Question about Sanyo Televison & Video
No picture , power on - Sanyo Televison & Video
  • Sanyo Master
  • 3,320 Answers
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Posted on Nov 17, 2014
Fix led to with dark picture?
problem in the picture power board
take it in and have it fixed
May 23, 2016 | Televison & Video
No picture or sound
Looks like a power supply issue the only solution to fix this up is to get it repaired.
Goodluck..
May 03, 2008 | Toshiba 32HFX72 32" TV
Picture dimmed. can see the picture and in menu increased the backlight to max but did not go back to normal. checked eco settings and did factory reset. still very dim but can see the picture.
Yah kindly follow this tip. After loosing the back cover when the tv power cord is removed from power socket, check for bulged or defect power capacitors in both the primary & secondary side of the power pack if found any kindly replace it with the actual or equivalent value as this electrolytic capacitor defects is much common for Samsung power packs
Apr 04, 2016 | Samsung UN46EH5300 - 46" LED-backlit LCD...
My 10" digital not working it comes on but not reponding the icon dont come up its not doing anything please help
hi
try to see if you have a reset hole in the back or sides if not then try to reconect the battary or to empty the battary .
May 17, 2014 | PANDIGITAL 7-Inch Digital Photo Frame with...
Dodigital frames need batteries or electricity?
Some digital picture frames work with batteries, while some work with a power plug, and some have the option to use either method. Running off of battery power can be handy if a power source is not readily available. For a frame that is going to be used 24/7, a power plug is more convenient.
Read more: How Does a Digital Picture Frame Work? ' eHow.com http://www.ehow.com/how-does_4613713_digital-picture-frame-work.html#ixzz2IsRZGCgP
Jan 24, 2013 | Photography
Red light flashes on power switch, but no picture or sound on tv
tv will not power on. red light on switch blinks. power relay clicks, but no picture or sound.
Jul 28, 2009 | Toshiba DVD Recorder AND Series2 TiVo...
Power but no picture
I doubt it is the picture tube...there are three of them.. a red. a green, and a blue. Would suspect something on the power/deflection board
Jul 05, 2009 | Hitachi 57F500 57" Rear Projection...
Mitsubishi CS-31303 will not power on.
I have Mitsubishi TV CS-31303. It has transient issues. At turn on, it shows horizontal fringes for some time along with picture, then single horizontal line only and then after some time finges at the 1/3rd bottom and then clear full picture. After some more time the clear picture turns into horizontal fringes at the bottom 3rd of the picture and picture rolls and then again the picture is very clear. Some one said that there is an issue in the signal PCB. Where is it and what componets are at fault. I do have service manual which shows circuit diagrams.
Oct 28, 2008 | Televison & Video
Powers up no picture but shows picture on power down
Try unplugging the three convergence plug wire clips on the SSM board and then try to power up your set, let me know what happens.
Jul 25, 2008 | Philips 60P8341 60" Rear Projection...
Televison & Video Logo
37 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
