Question about Air Tools & Compressors
Air compressor porter cable c2002 type 7 do not stop and the safety valve turned on.
  • 44 Answers
Check youre pressure switch
Posted on Nov 20, 2014
SOURCE: Extra fitting on my Porter Cable?
The porter cable compressor is equipped with a pressure relief valve. Mine has a ring attached to it. When you pull out on the valve, it releases all the pressure stored in the tank. Try pushing that valve back in, or if faulty replace it.
Posted on Jun 07, 2009
brewerstool
  • 141 Answers
SOURCE: I have a Porter Cable
I believe you have a head valve or piston ring problem. The parts you replace are suppose to leak. It is a safety feature that doesn't allow the motor to burn up before the pump warms up. Kind of like a soft start feature. If you look on the breakdown part number 107 Kit Valve Plate is what you need to inspect. Sounds like your valve plate is either worn or damaged. If you go into the pump you will have to get part 103 also which is a gasket kit. Or you can try to salvage the old gaskets.
If the valve plate is ok you will need to inspect the rings that go around the pistons. Some times you will get one that gets brittle and breaks off scarring the cylinder. Look for these two things, I am pretty sure one of them is the problem with your compressor.
Posted on Sep 08, 2009
SOURCE: my porter cable c2002 150 psi gal compressor the
According to Porter-Cable (Delta) themselves, they had lots of bad regulators on these compressors. I'm waiting for one myself. Same issue
Posted on Dec 20, 2010
H2_Brad
  • 425 Answers
SOURCE: I have a porter cable c2002 type 4 compressor with
It is a simple drain valve with NPT (pipe) thread. Most likely either 1/8" or 1/4" NPT threads. Any drain valve with the same thread size should work fine. You may also find one at an auto parts store as they are used on automotive radiators too.
Posted on Jul 16, 2011
hunter19_46m
  • 7482 Answers
SOURCE: I just took my Porter Cable C2002 compressor out
Hi alchids...
You only need to adjust your regulator normally one time...that is the first time you use it to set it to the pressure you want.
Try to rotate the regulator knob clockwise, that is the way you adjust the amount of air pressure you will want.
If the gauge still does not move try changing the gauge, it may be faulty.
Please take time to rate me thumbs up
Posted on Sep 10, 2011
Porter cable 6 gal pressure switch. safety valve blows when tank filling
Depending on the pressure in the tank when the safety valve releases,the problem is likely your pressure switch. If the pressure is at or above 160 psi when it blows, then the problem is the switch.If the pressure is lower, then it is likely a faulty safety valve. There are about 8 versions of this machine. check on dewalt service net for the correct part. you may need to check ebay if the part is nla thru dewalt.
Jul 06, 2014 | Porter Cable C2002 150 Psi 6 Gal...
My check valve hose gets very hot, I saw a question, what is meant by regulated pressure?
  1. The regulated pressure is at the output of the pressure regulator i/e the air pressure being delivered to the air tool or spray gun.
  2. This can be set from just a few PSI up to about 180 PSI (on my Porter Cable unit).
Nov 12, 2013 | Porter Cable C2002 150 Psi 6 Gal...
Why does the safety valve go off before the pressure switch on a porter cable 80 gal air compressor
The maximum pressure on most small compressors is 10 bar or 1000kpa which is about 145 psi in the old language most safety valves are set to 150 psi. I suggest you get some one to reduce the pressure switch setting. Running a compressor at elevated pressures does not give you any more air. A reasonable pressure for small compressors is 120 psi
Jan 17, 2013 | Porter Cable C2002-WKR 150 PSI, 6 Gal....
No regulated pressure - check valve hose gets extremely hot- hear leak under the black housing on PC c2002
I have seen the hoses develop a leak right where they exit the metal tube from the pump. The bad part is that you have to pull the pump apart to repair it. Here is a diagram so you can see what you have.
Porter Cable C2002 diagram
Aug 20, 2012 | Porter Cable C2002 150 Psi 6 Gal...
Air has started leaking around the plus/minus knob on the front of my "Porter Cable C2002 150 Psi 6 Gal Compressor." As a result it no longer can fill up with air. What can I do to fix it. Jim
They will let air out if you have turned the valve out too far, try turning it clockwise until it stops then open it by turning the other direction two or three full turns.
Don F
Aug 14, 2011 | Porter Cable C2002 150 Psi 6 Gal...
I have a porter cable c2002 type 4 compressor with a leaky drain valve \r\nmy question is does the 1/4 inch valve come out. there is somekind of strange metal flange with wings that appears crimped around...
Jul 11, 2011 | Porter Cable C2002 150 Psi 6 Gal...
My compressor will not start now when i plug it up. I had it started but the air was leaking from the bleed valve and i turn it to the side and after that it won't start.
sounds like a bad check valve,or a bad bleeder .check your reset button ,usually red ,and reset it.start your compressor again.it should start.be sure you didnt trip your breaker first.air is comming out steady from the bleeder when the compressor stop pumping ,replace your check valve.hope this help!
Apr 17, 2011 | Porter Cable C2002 150 Psi 6 Gal...
How to open drain valve on c2002?
Turn the knob to the left to loosen the tank drain valve.
If the valve will not turn you may need remove and replace the valve. This is just a standard 1/4 female pipe thread and you can purchase a drain valve at most local hardware stores.
Oct 17, 2010 | Porter Cable C2002 150 Psi 6 Gal...
Air Tools & Compressors Logo
52 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
