control
motor, DC controller PCB 2 (MAISY) and fixing unit."
Usually only helps a replacement fixong unit.
May 21, 2014 | Canon irc5185i
Konica minolta 1690mf process error belt clear by cover
KONICA MINOLTA 1690MF ERROR:
process error - belt (clear by cover)
SOLUTION: Open and close the scanner unit. Reseat the Image Unit and cycle the power to the machine. If the error persists and the machine is covered by warranty, a printer exchange is recommended.
KONICA MINOLTA SUPPORT PAGE:
https://kb.mykonicaminolta.com/selfservice_bus_anon/microsites/search.do?cmd=displayKC&docType=kc&externalId=TAD-doctad227704html0&sliceId=&docTypeID=DT_TAD_1_1&dialogID=10562139&stateId=1%200%2010556672
Feb 27, 2012 | Konica Minolta magicolor 1690MF All-In-One...
How to fix transfer belt error in my samsung CLX3160fn
To fix this error, you will need to replace the transfer belt and/or reset the transfer belt count on your printer. If you are happy the the print quality of the printer, then you can try to reset the transfer belt count and that will clear the error. Otherwise you need to get a replacement transfer belt and swap it out before resetting the count.
To remove your existing transfer belt, you need to open the front panel, and remove the imaging unit by pulling the green handle. The belt is located above the imaging unit. Pull the belt down to release and then pull it straight out of the machine. Take your new belt and slide the back into the machine and push the front of the belt up to lock in place. Then you need to reset the belt count.
To do this, follow the steps below.
1. Enter Tech Mode by pressing [MENU] [#] [1] [9] [3] [4]
2. If you do not see the Tech Mode menu press the menu button again. (You need to enter the key sequence quickly.)
3. Select Tech Menu
4. Select DataSetup
5. Arrow to Clear Counts and press OK
6. Enter Password 1934
7. Arrow to Transfer Belt and press OK.
Hope this helps you.
Feb 27, 2011 | Samsung CLX 3160fn All-In-One Printer
Error code e005
E005 is a fuser cleaning web error The fixing cleaning belt has been taken up. ? The fixing cleaning belt has been taken up. ? The DC controller PCB has a fault. ? The image processor PCB has a fault The fixing cleaning belt drive solenoid has been driven more than a specific number of times.
Apr 14, 2010 | Canon ImageRUNNER 330s Copier
SVC EL ERROR appears on the display
The SVC EL error on the 8008 indicates an 'ERASE LAMP' error.
The erase lamp in the 8008 is situated below the OPC belt in the printer, as a step to fixing the problem I would suggest removing the OPC belt from the printer, and taking suitable precautions to protect it from light and damage.
Then clean the area under the OPC belt in the printer to remove any stray toner.
Then test the printer, if the problem persists I would recommend having a suitably qualified engineer look at the printer. To check the Erase LED array is connected correctly and is functioning correctly.
Jun 21, 2009 | TallyGenicom 8008 Laser Printer
I have a oki 9600 Fatal error 917
Replace the transfer belt unit. A 917 is a belt **** sensor error.
Jun 19, 2009 | OKI C5150n Led Printer
Re Samsung CLX-3160FN & Transfer Belt Error
Take out the Imaging unit ,transfer belt and fix it properly.
Also take care that you will keep the printer on even surface.
IF nothing is solving the problem then you need to replace the transfer belt as a final solution.
Jun 18, 2009 | Samsung CLX 3160fn All-In-One Printer
Tally Genicom 8008
The Set Belt CG message on the 8008 indicates the printer is not detecting the OPC belt (the green reflective belt located in the top of the printer)
Try removing the Belt Cartridge and relocate this in the pritner, if this fails to fix the problem remove the Belt Cartridge from the printer then look down one side of the belt- (I think the left side of the belt), for black squares (I think there are two) the printer uses these to detect the Belt Cartridge is rotating. Check for damage to the Belt in this area. If the printer does not detect the belt as rotating it will indicate this error.
If the Belt Cartridge looks ok, remove the Belt Cartridge from the printer then look down the hole left in the printer when the belt cartridge is removed. Look for any obstuctions, also look at the black belt which is towards the back of the printer when you look in the top ( the transfer belt, I think) Look to see if there is any damage to this it may cause the Set Belt CG message.
Apr 02, 2008 | TallyGenicom 8008 Laser Printer
Konica Minolta A034012 Magicolor 1650en Laser Printer Logo
112 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
