Question about Miele CVA 4066 Stainless Steel
What do I do with fit the brew unit on a miele cva 4066
The unit is saying fit the brew unit
3 Suggested Answers
SOURCE: Miele CVA 4075 brew unit locked
Turn your machine off. Close the door. Depress <clear>, holding it down, press <on/off> then let go of both. Then press <clear> 3 times. On 3rd time, hold it until Service menu appears. Select <brew unit> then press left arrow to turn from <off> to <on>. Then press right arrow by <select> This will turn your brew unit drive to the correct position and you should be able to get your brew unit in/out and your waste container back in. Make sure to turn your machine off/on again to get out of Service Menu. I have a picture of how the wire needs to be inserted to get that back on. It's definitely not intuitive, but send another note with your email address and I can send the pics.
Posted on Jun 03, 2010
  • 128 Answers
SOURCE: I have a three month old Miele CVA 4066. I have
your brew unit is clogged. It will need to be removed and cleaned every 24 hours as per the owners manual. There is a yellow laminated card in the box with the accessories that shows step by step how to perform the 24 hour maintenance. To prolong the life of the brew unit, make sure the coffee grind size lever is in the middle or to the right of center, rather than the left (fine) side. Also, you only want to use dry beans, preferably espresso beans. Oily beans like french roast will clog that brew unit up very quickly.
Posted on Feb 24, 2011
When i turn on my delonghi magnifica pronto on its says insert brewing unit but its already in plus it makes a really loud noise when i turn it on
Sounds like the brewing unit, or infuser, has not been properly seated into its holder. Are you sure that the two red retainer fittings are in their snapped out positions? See page 16 of your owner's manual.
If the infuser has not been properly seated it could cause a loud noise when the servo drive tries to raise the unit into its brewing position.
Sep 04, 2014 | DeLonghi Coffee Makers & Espresso Machines
A black piece fell out of my brew unit while cleaning it and I don't know where it goes or how to put it back in. Help!
I assume you mean a 5cm by 5cm squarish piece of black plastic. If so this is the part of coffee chute. When looking at coffee machine from the front it goes on left hand side of the brew unit about half way up. You slide it on below the start of the chute on the brew unit and essentially it extends the chute. It can be installed upside down. If it's fitted correctly if it looks like a 'W' when the brew unit is viewed from left hand side. If fitted incorrectly it looks like an 'M'.
Aug 30, 2013 | Miele CVA4070 Coffee Maker
I have a Saeco Incanto S-class sirius machine. Message displayed, "Brew Group Blocked", so I purchased a new Brew Group Unit, when I installed it, got the same message. when turned on, I can...
Brew group blocked is normally displayed when there is no water flowing through the brew unit. Remove the brew unit and use a small screwdriver(make sure machine is off and cooled), then gently lift up on cross section fitting on white plastic valve inside the machine, if water flows out it works, now we will plug in machine keep brew unit out and turn it on and press fitting in again, if water flows and pump kicks in and water flows out from valve and not under machine you are good, The coffee grind might be too fine and needs to be adjusted to coarser.
Jun 28, 2011 | Saeco Incanto Sirius Fully Automatic...
No coffeer comes out of the coffee spouts, maybe the steel filters are dirty, how can I cean them?
Before the instructions on how to clean the filters, Check the grinder to make sure is set properly.
It might be set too fine
Cleaning the brew unit filters
Wipe away any coffee residues from the steel filter in the funnel of the
brew unit with a sponge.
The chrome filter to the left of the funnel can be removed for thorough
cleaning. Check and clean the chrome filter regularly.
^ Remove the brew unit.
^ Fit the enclosed allen wrench (that you got with your machine) to the
connection point (see illustration in your manual) in the brew unit. Turn it
counterclockwise while supporting the chrome filter from below.
^ Remove the chrome filter with the screw.
^ Clean the filter with hot water and dry.
^ Return the chrome filter to the brew unit and secure it by turning the allen
wrench clockwise. Press slightly against the filter to allow threading.
Jan 18, 2011 | Miele Coffee System
My gaggia titanium says it's brew unit is blocked
Try cleaning and relubing the brew unit.
If that fails you require a new main board.
Jan 03, 2010 | Gaggia Titanium Espresso Machine
Machine is stuck in rinse cycle and brewunit
Take the brew unit out again, and try to twist the rotational mechanism so that the little arrows in the front of the axis align. This should allow you to insert the unit.
On insertion, you might also need to push the little handle on the front of the brew unit to allow the coffee trough to fit.
Oct 11, 2009 | Gaggia Titanium Espresso Machine
Saeco Royal Professional capuccino maker brew unit assembly issue
Try this, check brew unit on it you will see a small arrow, this has to be pointing at the letter N, whisch is near the handle. Remove the drain tray and dreg tray, check the rails for the brew unit make sure there is no coffee on it, then slide unit in place.
May 27, 2009 | Saeco Royal Professional Espresso Machine
How to find & clean upper filter -Saeco Incanto Sirius brew gp?
If you are holding the brew unit in your hand with the words "Press" facing you, turn the unit right about 90°, and down 90°. Look above the dregs slide, you will see the filter screen under the red gasket.
Apr 02, 2009 | Saeco Incanto Classic Espresso Machine
Machine states the brew unit is missing when it is fitted
try pushing something which swivel up and down on the right hand side of the brew unit. once done it seems to fit back in properly, it did for me
Jan 04, 2009 | Gaggia Titanium Espresso Machine
Brew unit
Make sure you have brewing unit in start positions, if you have a press on your brewing unit make sure to press it to you hear a tick, then you can fit it in the machine.
Mar 02, 2008 | Saeco 762111651808 Espresso Machine
Miele CVA 4066 Stainless Steel Logo
70 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
Jerry Greenberg
Jerry Greenberg
Michael Galve
Michael Galve
Colin Stickland
Colin Stickland
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
