Question about Carlon Home Products Clamp On Slide Dimmer Switch, White
How do i get codes and button for model RC8800R and also a manual
How do I change the batteries in my Carlon RC8800R doorbell
Do you need to replace the batteries in the chime button or the receiver? To change the batteries on the doorbell (chime button) for most Carlon models, you need a ballpoint pen first to remove the chime button from the back. Press the pen point in the small round hole at the bottom of the button. Then gently push in on the tab. Finally rotate the chime button cover up and away from the back cover. Next take the ballpoint pen or a small screwdriver and place it in the slot below the top battery. Lift the battery up. Repeat this with the second battery. Then place the replacement CR2032 batteries into the battery compartment one at a time with the positive side up.
For the most of the wireless receivers, press the center of the brass tubes and lift those free to replace the 4 D cell batteries (2 behind each tube). A few models have a more obvious battery cover for a set of 4 AA cell batteries.
Many Carlon wireless chime manuals are available here: http://www.lamson-home.com/WirelessChimes.php . The direct link to the manual listed for the RC8800R is http://www.lamson-home.com/ProductSupport/WirelessChimes/RC3304_4300IM_3.06_v2.pdf .
I hope this helps.
Oct 09, 2016 | Carlon Home Security
CL error code
The CL code means that the "Control Lockout" function has been activated. This prevents the buttons from functioning. To deactivate it (re-enabling the buttons), hold down the power button for five seconds. See the manual for more info:
http://www.searspartsdirect.com/partsdirect/user-manuals/9962/758154080-Kenmore-Parts-HUMIDIFIER-manual?pathRender=fromManualTabPage
Jan 13, 2014 | Kenmore Humidifiers
Carlon RC8800R how to set chime for westminster crime
The Carlon RC8800R door chime, quicks chiming usally within two days of mounting the base unit interior wall. If I take down and re-arrange the 4-D size batteries in sometimes starts chiming again. Is the base unit just a "lemon"?
Nov 29, 2011 | Carlon Wireless Doorbell system with...
My wife asked me to set the time on her watch. She no longer has a manual. Can you help? It is a polar CE0537 Polar Electro and has two side buttons but no button in front. Thank you.
There is a link to download any Polar manual in PDF form in my tips and tricks page.
Are you sure there is no button in front? Polar watches are all activated for exercise recording by a front button. And if it is an A5 as the request and picture show there is definitely a front button.
On the back of the unit, near the upper portion of the backing will be the model number it will be a letter/ number code like A5, M32, etc... The CE0537 is a different coding than the model itself. You will need the model number for the correct manual.
Apr 25, 2011 | Polar A5 Wrist Watch
The speed ometer wont register speed pulled sensor cleaned but still wont read speed and after it warms up to temp the engine service light comes on. And when you let of the throttle it dies like you...
The engine service light coming on indicates that a trouble code has been entered. The trouble codes assist in locating the problem. On some models, (I am not sure about yours because I don't have a service manual on your specific model), you can hold the speedo reset button in while turning on the ignition switch. Once the ignition is switched on, release the button and the first code will come up. By pushing the button again, you can toggle through the various trouble codes. Warning...holding the reset button for longer than 5 seconds will erase the trouble code that is being viewed at that time, so do not hold the button any longer than it takes to toggle between trouble codes. Unfortunately, you will need to reference a service manual for your specific year and model in order to understand what the trouble codes are referring to. Hope this helps.
Oct 19, 2010 | 2003 Harley Davidson FLSTF Fat boy
Cant find privacy codes
We have been unable for some time to locate an online manual for the T250. Here is a link to the closest model the T289 http://www.motorola.com/mdirect/manuals/T289_User_Manual.pdf
On Page 13 you'll find the following instructions:
1. With radio on, press Menu button twice. The
current Code (small number) will flash.
2. Use Scroll buttons to select a new code.
3. Press Push-To-Talk button to set new code selection.
NOTE: Some early TalkAbout models did not offer privacy codes. You would be able to tell by looking at the screen, there would be no number in the upper right.
Best regards.
Mar 18, 2010 | Motorola Talkabout FRS 250 (14 Channels)...
RCA 36" model f36650
If you have your manual, the manual may have the error codes in them, otherwise you can search online for the error codes or post the model number here so that we can help you find the correct manual or list of codes, but yes the lights are an error code.
Let me know if you need any further help
Mar 28, 2008 | Televison & Video
User manual for a Bellsouth answering machine model 1188
Found my manual!
To set the time, press and hold the time/code button for 2 seconds. You will hear "TO SET CODE PRESS TIME AND CODE BUTTON."
Release the time/code button.
Press the 2 way/m button once. You will hear "SET DAY AND TIME, SUNDAY"
Press the << or >> button until you hear the correct day.
Press the time/code button once. You will hear "TWELVE"
Press the << or >> button until you hear the correct hour.
Press the time/code button once. You will hear "OH".
Press the << or >> button until you hear the correct minutes.
Press the time/code button once. You will hear "PM".
Press the << or >> button if you need to change to AM.
Press the time/code button once and you will hear the complete time and day setting.
To record an outgoing message, press and hold the ogm button. Release the ogm button and start to record after you hear "PLEASE RECORD AFTER THE TONE" followed by a beep tone. When finished, press the ogm button.
Make sure you put a battery in the answering machine so you don't lose these settings if the power goes out!
Nov 11, 2007 | Lands Phones
Carlon Home Products Clamp On Slide Dimmer Switch, White Logo
Top Carlon Home Products Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a Carlon Home Products Electrical Supply Expert? Answer questions, earn points and help others
