Question about Dewalt DW744 Factory Reconditioned Heavy Duty 10" Portable Table Saw
When I lower the blade on my table it sticks and then drops?
    New Friend:
    Problem Solver:
  • 6 Answers
I have an old Craftsman table saw that had this problem. I read the owners manual for your saw and it suggests cleaning and lubricating the height adjustment screw threads with grease. I found that grease is not a good option with all that sawdust blowing around so after cleaning the threads thoroughly I lubricated them with Dri-Coat. It comes in a spray can and does not attract the sawdust like grease would. This should take care of your problem. Let me know if you need a source for the Dri-Coat spray.
Posted on Nov 28, 2014
Testimonial: "Hi thank you for your response. I don't have a owners manual. Do you have a link to were I might find one or see one online, so I can see exactly what the adjustment screw is? Many thanks Mark Ps. could give me a link for the Dri-Coat spray."
  • Bud Gehring
    Bud Gehring Nov 28, 2014
    Try this link for the Dewalt DW744 owners manual. You can print it from there or download it to your device. Here is a link for the Dricoat although it should be available at stores such as Ace hardware, Lowes or Home Depot. Made by Bostik it may also be known as blade coat. Great for applying to your saw blades too.http://www.leevalley.com/US/Wood/page.as...
  • Bud Gehring
    Dewalt DW744 owners manualhttp://powertool.manualsonline.com/manua...
Raising and lowering blade almost impossible. How do I repair it
the blade is raised and lowered via a screw (long one) that you turn with a handle as with any mechanical item that moves , keeping it clean and lubricated is critical , I use candle wax on all my saws (not bee's wax) , as sawdust doesn't stick to it as much as a petroleum oil would cause, and it never mars my wood panels or stains it with a drip mark
Oct 29, 2015 | Saws
How to raise and lower saw blade
You raise and lower the table plate, NOT the blade. There is a knob to lossen and tighen the tension on the table plate and you can adjust the blade height by lowering the plate and vice versa.
Jun 20, 2011 | Dewalt DW364 7 - 1/4'' Heavy Duty circular...
I cannot easily raise/lower my blade on my Craftsman 10 inch table. I've cleaned out the say thouroughly and nothing appears to be obstructing mechanism to raise/lower the blade, but yet, it takes two...
mine did the same and i sprayed WD-40 on the assemblys or large screws and keep working it until free. but, check things over because some had a lock so the blade wont move after the hieght is set.
Dec 19, 2010 | Craftsman 10" Table Saw
I'm a wife with a do-it-yourself knack. I recently purchased a Ryobi 10 in. BTS211 table saw. I find the manual complicated as far as how to actually use the device. Can you recommend where I can get...
I am a retired contractor.
I have a shop with a 10" table saw.
And I have opinions about safe operation.
For safety, turn saw off when making adjustments.
1) Raise blade:
There is a handle you turn to raise the blade.
If you are cutting 1/2" plywood, then set your blade at 3/4" or a bit more.
Keep blade low and away from hands.
Keep hands high and away from blade.
For 1-1/2" thick 2x4, I usually set the saw at 1" and run the board through, and then flip the board over and run it through again, taking 2 passes to make really thick cuts.
2) Blade angle
There is a second handle you turn to set blade at an angle up to 45 degrees
Angle cannot be set if saw blade is fully raised >> lower blade to half way or less and experiment.
Angle cuts are difficult if wood is not perfectly flat and square, or too long or too short (boy is that helpful ... but cutting angles takes some experimentation)
3) Table Guide
You stand behind power saw to operate
The saw table guide is on left side of blade and clamps across the table
The guide markings show inches >>> these are usually approximate
To set guide for accuracy, measure distance from blade to saw guide, and then clamp guide down.
4) Push sticks push sticks push sticks and other safety stuff
Let me emphasize safety first last and always
A table saw will chop your fingers off in a blink
On the plus side, I hear it doesn't hurt. But OMG.
There is a very strong human instinct to reach in with your hand when working on stuff
Train your mind >> if the saw is running, do not lean or reach into the saw
If a board is stuck >>> turn off the saw and wait for full stop
If you wear baggy clothes of a loose shirt, the saw will grab you and pull you in too fast for you to react
Keep your clothes tight and your arms bare
Always use push sticks or push boards::
Notice the saw blade is set low
Two push sticks are used to assist when cutting short board > one stick holds down the board ahead of blade, the other stick is pushing board through saw.
Keep your hands away from the blade no matter what.
The person stands behind and to the side of the board being cut.
The cut wood is supported by a catch table (in this case there are rollers)
Where to stand
Obviously you stand behind the saw to cut wood, and sometimes with long pieces, you can move in front and pull them through, and sometimes with large plywood you stand kinda back and to the side.
Why not stand directly behind a saw? Because saws throw stuff back.
When 'ripping' a board lengthwise as shown in photo above, if the saw catches the board just right, it will throw it backwards like a spear.
If a board 'binds' the saw causing saw blade to stop, then turn off saw, back up the board, and cut again.
Crosscut guide
The saw comes with a T-shaped guide that fits into a groove.
This is a 'push stick' >>> you use it to cross cut a board, and it lets you stand to the side of the saw blade so things wont flip back on you
When using the cross cut guide, remove the table guide that clamps across the saw, or push the table guide WAY back so pieces don't get caught in a bind and the blade flips up the piece and hits you in the face
Remember, the saw throws everything backwards
The saw is strong and fast, and you are best when traveling slow and without rush around your strong friend.
Oct 15, 2010 | Garden
Raising and lowering the blade is really tight.
what I do is turn it over and using compressed air blow out as much of the dust as you can and then find a dry silicone type lubricant to thoroughly spray the threads and the slide portion of the saw. let dry and then move blade up and down a few times, you might have to repeat this but it works.
May 23, 2010 | Dewalt DW744X 10" Portable Table Saw
MAKITA #2703 table saw 10'' to rise and lower blade it
i would say the table is twisted then, strip it down first and if you need to "bend!" it back so it works
Mar 27, 2010 | Makita 2703 10" Table Saw, Electric Brake
I need to know how to aling the the out feet table heighth to that of the blade heighth. In moving, the out feet table is higher than the blade on a Delta wood jointer 37-196.
I assume you want to know how to get it adjusted just right, not how to move the outfeed table up and down. The easiest way I have found is to lay a metal ruler on edge on the outfeed table so that it extends over the blades. Slowly turn the blade forward by hand while you lower the outfeed table. Do that until the blade snags the metal ruler. Then raise the table until the blades just stop snagging the straight-edge.
Mar 13, 2010 | Delta Masonry Tools
Blade Height
Basic saw safety dictates that the blade should barely clear the thickness of the material being sawed. This has saved my fingers more than once, Also, make sure you use a push stick for thin rips. They are a lot easier to replace than fingers, and are easily made from scrap stuff. As for the blade diameter, you want to use a 10" blade, but on occasion a smaller blade can be used, just be sure the arbor doesn't rub against the bottom of the table. Dado blades for 10" saws are usually only about 8" in diameter.
Aug 27, 2008 | Dewalt DW744S 10" Portable Table Saw with...
Dewalt DW744 Factory Reconditioned Heavy Duty 10" Portable Table Saw Logo
117 people viewed this question
Top Dewalt Saws Experts
JOHN LAPIER
ken skalski
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
