Question about Garden
How can I raise the mower deck on my Troy-Bilt Bronco 13YX78KS011? On the highest setting (5)it mows very short. After mowing only once on setting (3) the pulley has ground a groove on the adjustment
We have only had the mower less than 5 months. Bought from Lowes as a returned mower. We have changed the deck belt at least 2 times.
    New Friend:
  • 95 Answers
I hope you have a warranty.. I did have a mower that I had to removes some shims from between the engine and the frame to keep the belt from being misaligned. but of course that has nothing to do with the deck height.
Posted on Nov 24, 2014
  • 154 Answers
SOURCE: mowing unlevel mower is brand new
check to see if all the mounts are tight.
Posted on Jun 07, 2009
rtpflh
  • 546 Answers
SOURCE: Have a 2006 145 automatic riding mower. Belt keeps
idler or adjustment pulley bearings worn allowing belt to ''run off''as it wobbles.stays on.check spring tension of idler.
Posted on Sep 20, 2009
rtpflh
  • 546 Answers
SOURCE: I have a troy bilt riding mower, 6 years old, 26
many of these units use the starter motor as the generator to re-charge battery. check voltage regulator & wiring.
Posted on Sep 28, 2009
  • 146 Answers
SOURCE: Swisher 60 deck belt breaks after mowing about 15 minutes.
Even though the routing is correct, have you checked that every spindle and idler pulley turns freely? These bearings can freeze up or bind because debris builds up in them. Also, if the bushings on the idler pulleys can wear, causing them to misalign. Keep checking. Also - is the belt snapping clean, or do you see a burnt, worn spot?
Posted on May 28, 2010
Testimonial: "Thank you for your help. The belt is snapping clean. You are correct in your assessment to what the problem might be. We checked all the above and did not correct problem. We put three washers on top of small idler pulley to bring it down and better align routing. Bought heavier belt at auto parts. Believe the bolt head was touching belt where it routed throught to larger idler pulley."
waynepwelker
  • 25 Answers
SOURCE: I have a troy bilt riding mower blades will not engage in the 1 or 2 deck setting
There is a spring attached to a tensioner that probably came unhooked while changing the belt. Higher deck settings push the deck backwards enough to spin the blades, the lower setting need the spring tensioner to take up the slack in the belt.
Posted on Jun 27, 2012
How do I make my Troy Bilt Colt XP zero turn mower mow in reverse
it may have a separate setting with the key. mine after starting you turn the key back one notch and it will let you mow in reverse. hope this helps.
Apr 24, 2016 | Troy Garden
I have a riddeing lawn tractor and on its highest setting cuts grass too short how do i raise the deck to get a taller grass
if you look under lawn mower were the deck attachs you will see the adjustment rods unhook one at a time to adjust ether screw the rod in or out do this on a driveway so you can measure with the tape measure how for you or lifting deck and can match hight on both sides
May 14, 2014 | Yard Machines 13AC762F000 38-Inch 344cc...
Ariens raise deck
the arms to the deck are adjustable or the wheel fittings will be adjustable
indications are that the cutter deck is either down at the front or the back where it should be level
Jan 28, 2018 | Garden
Troy Bilt zero turn Mustang Xp 50" deck height. My
raise the back as high as you like but unless you raise the front as well it will still cut short. If you want it higher and there appears there is no adjustment left you may have to re thread the adjusting screws to shorter dimensions or if it is on levers you may have to drill new holes further up the bars.
Jun 02, 2013 | Garden
Need help on replacing drive/transmission belt on 42" Troy-bilt Bronco. Access under the battery box? Do I need to remove entire mowing deck?
I believe their is a plate between the seat and steering wheel. Unscrew the plate and you will see drive pullies, push in and lock brake, this should supply enough slack for you to reach under the seat remove old belt and install new. It is a real pain.If brake can not be locked you need someone to press it while you do the work. Removing the deck will really not help because you will not be able to reach transmission pulley under seat.
Feb 24, 2011 | Troy Garden
Own a Troy Bilt self-propelled model #12A-466-M011 for a year now. It worked great when first got it. Now it will not clear the grass underneath so cuts off every 15 feet and have to manually clear grass...
I had the same problem with my Troy-Bilt self propelled lawn mower. You have to use the grass catcher if your grass is high. Also, I mowed wet grass and it made my belt slip off the pulley and created a new problem, somowing wet grass is definitely not a good idea.
Aug 01, 2010 | Troy Bilt 5.5hp Self Propelled Mower
I have an early-2000s Troy Bilt Bronco, 42 inch deck, 18hp Briggs Inotek engine, hydrostatic drive. It broke or threw a drive belt (not for the mower deck, but a transmission belt). How to you go about...
While mowing the yard, the mower went dead. I tried to recrank it and it won't crank. The gas pedal goes straight to the floor and doesn't work to crank the mower. I do not know anything about mowers and don't know where the problem could be. Can someone help?
Jun 14, 2010 | Troy Garden
Sep 28, 2009 | Garden
Troy built lawn tractor keeps stalling out while mowing lawn. It starts up again, but mowes for a couple of minutes then stalls out.
Have you checked your air filter..it sounds like it could be dirty and needs replacing..if this dont help..just comment back and i will get it..and i will help you further..Keith
Jul 04, 2009 | Garden
Garden Logo
174 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
