Question about Acer Aspire Computers & Internet
How do I reinstall or recover the Operation System
My computer running slow, at the store did diagnostic this week,
  • Acer Master
  • 5,649 Answers
Use the install disks either that came with the PC or that you made when started from new! Just put the disk in and follow instructions!
Posted on Nov 16, 2014
I want to recover my computer to it is original coditio but i cant because my computer doesnt to start because it says that i dont have operation system in my computer for that i cant reach recovery file...
hello if you have window 7 the easy way is reboot your pc and put the Disk in. it will give you option you want to recover or install the operation system . Window7 and Vista and kind of the same But xp you have to reinstall it. it doesn't give you recover option. please rate my comment
Nov 21, 2011 | Sony VAIO VGN-AR820E Intel Pentium...
My 5 year old Toshiba U300-13u is extremely slow and the disk drive isn't recognised and doesn't open. It is core2duo but is supremely bad. The battery life is about 20 minutes. Can Overuse be...
No, it is not need to apgrade, it will be good to reinstall your windows system, on it you can install Windows 7 32bit too, /if you have driver pack for windows7/, if no, reinstall vista 32bit, no problem, will be right, After it if your cd\dvd drive will not work, you can change only it.
May 30, 2011 | Toshiba Computers & Internet
My computer is VPCF121FD,when I recover my system,it stop at 60% and it said "An error occurred while executing an application" The operation was not completed error:320
Hi
You computer's operating system if corrupted and does not accept the system recover. Just reinstall or repair operating system and it will bring back to normal.
I hope it help you.
Jan 11, 2011 | Sony VAIO VGN-NR498E/S Notebook PC
Slow pc and no sound icon
I believe you had too many files on your computer. I advise to run deframenting your computer every week to speed up your computer and also run scan disk for error to fix some problems. Just go to program files>accessories>system tools>disk defragment. If still slow I advise to reinstall your operating system or ever upgrading it to windows 7 or vista.
Jan 04, 2011 | Dell Dimension 3000 PC Desktop
My dell inspiron 1525 often slows down
To speed up the computer we need to follow these steps this will run your computer operation much faster.
Click the start menu button and select run or search command box type in %temp% and then press enter you will see a box with lots of files single click on one of the file or folder then press the control + A key it will be all selected or highlighted, now you can press shift + delete key on the keyboard this will remove all temp files which is not necessary for the computer.
Type in the run or search box prefetch hit enter and follow the same process as the first one after that open control panel and select add/remove program it will show all the installed softwares in xp and in vista/win7 open programs and features icon once you see the unwanted list of installed programs highlight and remove it one by one, you need to identify the once which you do not require and then remove it by simply highlighting and hitting the change/remove button.
Run msconfig in the run box or the search box it will open a window click on the startup tab and deselect the one's which you dont require while system boots.
Nov 14, 2010 | Dell Inspiron 1525 Notebook
Hi My Laptop is very slow in booting and
Try to run a diagnostic on the hardrive and memory. Dell has a built in diagnostic. to run the built in diagnotic, make sure the laptop is turned off. Hold Fn, then press power button. you will see the diagnostic screen. after running the diagnostic and you didn't see any errors, try to reinstall the Operating System. try to isolate the problem first before replacing the parts. if reinstalling the OS still makes the computer slow, better call Dell tech support.
Feb 23, 2010 | Dell Inspiron 6000 Notebook
After i run the recovery software my pointing
you have some conflick in your installed system running the recovery console when your system goes to slow in operation is not the best option. this is my idea becuase your laptop experience neccessary operation, you never check first if your Pc is onfected with a virus? if so try to scan your PC with a reliable AV... try use NOD32 and scan your PC. and also reinstall your pointing device
Oct 08, 2009 | Sony VAIO VGP-WKB1 Keyboard
My acer runs very slow
may have a bug, restore your computer to earlier date when you noticed it starting to get slow. Go to system tools under accessories and restore to past date when it worked fine. You may have to reinstall some applications though but your files and photos will be safe.
Aug 11, 2009 | Acer Aspire 4315 Notebook
Computer running slow
Hello.
Usually when a computer get to that point, is time to save your info, format and reinstall the OS, it will be like getting a new computer.
I know this can be a real headache, most the time you have no way to recover some softwares already installed because you don't have the installer and even worse maybe you don't have the Operating System Installer.
However, some responsible vendors make a backup of your system and store it in a separate partition at the moment you buy the PC, it can be named System Backup or something like that.
If you have that file in your hard drive or DVD you can :
Go to - Start - All programs - Accesories - System Tools - Backup and try that posibility.
You can try anything like antispys, antivirus etc but i have never found a way to make a computer in that conditions get fast again, only a clean install will give you that.
I'm sorry.
Good luck.
Jul 04, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Computers & Internet Logo
32 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
