Question about The First Years Carry-Me-Near 3-in-1 Bassinet
How to assemble
Show instructions on how to put together
Took my machine apart to clean & oil. Now having concern about how to put hook assembly back together. I have a manual but photo doesn't show enough detail!
This video is about removing the items in the bobbin area to clear thread tangles, but the instructions may help you figure out how to put them back together.
30 Removing Tangled Thread from the Hook Race FREE
Jan 26, 2016 | Sewing Machines
Instruction how to put nania beway 123 car seat together
The two parts hanging down on the middle bottom of the back piece should snap into the slots on the base. Push down until you hear it click.
Jan 02, 2015 | Nania Baby Gear
My model 2250 shuttle assembly is not put together correctly
http://www.singerco.com/support/instruction-manuals/search put in the model number then download the manual to look at how it goes together.
Aug 17, 2014 | Sewing Machines
Assembly instructions for dw7350 mobile base
You are correct...the base is not pre-assembled as stated in the instructions. However it is a very easy task. The four base parts slot together in a fairly obvious way. The bolts to use are actually packaged separately and marked as "Bolts for Base". There are four bolts in total. One bolt goes in each corner of the base assembly. I put my bolts through from the bottom with the nuts and lockwashers on top. I did this to minimize the ground clearance although now that it is assembled it probably wasn't necessary. Once the four base pieces are together you can follow the instructions as printed. BTW, when bolting the four upright channels to the base, two of them use the same bolts as the ones holding one end of the "U"-shaped wheel supports. The instructions didn't mention this. It is also fairly obvious. In the end, no problems putting this extremely sturdy stand together. I'm glad I bought this to go along with my planer!
Feb 26, 2013 | Dewalt DW7350 Portable Planer Stand
How to put a step side bed floor frame rails together.
Most bed frames you buy come with assembly instructions. Assembly is usually very simple. Usually most of the frame is put together and all you have to do is link two parts in the middle of the front and back of the frame.
KWP2000
Feb 19, 2013 | Cars & Trucks
My smart living steam mop I bought at a home show came with no instructions. I don't know how to put it together or use it. Help, please.
Google in the web for the brand name and you should have an option for an instruction manual. That's just what I had to do for a hand held Dirt Devil Vacuum I just purchased and had no instructions with it. I then printed out the whole manual.
Apr 02, 2011 | Vacuums
Ihave pulled my baracuda apart and have no instructions on how to put it back together.
Below is a copy of the users manual for these pool cleaners from the Zodiac website. It has detailed instructions and illustrations that will show you how to put the cleaner back together.
http://www.baracuda.com/resources/manuals/TL-2050.pdf
Jan 11, 2011 | Zodiac Baracuda G3 Automatic In Ground...
The First Years Carry-Me-Near 3-in-1 Bassinet Logo
82 people viewed this question
Top The First Years Baby Gear Experts
Alan Matzke
Alan Matzke
Dorel UK
Dorel UK
Tom Chichester
Are you a The First Years Baby Gear Expert? Answer questions, earn points and help others
