I have a Goodman model GUN100-4B that is making a clicking sound once the blower kicks in and the unit is running normally. Could this be ignition noise? Sounds like it is malfunctioning. What woul
Does it need a new pilot ignition control module or Ignition Pilot and Flame Sensor Kit?
  • Tom Downs
    Tom Downs Nov 23, 2014
    It was making a loud clicking sound in the ignition area about a week ago. The day after I posted this question, the noise stopped. I suspect that there was a build up on the flame sensor or something that burned off. The unit is running normally and without the noise. I am monitoring the furnace for any new signs of trouble but it has been running perfectly now for the last week. Thank you for your inquiry, I will let you know if the problem comes back.
  • 148 Answers
Where and when it make sound?
Posted on Nov 23, 2014
Testimonial: "One week ago in the ignition area. Problem ceased one day after I submitted this question. Furnace not making the noise anymore! Not sure what happened - maybe there was a buildup on the flame sensor and it burned off? I will take the victory for now. I will let you know if the problem comes back. Thank you for replying to my question. Have a great Thanksgiving. Tom"
Therinnaiguy
  • 1420 Answers
SOURCE: flame sensor
The flame sensor is located in the burner box of this unit. You may have to remove a cover plate to get to it. It will either look like a small probe or small diameter copper pipe (real small).
It will either be close to the pilot or ignitor or aways away where the flame has to travel to it.
A small brush or sand paper can be used to clean it.
If your furnace has more than one burner, while you are inside, clean out the track that allows the flame to travel to each burner. A small can of compressed air works great along with a small wire bruch.
Posted on Oct 16, 2007
Therinnaiguy
  • 1420 Answers
SOURCE: furnace problems
Yes, this a symptom when the heat exchanger has a crack in it. Get someone there today! If there is a crack, you could be exposing yourself to Carbon Monoxide! GET IT CHECKED NOW.
Posted on Nov 17, 2007
SOURCE: Glo-Warm Wall Gas Wall-heater parts...
We had a problem keeping the pilot light to stay on, and this site recommended that it could possibly be the thermocoupler that was causing our problems also. We ordered the thermocouple, put it on,hooked it back up and it worked great! Thank you so much.
ordered thermocouple from www.masterparts.net
Posted on Feb 24, 2009
  • 48 Answers
SOURCE: Pilot light won't ignite on a Rinnai 2000 1
The trick is that it may take a long time for the flammable portion of the gas to reach the pilot light orifice where the flame lives. This happens a lot when the pilot flame has been out for some time. There won't be a clicking sound as YOU are supposed to provide the flame - it's not like a cooking stove with such conveniences, because the pilot light is only an occasional thing to light it's rare to find an ignition source built in. I'd hate to see you spend good money when all you need to apply here is time and a flame.
Posted on Sep 06, 2009
Testimonial: "thanks - much appreciated Mark"
SOURCE: Have two- 6000 glx firplaces,both 4 yrs old.
I realize this is an old question but i've put my answer out here in hopes that someone else looking for the same info might have it available.
Kevin,
In my case I've got a heatilator NB4236I and the same parts you've mentioned. I had also come to the idea that the GFVE14 gas module might be the issue. If you open it up you'll see that its a fairly simple solenoid - you can bench test it by taking it off the unit and simply providing power to the red tab and then simply grounding the chassis. In my case the problem didn't turn out to be the gas module - which is fairly unlikely given how simple it is - but rather a high limit switch that pops open if the heat exceeds the limit switch's non adjustable value.
You can easily test to see if the limit switch is the issue by disconnecting all of the other wires from the brown wires of the GM-6KA and basically just short them together (with the power and gas on - and the unit resealed) if it fires up then its almost assuredly the limit switch which you can simply reset. The fact that the heat limit switch blew though could be an indication of an installation problem and may quickly get into a situation that is not DIY.
I have 0 HVAC experience so definitely not an expert fwiw.
Posted on Nov 04, 2011
I have a coleman 7956c856 direct vent forced air furnace it ignites fine but the blower wont kick on
main fan should come on once furnace has heated up to supply hot air to the house. make sure proper voltage going to the fan. fan relay in board may be shot
Jan 29, 2014 | Goodman GMS90703BXA Heater
I have a goodman furnace with a solid red light. Says normal operation, but ignitor does not light. Unplugged ignitor and still solid light. Could it be the circuit board or something else? Blower
Usually you can visually inspect the igniter, looking for any cracks or breaks in the element. The best way to check it is with a volt meter to see if your getting the 120v to the plug itself, putting your leads in each of the prongs on the plug. If you are not getting the voltage, it's usually the board. Make sure all connections are tight. The heating sequence will be: 1. Inducer motor starts 2. You will hear a click from the board, it telling the igniter to light. It should start to glow. 3. Next click will be the gas valve opening and flames on. 4. Blower motor starts. Hope this helps!
Nov 13, 2012 | Goodman Heating & Cooling
We have a goodman split unit, It was below freezing the other morning and the unit had a squeaking sound when it started up. Now it has warmed back up, the unit is sounding as if it's trying to kick off...
The symptoms seem to be related to the main blower motor and/or it's capacitor. Turn the system off for a couple of minutes and then turn just the fan on while the thermostats heat setting is in the off position. If the lights still dim then replace the motor and capacitor. The clicking noise is the fan relay.
Dec 17, 2010 | Goodman GMS807034ANA Heater
Just installed new Goodman 95% updraft furnace with 3" supply and vent lines going out through wall. Gas valve won't open. Circulation blower runs in manual on, A/C system runs fine. I have used an...
Make sure you have bled your gas lines. If any air is in the lines, it will cause the unit to do exactly what yours is doing. The relay "click" you hear is the gas valve opening, but if there is no gas, it will not ignite. This is common for a new install. I hope this helps or at least points you in the right direction! Good luck!
Sep 27, 2010 | Goodman Heating & Cooling
Burners ignite but then blow backwards w blower
Check your exhaust flue. I think you will find a birds nest or something inside. This causes it to blow back or what they call roll out.
Oct 10, 2009 | Goodman GMS90703BXA Heater
Goodman gmp050-03 heater
Either yourself or a Heating specialist will have to replace the gas valve.. Once installed you will plug unit back in which will reset power board and should work fine
Dec 23, 2008 | Goodman GDS80904BNA Open Flame Heater
My heater is not running no ignition
your polarity wires need to be reversed the main wires coming into the unit are either black going to black white going to white changed the wires around to black going to white and white going to black that should solve your problem
Nov 04, 2008 | Goodman GMS90703BXA Heater
Goodman Model CK60-1C with White Rogers mercury tube thermostat
The contactor on the outside unit is sticking and must be replaced. The inside unit cycles off and the outside continues to run causing the refrigerant lines to freeze up.
Jul 29, 2008 | Goodman CKL60AR60 Air Conditioner
Heating & Cooling Logo
53 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
