Question about Lands Phones
Phone number digits
Have trouble / saving / entering ALL the digits ie 13 off Australia do I need to prefix with 00 my BT phone is a BT8500
  • CRABPOTPETE
    CRABPOTPETE Nov 17, 2014
    To update on this issue. My sister lives in Australia and I live in the UK. The BT8500 will allow me to store 12 digits only when the required number of digits is 13. This includes the pre code from the UK as 00, Maybe one has to use the + sign instead but the phone does not have this option on the entry pad. ??
  • 274 Answers
SOURCE: System Directory
I assume you have the manual. I found it very difficult to follow, very poor. While "on hook" enter the number you want to call. Press "store" or "enter". Enter the name referring to the graphics chart on pages 7 & 8. It is set up for Alpha characters and it depends on which software is installed on your phone. Example: If you want the letter "A" you press the number 2 one time. If you want the number "2", you have press "2" seven times to display the number 2. Use the toggle key to move to the next letter or number you want to enter. When you have finished press "Store". It may take awhile but that's how its done. Not a very good system for the average consumer in my opinion. But that's how its done. I was unable to upload the manual. Here's the link if you don't have it: http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Business-Home-Systems/System-Phones/Digital-Hybrid-IP-PBX-Phones/model.KX-T7630
Posted on Sep 15, 2007
  • 4 Answers
SOURCE: how do i set the time setting for panasonic kxt7456 black digital super hybrid system anyone has the manual? or set of instructions?
ok, the link isn't working properly, so I'll try to explain:
step 1 press "program" button, then **1234
step 2 enter 000
press next (or spkr phn button) for date
press next (or spkr phn button) for time
press fwd/dnd button
press fwd/dnd button again
press sel (or auto answer/mute button) to change am/pm
press store (or auto dial/store)
press end (or hold button)
press spkr phn button or pick up hand set and hang up to leave programming mode.
Posted on Jan 29, 2008
SOURCE: Programing Speed dial on Walker W1000 Clarity Phones
I solved my problem by trial and error!
Steps to program speed dial on the Walker/Clarity Model W-1000 Touch Tone Sound Amplifier desk set phone w/large number pad.
1. Choose phone number to program including the (#1) digit for a long distance direct dial if
needed.
Write chosen number(s) on a scratch pad as a guide for numbers. Identify numbers with the
names or contact description (ie."Mom's Cell Phone.")
2. Remove hand set receiver from phone.
3. Press "memory set" button ONCE on the phone located uder the receiver on the desk set.
4. Enter phone number chosen,including area codes and long distance prefixes if needed!
5. Locate the speed dial position button you want for that number...(located adjacent to
tag/pad slot for name and/or phone number to be written after entering.
6. Press the speed dial position button (ONCE). Then replace receiver back in craddle.
7. Try out speed/dial program. Pick up receiver, push speed dial button(position) listen to see if
correct phone number is contacted. Once established as correct; program additional speed dial
numbers: ie family, business, as needed.
8. DO NOT TRY TO PROGRAM THE NATIONAL EMERGENCY 911 NUMBER! Keep this in your
own memory!
9. If you make a mistake while entering a phone number: Stop, Hang up phone and start all over
again in the procedure sequence.
10. Remove white "description pad with slots for names or numbers) from underneath clear
plastic cover.(use a paper clip end to lift up plastic cover). Write name/description for that number
on white pad(ie. "Mom's Cell") Use a PENCIL FOR DESCRIPTIONS!!
11. TO SAVE TIME AND INCONVENIENCE TO PERSONS/BUSINESSES OF HAVING TO
ANSWER YOUR CALLS; CHOOSE A AUTOMATED ANSWERING NUMBER (USUALLY A
BUSINESS ANSWERING AUTOMATED SERVICE (IE. LARGE INSTITUTIONAL PHONE
NUMBER THAT HAS A MENU PROMPT usually a AT&T 800 # will have a prompt menu
USE this procedure to see if you program correctly then once you know how; go back and re-
enter all the numbers that you actually want on your speed dial settings.
Posted on Nov 29, 2008
SOURCE: BT PHONE MODEL SYNERGY 3100 DIGITAL CLARITY
http://bt.custhelp.com/cgi-bin/bt.cfg/php/enduser/cci/bt_adp.php?p_sid=KEyO-6Fj&cat_lvl1=1243&cat_lvl2=1899&cat_lvl3=1897&cat_lvl4=1918&p_cv=4.1918&p_cats=1243,1899,1897,1918&p_faqid=11935
this is the manual for synergy 3100
Posted on Aug 11, 2009
SOURCE: My BT Verve 450 digital phone set won't ring out /incoming call
My GE cordless handset won't ring when it's on the base charging but it will when I take it off. I've taken off the battery and disconnect the phone from the wall to try to reset it, but it still doesn't ring.
Posted on Nov 19, 2009
How can I hide my number when making a call
In many countries, you can enter a code before you dial a number and your phone number will be blocked from appearing on the recipient's caller ID. The code varies depending on your country and your service provider, and it is not possible to block in all countries. Enter the prefix, followed immediately by the number you are dialing. For example, if you are in the US and want to call (555)123-4567, you would enter *675551234567.
  • North America - *67 or #31#
  • Albania, Australia, Denmark, Greece, Israel, Italy, Netherlands, Sweden: #31#
  • Argentina, Iceland, Switzerland, South Africa: *31*
  • Germany: *31# or #31#
  • Hong Kong: 133
  • Japan: 184
  • UK and Ireland: 141
  • New Zealand: 0197 (Telecom) or *67 (Vodafone)
  • Australia: 1831 or #31#
  • India: *31# - Must be enabled by network.
  • If your country is not listed, chances are you can use either *67 or #31#. Most GSM mobile networks work with #31#.
You can as well change the settings from your mobile device by turning off your show caller id from the call settings.
Mar 11, 2015 | BT 2100 Corded Phone
BT8500
Yes, there is a model BT8500.
Nov 07, 2014 | Lands Phones
I have just purchased BT8500 Advanced Call Blocker phone how do i return to the set up menu to install caller display that i have just purchased from BT
You should find all the information in this link
http://www.ligo.co.uk/data/manuals/BT%208500%20-%20User%20Manual.pdf
Oct 03, 2014 | Lands Phones
What is code for calling austalia?
the general international call prefix is 00 but that of autralia is different. 0011 is used as it is the international call prefix assifned to australia. the country calling code is 61.so if you want to make a call to australia, you dail 0011+61+assigned area code+ the number. hope this answer your problem
May 09, 2011 | Lands Phones
I need the u.k phone prefix please... I have to make a phone call from italy... please
You need to Dial :-
00 - International Prefix to Call out of Italy
44 - International Code used to Dial in U.K
XX - Local Area Code
YYYYYYYYYY - Number
So, you need to dial :-
1234567891
You need to Dial ;-
00 44 1234 567891
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 10, 2009 | Lands Phones
I lost the instructions that contain the unlock code to enable bluetooth access... I got one of those bluetooth adapters for my computer and i'm trying to pair my computer with my mobile phone. My phone is...
If you want to pair the phone with the PC through BT then all you have to do is to give and number like 00 or 0000 as the code. on the phone and press enter. Then the PC will ask for the code. You should give the same number there too, ie, 00 or 0000, whatever you gave earlier. Then the phone will connect to the PC through BT.No instruction manual is required for this. Once your phone and PC are paired you can set then to connect with out this code being given every time.
Dec 04, 2009 | Computers & Internet
needed.
own memory!
Nov 28, 2008 | Panasonic KX-T7730 Corded Phone
How do I change the time on Avanti 3020 telephone?
For the Avanti 3015 phone you have to
  1. push the feature button
  2. enter the number 82
  3. enter the time as follows
  4. Enter four digits for the current time (00 to 23 for hours and 00 to 59 for minutes).
    Enter two digits for the date (01-31)
    Enter two digits for the month (01-12)
    Enter two digits for the year (00-99)
    - The display shows the digits as you enter them - Press {SAVE}
    - The new time and date are displayed
Sep 28, 2007 | Lands Phones
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
