Question about Danby DWC518BLS 51 Bottle Built-In Wine Cooler
My Danby model DWC518BLS is not keeping its temperature. what do I have to do?
It is not reaching the temperature that we are programming it do reach.
2 Suggested Answers
  • 4736 Answers
SOURCE: just purchased a Danby dehumidifier
Depending on which mode you have the unit set on, will determine if it shots OFF entirely or the fan continues to run. In the Constant or Continual mode, the compressor will turn OFF, once the humidity extraction level has been reached. But, the fan will continue to operate, in an effort to keep the air circulating, so that if the humidity level rises, the compressor will turn ON and start extracting again.
In Timed Mode (usually 2 hour or 4 hour) , when the compressor turns OFF the fan does too.
Hope this helped you. Please let me know. Thanks.
Posted on Jun 06, 2011
Cooling issues between top and bottom
Check this manual if you don't have it. http://site.us-appliance.com/pdfs/DWC518BLS_owner.pdf Is it red or white section?
Sep 25, 2013 | Danby DWC518BLS 51 Bottle Built-In Wine...
Cant find manual. How do you adjust tempature on this ? Thank you
First make sure that the unit is in Cool mode. (Press the Mode button: the choices are Cool, Dehumidify, Fan and Auto. You will see the mode at the top of the LCD display - Cool to the left and Auto above the temperature display) Then press the + or - buttons (or the up/down arrows on the remote) to reach the temperature that you want the unit to maintain. If you press both the up and down buttons together, the current set temperature will display for about 5 seconds. Then you can set the unit back into the Auto mode so that the mode and fan will switch on as needed.
Danby has the manual for the DPAC7099 on their site: http://www.danby.com/product/DPAC7099/4 . See the Literature tab. The direct link is http://www.danby.ca/cms/uploads/products/en_manual/dpac7099_web.pdf .
I hope this helps.
Aug 02, 2011 | Danby DPAC7099 Air Conditioner
Just purchased a Danby dehumidifier (model # DDR6O11R). I was wondering when the dehumidifier reaches the programmed level of humidity (example: 40%). Is the unit suppose to shut off completely? I believe...
Jun 06, 2011 | Danby Dehumidifier
How do i start the fridge to get it cold and how long does it take? Danby mini fridge
Just plug it in and give it time to run, it could take up to 24 hours to reach the set temperature. Try plugging it in before bed. =)
May 30, 2011 | Refrigerators
How to make the kegerator colder
From the operators Manual page 14:
http://www.manualnguide.com/dl/20835/
Each depression of the up or down arrow will
increase or decrease the temperature
incrementally by 1º (F/C) until the desired setting
is reached. The temperature can be set between
36-46º F (2-8º C).
Danby Phone:
1-800-263-2629
*Note: the display will flash for 5 seconds from
the time the last button was activated before
resuming display of the internal temperature of
the cabinet.
Feb 05, 2010 | Danby DKC646BLS Full Size / Pony Beer Keg...
Model 460/5 can not control the heat
I would have to say that your issue is thermostat related.  The thermostat only send a signal when temperature is reached, not what the current temperature is.  So if it is malfuntioning, the desired temperature will never be reached.  Therefore, not sending a signal to cut the heat, even though it is 350.
Mar 04, 2009 | Farberware T490C 1500 Watts Toaster Oven...
DIPLOMAT FREEZER MODEL NUMBER APP6403 MOTOR RUNNING CONTINUOUSLY NEW THERMOSTAT FITTED STILL THE SAME MOTOR KEEPS RUNNING
This kind of a problem could be caused by;
The system has a leak and is not reaching the shut off temperature of the thermostat.
The compressor is worn out and not pumping gas fast enough to reach shut off temperature.
Dirty condenser not allowing the system to get rid of the heat.
Jul 31, 2008 | Refrigerators
E3 code
Received from Danby customer support:
"The error code of E3 tells us that the unit is not getting the proper water temperature to continue thru the entire cycle. Before starting the dishwasher and attaching the quick connect assembly to the faucet, please make sure that the water from the faucet is warm to the touch; you can then attach the quick connect assembly with hose to the faucet and start the unit. If the water temperature does not reach 120 degrees F the dishwasher will not be able to run thru the entire cycle properly. If this is being done and the same code comes up, we will need a service tech in you area to diagnose the problem for us. For a warranty servicer in your area you can reach us at 800-263-2629 Mon-Thu 8:30-5 or Fri 8:30-4 EST."
Jun 11, 2008 | Danby DDW496W Free-Standing Dishwasher
Non stop compressor?
these units have a condensor cooling fan in the rear it appears that yours may be seized up.
Regards
Advisor
Nov 10, 2007 | Danby DWC283BLS Wine Cooler
Danby DWC518BLS 51 Bottle Built-In Wine Cooler Logo
69 people viewed this question
Top Danby Furniture Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Dennis Boxerman
Are you a Danby Furniture Expert? Answer questions, earn points and help others
