Question about Bosch Dryers
How do I clean dryer squirrel cage?
500 series Model # WTMC3321us
    Master:
  • Bosch Master
  • 480 Answers
To remove drum/fan drive motor:
• Remove rear panel & rear air duct. Remove belt from belttensioner. Remove top panel & drum if needed for better access.
• Disconnect terminal connector from motor, then remove two screws from motor mount & one screw holding fan to front shield. Lift rear of motor mount up and slide entire assembly toward rear of dryer.
• While holding motor shaft, not rotor fins, remove fan blade from motor shaft. Remove three screws, then remove fan housing from motor.
• Remove spring clamps by pushing ends of them down and away from motor. Lift motor up from motor mount.
How do I clean dryer squirrel cage? - 25286040-v2c5cnqd455ajgpzo1p2vswz-5-0.jpg
Cage motor is the best blow out with compressed air. Also, by the way, clean the fan housing fHow do I clean dryer squirrel cage? - 25286040-v2c5cnqd455ajgpzo1p2vswz-5-9.jpgfixya.net/uploads/images/25286040-v2c5cnqd455ajgpzo1p2vswz-5-9.jpg" alt="25286040-v2c5cnqd455ajgpzo1p2vswz-5-9.jpg" class="h_mi" />
Dado
Posted on Oct 23, 2015
kachbibi1
  • 979 Answers
SOURCE: maytag performa dryer quit working
Check your breaker first and then the wiring. Check power coming from the timer next. With a load and resistance that you had, you could have tripped one of the breakers.Since you have bypassed the thermal fuse, it probably is the timer switch.
Posted on Jan 28, 2009
garing
  • 998 Answers
SOURCE: how to access dryer motor
take drum out...then it's easy
thumbs up
Posted on Aug 17, 2009
heatman101
  • 43501 Answers
SOURCE: clothes take at least 2 hours to dry. cleaned out
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Posted on Sep 12, 2010
  • 96 Answers
SOURCE: I have model ye226lv.
Your blower wheel is stripped out. Replace
Posted on Mar 29, 2011
dmftrucker
  • 1922 Answers
SOURCE: kenmore 100.85081400 no heat
check the thermal fuse on the blower housing if its open some units wont heat,also check the heating element if heated electrically,or the ignitor on gas fired units,by the number you provided i believe you meant its a 110.85081400 instead of the 100.85081400 (and is electrically heated) you provided which is produced by whirlpool for sears (kenmore) also there is a control board located inside behind the control panel that may be a culprit,but check the first two things i suggested at the top
Posted on Jul 24, 2012
Bosch Nexxt 500-series electric dryer problems - Dryer never finishes complete cycle of drying clothes. When attempting to restart, the display will show 20 (mins) even though I've pushed something di
did you clean the LINT filter? try vacuuming the lint trap area. wet or damp lint can get built up in the lint trap area. it is good to regularly clean the area as it is a Major fire hazard.
Mar 12, 2014 | Bosch Nexxt 500 Dryer
Mouse /debris in in squirrel cage
Usually! There may be other problems too - rodents LOVE to chew up wires! The squirrel cage is on the passenger side, and it is a labor intensive job. depending on your finances, it may be faster - and easier - to let a shop have the headaches!!
Jan 25, 2014 | Infiniti Cars & Trucks
I can't figure out how to reverse the door on my
You need a left sided hinge kit...here is the link to the part from Bosch http://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/us/prodlg.htm?Maktx=wtz1260&eshoptype=A
There is a PDF on their site under "support" and your model number wtmc3321us that shows this on page 8. Hope this helps you! :)
Jun 11, 2012 | Dryers
Fuse out on kenmore electric dryer 90 series
The fuse on most Kenmore series dryers is located on the blower housing where the squirrel cage is that blows the air out of the back of the dryer.
Apr 21, 2012 | Kenmore Dryers
How do I clean a Hawaiian Breeze tower fan?
Unplug fan. Lay the fan face down. Remove the four screws holding the stand to the base. Slide the stand all the way off the cord. Look at bottom of fan and find the small half circle indent just to left of center. There is a screw there, remove it. Go to the hand grip at the top of the back and pry out the two white rubber plugs to reveal two more screws, remove them. Back cover can now slide downward. May take a little squeezing at the center of the grille where internal clip is. Remove two screws at top of squirrel cage. Turn squirrel cage and loosen screw at bottom collar on motor shaft. Tilt the top of the squirrel cage outward slightly and slide upward to remove the squirrel cage. You can slip upper metal bracket off and set aside. Motor is held in by two screws, remove them and flip motor out of the way. There are two screws below where motor sat that hold in base of front grille, remove. Front grille has a series of clips along edges, carefully pry them inward from bottom to top and push grille gently outwards. You can now clean the rear grille, front grille and squirrel cage in warm soapy water and allow to dry. While they are drying, use a vacuum and dust rags to clean interior. When parts are dry, reinstall front grille and reinstall 2 screws. Reinstall motor with two screws. Turn motor shaft so flat notch is pointing up. Recommend to spray a tiny bit of WD-40 or a tiny dab of moly grease on shaft at top of squirrel cage, then replace upper bearing bracket on top shaft. Slide collar end of squirrel cage onto motor shaft and align screw with shaft flat and tighten. Reinstall two screws at bracket at top of squirrel cage. Align back cover just a bit toward bottom, then slide upward and clips will snap into place. Reinstall two screws in hand hold area, then reinstall screw at bottom of cover at half circle notch. You'll need either a magnetic tip screwdriver or a pair of long needle-nosed pliers to get screw in hole before tightening. Feed cord back through base and reinstall 4 screws. It took me about half an hour to do this whole process on each of my two Hawaiian Breeze fans, but they now look brand new and run very quiet.
Aug 05, 2010 | Tower Aloha Breeze Fan
I want to clean the squirl cage fan on my Carrier handler. It's 12 years old and never really been cleaned. What is the best cleaning procedure to maximize its efficiency.
The best way to really clean the squirrel cage is to remove the entire indoor blower motor housing assembly out of the furnace then remove the squirrel cage from the motor shaft and pressure wash the squirrel cage. Make sure you don't use to much water pressure as you might knock off any balancing weights that may be attached to the one or more of the vanes. Make sure the cage is completely dry before you re-install it back on the motor shaft.
Nov 16, 2009 | Kitchen Ranges
The squirl cage on the dryer of my model LSE7806
Howdy,
Absolutely should be positively "locked" to the motor shaft. There should be a set screw in the collar of the squirrel cage mount. Either it is missing of has loosened. Please tighten (or replace) this set screw. Also, it is very IMPORTANT to make sure that if there is a flat machined surface on the motor shaft, that you align the squirrel cage (and set screw) so that the set screw will seat firmly and squarely against this flat surface. This design ensures that once properly aligned and set, that the squirrel cage will follow the motor shaft faithfully. Also, it is recommmended to apply some thread sealant (Locktite) to the threads of the set screw so this will not happen in the future. Vibration can be the cause of this.
Good luck,
J
Oct 20, 2009 | Maytag LSE7806A Top Load Stacked...
Dryer ccontrol wiring issues
The growling vibration is due to the squirrel cage being out of balance,the wiring issue is due to having no lint trap causing lint to build in the bottom of the dryer and catch fire taking the wiring insulation with it, have seen it many times.
If you repair it make sure you get a new lint filter for it..
Sep 20, 2009 | Dryers
Bosch 500 series dryer stuck on pause mode
things I would try:
remove the power from the dryer and let sit for a while. Plug back in when you feel it is time.
If that does not reset, I would take the cover of the board to see if the button is not stuck. (remove the top 1st, the the cover of the control board will come out)
Jun 05, 2009 | Bosch Nexxt WTMC3321US Electric Dryer
Dryers Logo
133 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
