I have a polk audio pswi225 wireless sub that kept cutting out. Now it's not working at all. Not sure if it's the sub or the wireless contrl controller not making a good connection to the sub. Any suggestions? Thx in advance.
  • 3,320 Answers
Sounds like the power supply has died in the sub. You can get the PS replaced.
Posted on Nov 17, 2014
  • 124 Answers
SOURCE: Velodyne sub woofer: Series S Model: VA08BVX10
The volume control pot can be replaced.
Any good quality audio shop or electronics repair shop should be able to fix this.
Posted on Nov 21, 2009
Grubhead
  • 5391 Answers
SOURCE: Polk Audio PSW10 electrical board smoking
I should just replace the parts that were burning, it will cost a lot less.
Posted on Jan 17, 2010
  • 40 Answers
SOURCE: Optimum set up for Polk Audio PSW 10?
Run 2 RCA cables from the two Purple connections on your Receiver (Labled "PRE OUT SUBWOOFER") to the Red and White connectors on the back of your Sub (it does not matter which Purple connecter you plug into either the Red and White)
Set the volume control on the Sub to about 75%, and keep the power switch in the "ON AUTO" position. To set the Low Pass value, look at the back of one of the front speakers in your setup, and note its frequency range (will look something like 100Hz - 17kHz). Set the Low Pass at a value slightly higher than the low value on the back of your surround speakers.
To set the phase switch, stand in the middle of the room with some music on (something with some bass, but not over the top bass) and have someone switch between 0 Deg and 180 Deg. Listen for which setting sounds "Louder and Fuller". This is the one you want. You will need to do this each time you move the Sub, as its position may change its phase in relation to the rest of your system.
Good Luck!
Posted on Mar 26, 2010
dunnbiker
  • 8546 Answers
SOURCE: Polk Audio DSW Pro 500
Is this NEW? Or did it just fail spontaneously after working for awhile?
Is this just a remote control issue or is the sub dead, too?
From the manual...
No sound coming from subwoofer.
If hookup is "SUB OUT" to LFE, check and make sure your receiver is set to Subwoofer=YES. If hookup is via speaker wire, check that the polarity of the wires is correct.
Subwoofer has no power.
Is the AC MAIN switch on? Check outlet; check fuse after unplugging the subwoofer. The fuse is located under the power cord
receptacle. Fuse type and rating is found on the back panel.
Remote control doesn't work.
Remove the plastic tab to activate the remote control's battery or try replacing the battery. Ensure the IR sensor is not blocked.
If it's a new problem with a previously working remote...
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12954406270641
It describes a way to possibly fix your remote or at least prove it works or doesn't.
Find new or replacement remotes:
http://remotes.com/remotes/servlet/rs?a=Display&contents=home&uuid=A12992635562861
or eBay: search for "(model) remotes", check the 'include description' box. Usually cheaper than the vendors.
Posted on Mar 06, 2011
dunnbiker
  • 8546 Answers
SOURCE: Polk Audio PSW300 What is the
IAW the manual...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Denon-AVR-791-Receivers-manual/id/23693ag505/t/2/
Page 5
Posted on Apr 18, 2011
Have jvc rx-2020v receiver with mono rca out for sub and trying to hook it up with polk audio rm 1000 w sub woofer with +/- terminals for both left ane right channels plus blue terminal(?). How to?
Your Polk Audio subwoofer is a passive sub and your JVC mono output is for connection to a powered sub. If the JVC does not have an amplified output for a passive sub, you'll either need to get an amplified sub, a different receiver, or buy a dedicated mono subwoofer amplifier.
Oct 14, 2016 | JVC Audio Players & Recorders
NEED REPLACEMENT NON OEM REPLACEMENT WILL WORK WITH POLK AUDIO WIRELESS SUBWOOFER PSWi225
sq nearest expert radioinstaller I'm sure he will know the answer and have the replacement part you need
Feb 08, 2015 | Polk Audio Audio Players & Recorders
What could be the issue with my sub woofer power?
Many of these SUB amps ended up with Capacitor failures in the Power supply section . Find someone who works on amps or TVs to have a look see.
May 26, 2014 | Polk Audio Polk DSW PRO 550WI Subwoofer
I'm looking for the transmitter for the Polk Audio PSWi225 wireless subwoofer
i have the transmiter and no sub.Got it in a box of left over parts from ultimate electronics when they went out of buisiness in arizona
Aug 17, 2013 | Polk Audio PSWi225 Subwoofer Speaker
I bought a PSWi-8M wireless powered sub woofer from Ultimate Electronics and did not get the transmitter. They are out of business and I can't return it. I don't really need wireless. Is there a way to...
Unfortunately you need the transmitter. i would contact Polk and see if they sell this part separately or start scouring the internet. someone might have blown their sub but the transmitter would still work.
Apr 13, 2011 | Audio Players & Recorders
I have polk amp that is powering 2 12' subs but itis flashing up with low amp/short light with a little buzz noise?
you must check your wiring from head unit back to subs even take subs out of box to make sure no wires are lose 99.9 of the time a wire has come lose which can be bad if your bridging sups as it changes ohms with 1 or 2 subs hope that helps oh and check volts from you batt and check volts at fuse spots and after fuse to make sure your geting at least 12 to 14 volts cheers i just had a ***** of a prob my subs worked but **** bass found out head unit sub out craped out
Oct 16, 2009 | Polk Audio C5001 Car Audio Amplifier
Cuts out at higher volume
Your amp might now have enough power to push the subs or you need to get a better amp kit that will deliver the power the amp needs to operate at a high spl lvl
Mar 04, 2009 | Car Audio & Video
Polk Audio PSW 350 sub has no power
Hi, Just call the parts line at Polk Audio. They should have the fuse. You can also ask for technical if you're not sure of the problem. Here's the number for Polk: 800-377-7655 Good luck to you.
Dec 30, 2008 | Polk Audio PSW350 Subwoofer
97 people viewed this question
 Grubhead
Grubhead
