Question about Whirlpool Gold GI6FARXXQ 25.5 cu. ft. French Door Refrigerator with SpillGuard Glass Shelves, Accu-Chill, Fast Cool, Energy Star Qualified, Tap Touch Controls and External Ice/Water Dispenser: White
Drain plug frozen, how to unfreese it. GI6FARXXQ00
    Sergeant:
    Champion:
  • 253 Answers
I'm not sure which drain plug you mean, but a hair dryer is the safest way to thaw it out. Unless you can unplug it for a day or 2 and let it thaw on it's own [usually not feasible]
Posted on Nov 20, 2014
Boiler,heating and water all working OK but manual override to turn heat on before preset time caused dripping under boiler.Cause and solution?
Did the boiler winter over with the heat turned off and no winterization? If so, then the boiler may have frozen and cracked. Replace it.
If it WAS drained down and winterized, and you just filled it with cold water before firing it, it may be condensation.
May 05, 2017 | Water Water Heaters
How do I drain the Kwikot 600 dual geyser to replace the element
If the design is typical, there should be a drain valve at the bottom. There could be simply a plug that has to be removed for draining.
Jun 27, 2016 | Water Heaters
Im using a salamander heater to thaw out frozen pipes in a double wide, been running for 3 hrs. I still do not have water! Could the underground pipe be frozen,if so how do I fix this?
just keep heating it, if it is frozen underground heating will be the only way once unfrozen let one tap drip a bit to stop it from freezing again
Feb 19, 2015 | Water Heaters
My 6gallons atwwod water heater stop working. the drain plug had 2 wires coming from it. what are they for
"BEWARE OF ELECTRICAL SHOCK HAZARD"!! Wires coming from a drain plug would indicate to me that someone has used a "hot rod" type element in the water heater. They are an aftermarket heating element, that would be plugged in somewhere, (usually inside to a receptacle) that would supply 120 VAC (hydro) to it. BE REAL CAREFUL THAT THOSE WIRES AREN'T LIVE.!! Go in trailer and access rear of water heater if that's where the wires appear to be going and make sure it's not plugged in somewhere. When you removed it, was it similar to a round rod , or just a plug?
Jan 10, 2011 | RTO Atwood Water Heater - 6 Gal LP
I have a GE smartwater reverse osmosis system model number GXRM10GBL02. Water leaks daily from the small hole on the faucet on my counter top. Any idea why water comes out that small hole? Otherwise the...
That is the drain for the reverse osmosis system. You have what is referred to as an AIR GAP faucet. The waste water is pushed up there before it goes to drain just as the drain for a dishwasher does. If water is coming out of the faucet the drain is most likely plugged or the line is kinked causing water to back up and overflow. Check the drain line for kinks and clean out the drain where it attaches to the stand pipe.
RJ
Oct 22, 2010 | General Electric GE SmartWater Household...
Is it feasible to un-screw the drain on the Rheem 50 water heater without it breaking off inside? I want to drain my tank but the drain valve is clogged and I cannot clean it as it is a right angle hose...
POWER OFF ..ya i think its plastic so if it does break you can picj it out with a screw driver and A HACKSAW BLADE. then go buy a brass plug or a new valve.. a ball valve would be nice.. did you know that you shold drain the tank EVERY YEAR ! AND SHUT THE POWER OFF
if i was of help please tell me.. tahks ..jay
Sep 12, 2010 | Rheem Water Heater Drain Valve
I have a keystone camper and apparently the hot water line under the belly is frozen because I get no water flow to the sink...funny thing is at the shower and bathroom sink the faucets are switched the...
YEP. I'M IN THE RV BIZ AND IT'S MORE COMMON THAN U THINK. SOME DEALERS DON'T DO A THOROUGH JOB OF DELIVERY INSPECTIONS. ANYWAY, TAKE A HAIR DRYER AND THAW OUT UR FROZEN WATER LINE. SWITCH AROUND THE OFFENDING WATER LINES, THERE SHOULD BE ENOUGH PIPE TO ACCOMPLISH THIS. ASSUMING THE LOW FLOW IS WHEN UR USING UR PUMP, YOU CAN TURN THE PHILLIPS SCREW ON THE HEAD OF THE PUMP CLOCKWISE TO GIVE IT A LONGER STROKE. CHECK THE SCREEN FILTER FOR ANY DEBRIS, KINKS IN THE LINE BETWEEN THE PUMP AND WATER TANK, MAKE SURE THE AERATOR SCREENS AT THE SINKS AREN'T PLUGGED.
Dec 04, 2009 | RTO Atwood Water Heater - 6 Gal LP
Genesis System 4 water softener drain hose leak
u can buy a can of liquid nitrogen along with a jacket about 12 pounds, wrap jacket around pipe and put extended nozel into jacket and spray, leave for several minutes and it produces a frozen slug in the pipe enabling u to change part
Aug 07, 2009 | Water Heaters
How to remove the water filter in Noritz
it's just a cup screen,, when you take off the cap screw you pull it out claen i and put it back,, it is on the cold side only right before the unit connection
Jun 22, 2009 | Noritz 6.9 Gallon Residential Direct Vent...
Whirlpool Gold GI6FARXXQ 25.5 cu. ft. French Door Refrigerator with SpillGuard Glass Shelves, Accu-Chill, Fast Cool, Energy Star Qualified, Tap Touch Controls and External Ice/Water Dispenser: White Logo
Top Whirlpool Water Heaters Experts
Donni Steen
80stech
jdthefixer
Are you a Whirlpool Water Heater Expert? Answer questions, earn points and help others
