Question about Ovens
My display is broken so I cant put oven on any advice
Displayhas gone off and oven won't work until this is set can it be replaced
  • John Griffiths Nov 20, 2014
    Before dismantling as stated below try re-setting the clock as per your oven's manual .
    Obviously following the cleaning you will again have to re-set the clock as per your manual to get the ovens to work. Add a Comment
    Problem Solver:
  • 3 Answers
Had a similar problem over a year ago on my Rangemaster, neither of the ovens would come on, only the gas hob worked.
The cost of a new display unit was around £100 plus so decided to check out the unit by removing it (it was quite easy to do; but remember to isloate the cooker from the mains before you start dismantling).
On my display there were six wires plugged into it. I marked each one and the display before removing them so that they all went back to the correct location (i am not an electrician and am therefore an electrical numpty).
Firstly I degreased each male and female connector using an electrical spray degreaser/cleaner and then cleaned them using very fine emery paper and a special pen with glassfibre bristles until they gleamed and then gave them a final spray to remove any debrie left by the cleaning process.
Before i put everything back i also cleaned all the connectors to the switches etc which were accessable in a similar manner; about another eight/ten in total.
Following reassembly and switching the power back everything started working again. All this work took about an hour and my cooker has been working fine for the last 12 months.
Posted on Nov 20, 2014
Smeg linear oven is displaying sho (showroom mode) and will not heat up. I have held down function knob for 5 seconds which clears SHO from display but within seconds it comes back. Any ideas
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Sep 28, 2013 | Smeg Linear Pyrolitic Single Oven Electric
SMEG OVEN BRAND NEW WON'T HEAT
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
Sep 08, 2012 | Smeg Ovens
Fixed fan element, but can't remember how to put it back together again
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Jun 22, 2012 | Smeg Ovens
Oven does not work! temperature display goes very fast and won't stop to higest temp
You have a bad control board and oven temperature sensor. I highly recommend disconnecting the power source until the repair is made.
Apr 24, 2012 | Thermador Ovens
I push the bake button for the lower oven and it begins to beep and displays a F9 on the digital display
Hi
F9 is a door lock error and to solve this issue you can hold the light switch for 15 seconds, this will reset the control. If it won't work then hold the light switch in and set the unit to clean and after a minute press cancel to cancel the clean cycle. If still it won't work then the door lock assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 01, 2011 | Amana ACB6260A Electric Double Oven
I have a Smeg SA 398x model. firstly, I would like to know the year of manufacture please. Secondly, for some reason the fan element options do not heat up. The fan in the back of the oven works but no...
Jul 19, 2011 | Smeg Linear Pyrolitic Single Oven Electric
When using the oven the electicity tripped; after resetting the breaker the oven does not appear to get hot; however the grill works, the light works and the fan works what could be the problem?
Sounds like the oven element has gone. When these elements go they often short against the outside casing of the element which is earthed (or should be). This trips the main trip switch in the house. Having tripped and cooled down, the element is now broken inside & won't heat up. Usually 2 screws to remove, either inside oven or outside at back. Element usually taken out thro oven. Take it & cooker info to your dealer & ask for replacement. Shouldn't cost much.
Jun 13, 2011 | New World Ovens
Hi Our oven wont turn on, has power as the display panel has a little "A" luminated on the left of display screen but nothing else operates, no fan, Grill, timer. please advise
Mar 24, 2011 | Smeg SE210X/1 Stainless Steel Electric...
MY 24 INCH BUILT IN SINGLE WALL OVEN DIGITAL TIMER
turn power off at main box the back on retry st set clock . if it won;t set / replace it . it has gone bad .mm
Dec 09, 2009 | Maytag 24" Built-In Single Electric Wall...
Oven wont work
ok an oven won't work withought the time set i am not sure which one you have but usually if you press all the buttons together the oven will then work
Apr 03, 2009 | Kenmore Ovens
Ovens Logo
63 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
