Question about Garden
I have an ariens 34 inch zero turn mower with the 13.5 hp the wheels won't move while the mower isn't running. Is there some kind of switch or lever that disengage the wheels to be able to move without starting it?
  • 1,169 Answers
Yes there are two dump valves levers. One each transaxle. Location depends the model. Here is an example from a 915157.
I have an ariens 34 inch zero turn mower with the - 25285986-rtbziddx1k5gnehtweo0otnv-4-0.png
Posted on Nov 16, 2014
5 Suggested Answers
SOURCE: I just installed mulch kit on my Ariens 34
i'm wanting to install a mulch kit too but it seems diffecult. hoew do you access under the mowing deck to install everything?
Posted on Sep 14, 2009
  • 13 Answers
SOURCE: ferris zero mower;eng.dies when releasing brake or control levers
Check seat SW.
Posted on Sep 29, 2009
Testimonial: "Thanks, I've had problems w/that sw. before,I'am going to run an ohms test on it. That tells me where to start."
braintrust
  • 62 Answers
SOURCE: after replacing the belt, new pulleys, and bolts,
sounds like the linkage to your blades, check your lever, to make sure its working right may need some grease, it may be sticking and not fully engaging, or doing its job when its supposed to
Posted on Oct 27, 2009
SOURCE: Mower wont start.
I have a 927 series rider and just put a new battery,and spark plug.Has spark and still wont start. What else can I try?
Posted on May 30, 2010
How do I get back wheels to turn when not running
most have a release lever you must pull to disconnect the hydrostatics . LOOK for it .
May 03, 2016 | Ariens 34 In. Zoom Series Riding Mower
It will not go forward it is only 1 year old and yes it starts my husband past away and I don't know what I am doing wrong
After the engine starts you must put the mower into gear so that it moves. Look for the gear shift lever or whatever.
Aug 02, 2015 | Ariens Zoom 42 In 165 HP Briggs Stratton...
I have an ariens ex rider zeros turn. The mower
check for water in gas bad safty switch slow govenor responce clean bowl on carb and blow air through jet
Sep 07, 2014 | Garden
Ariens Zoom 34 will not move forward or back
suspect a damaged belt or tensioner spring for the drive belt... these units have no servicable trans-axles. or did you just remove both rear wheels ???
Nov 27, 2013 | Ariens Zoom 34" (Stamped Deck) Zero Turn...
My Ariens 34" zero turn's
there is a switch under the hand brake that you can by pass this is not a good idea but it works e-mail me when you get it whitejeff74@yahoo.com
Jul 19, 2011 | Garden
Not sure, but i think the electronic clutch is not engaging when i push the control levers forward or backwards. the engine and the mower deck both run, but the mower will not move
The electric clutch is to power the blades/mower deck. There is a belt that drives the hydrostatic pumps to power the wheels. Make sure the Parking brake is OFF. Could be a belt, spring, idler pulley.
Nov 19, 2009 | Ariens 34 In. Zoom Series Riding Mower
My 1999 Ariens EZR 1742 will not move. Cranks and
if both belts are present are they both moving? Could be tensioner froze up and it is not applying tension. mine had and i had to remove and free it up.
Sep 26, 2009 | Ariens 34 In. Zoom Series Riding Mower
Garden Logo
53 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
