Question about Dryers
Whirpool duet sport electric dryer, works fine however when its on any heat setting other than extra low it starts to make a grinding noise. It only happens when its hot. Any ideas what it might be?
    Genius:
  • 2,494 Answers
Check if there is a bearing gone behind the back cover.
Posted on Nov 16, 2014
  • 67 Answers
SOURCE: Whirlpool Duet Dryer is scorching clothes
there is a sensor in the exhaust line in the dryer, near the motor. this tells the heating element to shut off when it gets to a certain temp, either during reg cycle or if the exhaust gets clogged, it is meant as a safety measure, but it sounds like yours is bad so the heating element never shuts off. it is not an expensive part and easy to replace
Posted on Oct 28, 2008
lenwest
  • 150 Answers
SOURCE: Whirlpool duet electric dryer - drum turns; no heat
Turn off the breaker and check the heating element.
for more help go to live chat.
hope this helps
len west
Posted on Jan 30, 2009
lhendrix04
  • 11 Answers
SOURCE: Kenmore electric dryer won't start
DOOR SWITCH
Posted on Apr 20, 2009
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Duet Dryer ( gew9200lw1): no heat
If your dryer runs, but does NOT heat, the following link explains how to troubleshoot an ELECTRIC dryer with a no heat problem:
http://www.fixya.com/support/r3576548-dryer_runs_but_does_not_heat
First, begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
NOTE: If the wires at the terminal block are not color coded, the outer two wires (left and right) are the hot leads. The center conductor is neutral or ground.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer may exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the dryer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum.
The Heating Element is located inside a heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
If either the TCO or Hi-Limit Thermostat are determined to be bad, replace BOTH components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace.
Replacement parts (if required) can be found at the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average cost of these components varies, so shop and compare. The first three websites I listed have helpful exploded view parts diagrams that can help you locate and properly identify the parts you need. The heating components are usually listed under the "Bulkhead" section.
NOTE: In many cases the problem is NOT the heating element. The heating element has protection devices that are designed to regulate the heat temperatures. If the dryer overheats the Thermal Cut-Out (TCO) typically will blow BEFORE the heating element. The replacement kit is much cheaper than purchasing a new heating element that may or may not be the problem.
Read through the information I provided and, if you have any questions, please post back and let me know. I hope you find this information is helpful.
Posted on Feb 25, 2010
heatman101
  • 43501 Answers
SOURCE: whirlpool duet GEW9250PW1 electric dryer squeals
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Posted on Apr 06, 2010
Testimonial: "Thanks, so now how do I get the extended warranty plan to pay for it. They will not send someone out for squeaks and squeals. "
My duet whirpool electric dryer keeps stoping before my clothes are dry
Make sure you are not using a timed drying setting. Use one of the pre programmed functions on the dial. These settings are meant to use a sensor and stop when the clothes are dry. If the problem continues on one of these settings, there is likely a problem with the sensor or your heating element
Sep 15, 2014 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Duet sport electric dryer won't heat or spin, minute counter counts down
You will need to replace the "thermal fuse" located on the back of the dryer. Here is the part to order.
Nov 22, 2012 | Dryers
I have a whirpool duet dryer the clothes are not getting dried
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 25, 2011 | Whirlpool Dryers
Whirlpool dryer duet sport MOD WED8300SW error message
I have a whirlpool duet sport electric dryer with an error code of F 26.
Mar 02, 2010 | Dryers
Whirlpool Duet Sport Gas Dryer - Works fine but makes loud noise
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
yriur
Nov 24, 2008 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Open Questions:
Dryers Logo
Top Dryers Experts
