Question about Nespresso D290/C Espresso & Cappuccino Maker
TROUBLESHOOTING MACHINE DOESN'T TURN ON
MACHINE DOESN'T SEEM TO TURN ON TO BEGIN PROCESS. IT IS ABOUT 3 YEARS OLD. NEVER HAD TROUBLE BEFORE NOW. cOST OF REPAIR. hOW TROUBLESHOOT BEFORE SEEKING PROFESSIONAL REPAIR?
  • 1,511 Answers
If the unit fails to turn on, it seems the circuit board has failed. These are sensitive to power surges, or other electrical disturbances. You can have a circuit board replaced, but many times over; the cost is as much or more than a replacement.
Posted on Dec 09, 2014
Just turned machine on after being off and unpugged for a month or so and it is making a noise like a motor is running. any suggestions?
Question on sewing machine motors on vintage machines. - Sewing ...
artisanssquare.com > ... > Sewing Machines
Apr 28, 2010 - 20 posts - ‎4 authors
I've recently acquired 3 vintage machines a Singer 201 and 185 and a New ... When the motor is making some noise, but nothing is moving yet, that .... look - fragile, warped ? something like that anyway - in the first few turns.
How Do I Fix My Sewing Machine: Troubleshooting Your ...
www.craftsy.com > Blog Home > Sewing Blog
Nov 7, 2014 - Well, I've been teaching on Janome machines for about 6 years, and I ... Take the Trouble Out of Sewing Machine Troubleshooting! .... Problem #7: Themachine is trying to sew and making sewing-like sounds, but ..... My Brother sewing machine JX2517 just shut down while I was ... in or close to the motor.
Six Common Sewing Machine Problems Solved ' eBay
www.ebay.com > ... > Sewing Manuals & Instruction
Sewing machines sometimes seem to have a life of their own when it comes to working ... sewing problems can be fixed or prevented just by making sure themachine is... ... If the sewing machine is making uncommon noises, such as grinding or ... Do not use the machine when it is operating this way, and turn off power to ...
Let's Talk Sewing Machine Maintenance! ' LLADYBIRD
lladybird.com/2013/02/13/lets-talk-sewing-machine-maintenanc/
Feb 13, 2013 - At the risk of sounding like a big fat sewing machine snob, it makes me cringe ... I understand that it may not be common knowledge that sewing machinesneed regular ... If the idea of poking around in your machine just sounds too ...... now the tune up turn into oiling the most basic part of your machine, .
Jan 25, 2016 | Sewing Machines
Why does my machine a red wrench & the number 3, what's wrong with it?
Here is the Troubleshooting for the "Red Wrench" problem:
Turn the machine off . After 30 seconds, turn it back on. Try this 2 or 3 times. If the machine does NOT start, contact an authorised service centre.
The manual is available at: http://download.p4c.philips.com/files/h/hd8838_02/hd8838_02_dfu_eng.pdf
Jun 03, 2014 | Saeco Syntia Espresso Machine & Coffee...
Noises
After 15 years of service I imagine it will be hard to get the parts you want to repair it.. Newer machines may not dry as quickly as the older types but they use less power to do so.. Consider a new machine for the sake of the economics of the problem
Jul 26, 2013 | Maytag Neptune MDG5500AW Gas Dryer
When I change back to upright cleaner I can never get the belt to work
Hi Andy, Please forgive me, but I have to say this just in case. Make sure you put the powerhead on the machine, BEFORE you turn the handle to line up the green arrows. If the machine is a few years old, it may be because the belt has stretched, and no longer holds enough tension when dissengaged, and falls off inside. If you have the shampooer attachment, try borrowing the belt from that, and put it on the vacuum powerhead to see if it still happens. If it doesn't, then there's your culprit. I hope this helped. I'll check back to see. Good luck!
Dec 06, 2011 | Kirby G6 Bagged Upright Vacuum
I have an f00 showing on my display. How do I get rid of it?
This F00 code indicating a Drive Motor Tachometer Error. The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes:
- Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
- Check the Drive Motor
- Check the MCU
- Check the Wire Harness
Begin troubleshooting right at the motor. Remove the back panel and unwind the belt from the drum pulley. Now turn the motor pulley (sans belt) by hand. If it doesn't turn smoothly and easily, you have a bad motor.
Hope helps.
Oct 10, 2011 | Washing Machines
There is an f00 showing on the display. How do I get rid of it?
Potential Causes:
- Check the MCU
Hope helps.
I'm in trouble deep-I was trying to fix an old
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 06, 2011 | Toyota SE-06 Mechanical Sewing Machine
Inglis Washing Machine agitator not working right
It appears your motor controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 17, 2009 | Washing Machines
Trouble downloading photoshop 7.0 onto MBP
Unfortunately, Photoshop 7 is not compatible with Intel Macs. You will need to upgrade to a more recent edition (CS/2/3/4).
Jan 16, 2009 | Apple MacBook Pro Laptop Computer with...
Nespresso D290/C Espresso & Cappuccino Maker Logo
161 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
