Question about Kitchen Appliances - Others
How do I get ACM 25 AE-B 230/50/1 info to do service?
    Top Expert:
  • 1,144 Answers
Amana microwave/convection combo
most shops will charge you 60 to 80 bucks (they get it upfront) just to look at it to see what's wrong , me id do a bit of research to see what a replacement would cost , then using that info make a informed decision on how much to spend on repairing it , you could use the 75/25 plan if it costs more than 75% of new to fix it , then id buy a new one
what helps is that its a counter top model , they are easier to replace , as your not tied to a exact size as one would be in a built in model
Feb 09, 2016 | Amana Microwave Ovens
Tip
Activate the Faunhofer IIS MP3 Professional Codec remove Advanced
The WMP Bundled MP3 codec is the L3CODECA.ACM encoder "Fraunhofer Advanced MPEG" codec has limitations on available bit-rates andkeeps the sampling rate at below 22,050Khz it is licensed by Microsoft and ACM (Audio Compression Manager) is also by Microsoft
To improve the bitrates and sample rates available to you install and activate the Professional Fraunhofer ACM codec this is called L3CODECP.ACM, use the included TWEAK to remove the Advanced version and enable the Professional version after you have installed it.
The another version of the Fraunhofer MP3 codec is L3CODECX.ACM, and is a decode version ONLY and can be seen in the drivers.desc in the registry this can't be used as an ACM for re-encoding in VirtualDub and other such programs. This is also included in the zip file HERE
If you want to remove the MP3 decoder only L3CODECX.ACM I suggest that you use Codec Sniper be carefull only DELETE press once keep your sound ON if it says HEADSHOT it has been removed....
Check with Sherlock Detective to see if the Codec has been removed sucessfully this is also the best way to view all your Audio and Video codecs it will give you version number and manufacture details
  • l3codecx.acm: v1.0.0.64 (included in WMP6.4 decode only)
  • l3codeca.acm v1.9.0.305 (Advanced): Encodes up to 56Kbps
  • l3codecp.acm v3.4.0.0 (Professional): Encodes up to 320Kbps. (included in WMP10+11)
  • l3codecp.acm (so-called "Radium" version): Encodes up to 320Kbps
If you want to extract this latest L3CODECP.ACM v3.4.0.0 that has unlimited encoding use this little tip its perfectly legal to do this by the way.
Download the wmp11-windowsxp-x86-enu.exe it may require Windows Genuine Activation then save it to the root folder then extact it the Professional Version of the Codec L3CODECP.ACM, will be included in the wmp11.exe extract this and then just copy it to the system32 folder use THIS reg tweak to install it.
on Feb 14, 2010 | Computers & Internet
ACM 25 AE-B 230/50/1 manual Scotchman frimont
I can get it if you still need it let me know
Nov 16, 2014 | Kitchen Appliances - Others
Windows 7 Media Player 12.0.7601.17514 configuration setting are corrupted and remain corrupted after resetting the Media Player to its default settings. How do I completely rebuild the default Media
You may be able to remove then put back WMP from Programs and Features in Control Panel. Click on add/remove features and you should see it there. Uncheck the box and apply. Restart afterwards then check the box and apply. May require another reboot.
Jan 14, 2013 | Microsoft Windows 7 Home Premium 64BIT...
Loud clicking and jamming, changed 40X2831 Media feed ACM clutch CBM and 40X2838 Media (ACM) drive assembly with very little help if any.
Can you provide info as to where the noise is coming from? Is it from the rear, side or front. If you're getting the following error code 201 or 202, you have to replace the fuser.
Apr 30, 2012 | Lexmark E450dn Laser Printer
No soud on video you tube
Copy everything under the dotted line
Paste into a text file. rename the file fix.reg. Double click on the reg file after it is done you need to reboot pc and it should allow for audio on flash again. The reason is that registry keys seem to get messed up sometimes and stuff gets lost. This is a sure fire way to fix it
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Drivers32]
"midimapper"="midimap.dll"
"msacm.imaadpcm"="imaadp32.acm"
"msacm.msadpcm"="msadp32.acm"
"msacm.msg711"="msg711.acm"
"msacm.msgsm610"="msgsm32.acm"
"msacm.trspch"="tssoft32.acm"
"vidc.cvid"="iccvid.dll"
"VIDC.I420"="i420vfw.dll"
"vidc.iv31"="ir32_32.dll"
"vidc.iv32"="ir32_32.dll"
"vidc.iv41"="ir41_32.ax"
"VIDC.IYUV"="iyuv_32.dll"
"vidc.mrle"="msrle32.dll"
"vidc.msvc"="msvidc32.dll"
"VIDC.YVYU"="msyuv.dll"
"wavemapper"="msacm32.drv"
"msacm.msg723"="msg723.acm"
"vidc.M263"="msh263.drv"
"vidc.M261"="msh261.drv"
"msacm.msaudio1"="msaud32.acm"
"msacm.sl_anet"="sl_anet.acm"
"msacm.iac2"="C:\\WINDOWS\\system32\\iac25_32.ax"
"vidc.iv50"="ir50_32.dll"
"wave"="wdmaud.drv"
"midi"="wdmaud.drv"
"mixer"="wdmaud.drv"
"VIDC.WMV3"="wmv9vcm.dll"
"VIDC.VP40"="vp4vfw.dll"
"msacm.voxacm160"="vct3216.acm"
"MSVideo"="vfwwdm32.dll"
"MSVideo8"="VfWWDM32.dll"
"wave1"="wdmaud.drv"
"midi1"="wdmaud.drv"
"mixer1"="wdmaud.drv"
"aux"="wdmaud.drv"
"vidc.VP70"="vp7vfw.dll"
"vidc.X264"="x264vfw.dll"
"VIDC.FPS1"="frapsvid.dll"
Nov 30, 2010 | Computers & Internet
GE Monigram Ref, main food comparment stuck at 25 degrees
is your damper door between the freezer and refrige compartments opening and closing as you adjust the temp settings,they can become stuck open by ice build up,defrost the damper door and see if it closes then
Jan 16, 2010 | Refrigerators
25 year old Canon AE-1 Program SLR camera mirror suddenly stuck up. I can catch the edge and gently pull it away, but it returns back to the stuck up position. I have already rewound most of the film back...
I wonder about answering posts that are a year old but here goes. The Canon AE-1 Program is a solid working classic but unfortunately Canon won't repair them anymore at least not in m y country anyway. However there are many individual repair people still bringing these cameras back from retirement to full service. Check with a local camera club or cruise e-Bay I've seen auctions selling service for these cameras in the US for as little as $79.95.
Sep 13, 2009 | Canon EOS-AE-1 35mm SLR Camera
USB charge point location
YOu need to purchase and install the ACM (audio connectivity module).
If you're in the US I know where to get the ACM. I have the instructions for the ACM install if you're interested. First you will have to spend money on the
ACM - about 300 dollars....
Feb 16, 2009 | 2002 Jaguar X-Type
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
