Question about Kitchen Appliances - Others
ACM 25 AE-B 230/50/1 manual Scotchman frimont
Need manual
  • 100 Answers
I can get it if you still need it let me know
Posted on Jan 14, 2015
Tip
Activate the Faunhofer IIS MP3 Professional Codec remove Advanced
The WMP Bundled MP3 codec is the L3CODECA.ACM encoder "Fraunhofer Advanced MPEG" codec has limitations on available bit-rates andkeeps the sampling rate at below 22,050Khz it is licensed by Microsoft and ACM (Audio Compression Manager) is also by Microsoft
To improve the bitrates and sample rates available to you install and activate the Professional Fraunhofer ACM codec this is called L3CODECP.ACM, use the included TWEAK to remove the Advanced version and enable the Professional version after you have installed it.
The another version of the Fraunhofer MP3 codec is L3CODECX.ACM, and is a decode version ONLY and can be seen in the drivers.desc in the registry this can't be used as an ACM for re-encoding in VirtualDub and other such programs. This is also included in the zip file HERE
If you want to remove the MP3 decoder only L3CODECX.ACM I suggest that you use Codec Sniper be carefull only DELETE press once keep your sound ON if it says HEADSHOT it has been removed....
Check with Sherlock Detective to see if the Codec has been removed sucessfully this is also the best way to view all your Audio and Video codecs it will give you version number and manufacture details
  • l3codecx.acm: v1.0.0.64 (included in WMP6.4 decode only)
  • l3codeca.acm v1.9.0.305 (Advanced): Encodes up to 56Kbps
  • l3codecp.acm v3.4.0.0 (Professional): Encodes up to 320Kbps. (included in WMP10+11)
  • l3codecp.acm (so-called "Radium" version): Encodes up to 320Kbps
If you want to extract this latest L3CODECP.ACM v3.4.0.0 that has unlimited encoding use this little tip its perfectly legal to do this by the way.
Download the wmp11-windowsxp-x86-enu.exe it may require Windows Genuine Activation then save it to the root folder then extact it the Professional Version of the Codec L3CODECP.ACM, will be included in the wmp11.exe extract this and then just copy it to the system32 folder use THIS reg tweak to install it.
on Feb 14, 2010 | Computers & Internet
I need manual for audio centron acm 1406 sound mixer
Got a PDF Manual a audio centron ACM 1406 contact me at carlsgangl@yahoo.com if you want a copy
Dec 21, 2011 | Juicers
No soud on video you tube
Copy everything under the dotted line
Paste into a text file. rename the file fix.reg. Double click on the reg file after it is done you need to reboot pc and it should allow for audio on flash again. The reason is that registry keys seem to get messed up sometimes and stuff gets lost. This is a sure fire way to fix it
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Drivers32]
"midimapper"="midimap.dll"
"msacm.imaadpcm"="imaadp32.acm"
"msacm.msadpcm"="msadp32.acm"
"msacm.msg711"="msg711.acm"
"msacm.msgsm610"="msgsm32.acm"
"msacm.trspch"="tssoft32.acm"
"vidc.cvid"="iccvid.dll"
"VIDC.I420"="i420vfw.dll"
"vidc.iv31"="ir32_32.dll"
"vidc.iv32"="ir32_32.dll"
"vidc.iv41"="ir41_32.ax"
"VIDC.IYUV"="iyuv_32.dll"
"vidc.mrle"="msrle32.dll"
"vidc.msvc"="msvidc32.dll"
"VIDC.YVYU"="msyuv.dll"
"wavemapper"="msacm32.drv"
"msacm.msg723"="msg723.acm"
"vidc.M263"="msh263.drv"
"vidc.M261"="msh261.drv"
"msacm.msaudio1"="msaud32.acm"
"msacm.sl_anet"="sl_anet.acm"
"msacm.iac2"="C:\\WINDOWS\\system32\\iac25_32.ax"
"vidc.iv50"="ir50_32.dll"
"wave"="wdmaud.drv"
"midi"="wdmaud.drv"
"mixer"="wdmaud.drv"
"VIDC.WMV3"="wmv9vcm.dll"
"VIDC.VP40"="vp4vfw.dll"
"msacm.voxacm160"="vct3216.acm"
"MSVideo"="vfwwdm32.dll"
"MSVideo8"="VfWWDM32.dll"
"wave1"="wdmaud.drv"
"midi1"="wdmaud.drv"
"mixer1"="wdmaud.drv"
"aux"="wdmaud.drv"
"vidc.VP70"="vp7vfw.dll"
"vidc.X264"="x264vfw.dll"
"VIDC.FPS1"="frapsvid.dll"
Nov 30, 2010 | Computers & Internet
To get free download of dsp group truespeech audio
Here's the download link:
DSP Group TrueSpeech Audio Codec 1.1.1.5
http://www.codec-download.com/modules.php?name=Downloads&d_op=viewdownloaddetails&lid=505&ttitle=DSP_Group_TrueSpeech_Audio_Codec_1.1.1.5
1. Extract tssoft32.acm into your C:/Windows/System32 folder, rename your old tssoft32.acm to tssoft32OLD.acm and rename the new unzipped file tssoft32[Codec-Download.de].acm to tssoft32.acm .
2. In Control Panel, go to Add Hardware.
3. Click Next and after it searches choose 'Yes, I have already connected
the hardware'. Click Next.
4. Scroll down to the bottom of the 'Installed harware' list and choose
'Add a new hardware device'. Click Next.
5. Choose 'Install the hardware that I manually select from a list
(Advanced)'. Click Next.
6. Choose ' Sound, video and game controllers' from the 'Common hardware
types' list. Click Next.
7. Click on the 'Have Disk' button.
8. Click 'Browse'
9. Navigate to the 'C:/Windows/System32' folder
10. Choose '$winnt$.inf'. Click Ok.
11. Click 'Continue Anyway' if you get a warning box.
12. Select 'DSP Group TrueSpeech™ Audio CODEC from the list. Click Next.
13. Click Next again to install.
14. Restart if necessary.
*This was taken from another site
It wast posted by Faizi
Mar 04, 2010 | Asrock 775i65G Motherboard
I need to set up margens
The manual is $25 and can be found here. CLICK HERE
I hope this helps and good luck!
Feb 02, 2010 | Office Equipment & Supplies
Unknown Phone on Lincoln Navigator
It means your phone is activated somehow. Cellular Phone NOTE: The audio system does not operate when the portable cellular phone is in use because the audio-mute feature will mute the audio system when a call is placed or received. Portable Cellular Phone Features
The portable cellular phone system is available only with the P100i audio unit and has the following features:
  • hands-free operation
  • radio muting while phone is in use
  • radio displays the phone number, signal strength, and call timer
  • radio can be used to dial stored numbers and adjust hands-free operation volume
For more detailed information, refer to the User's Guide.
  • Entering ACM Self-Diagnostic Mode.
  • ACM (Audio Control Module) Self-Diagnostic Mode
    NOTE: To enter the Speaker Walk-Around Test or ACM self-diagnostic mode, the ACM must be turned on and in radio tuner mode (AM/FM).
    ACM self-diagnostic mode can only be entered while in the Speaker Walk-Around Test.
    1. To enter the Speaker Walk-Around Test, press the ACM Preset Buttons 3 and 6 simultaneously.
    1. The Speaker Walk-Around Test stops at each speaker and applies a different tone to each speaker for about 1-2 seconds. Each speaker is tested and displayed on the ACM in the following sequence: RF, LF, LR, RR, SUBWOOFER I, SUBWOOFER II.
    1. The Speaker Walk-Around Test automatically continues and tests:
    • the antenna and displays ANTENNA II, for five seconds.
    • for a speaker short. If a short is present, SPKR SHORT will be displayed.
    • for the CD/DJ. The ACM display will show NO DJ if not present. The Speaker Walk-Around Test will end and the ACM will return to its previous setting.
    1. ACM self-diagnostic mode has five tests available:
    • Preset button 1 = Audio internal/external SELF TEST. If SELF FAIL is displayed, press TUNE > to scroll view the DTCs stored. Refer to the ACM Diagnostic Trouble Codes (DTC) Index. If the system is OK, SELF PASS is displayed.
    • Preset button 2 = View/Clear continuous diagnostic trouble codes (DTCs). NO DTCS is displayed if no DTCs are retrieved. If DTCS FOUND is displayed, press TUNE > button to view the DTCs retrieved. Refer to the ACM DTC Index. To clear all DTCs, press the EJECT button. DTCS CLEAR will be displayed.
    • Preset button 3 = SIGNAL TEST. This test measures the average strength at the current tuner setting.
    • Preset button 4 = Software configuration level. This test queries each radio system controller for the software configuration level. SOFT LEVELS will be displayed upon completion of the query. Press TUNE > to scroll view the software configuration version level.
    Controller Description Radio Display Example Main Main micro software version MAIN ##.##.## CDSP CDSP micro software version CDSP ##.##.## ADSP ADSP micro software version ADSP ##.##.## Auxiliary Auxiliary software version AUX ##.##.## CD/DJ CDDJ software version DJ ##.##.## CD Changer CDR software version CD ##.##.## Tape Deck Tape Deck software version TAP ##.##.## RSC Rear Seat controller software version RCP ##.##.##
    • Preset button 5 = DISPLAY TEST. This test will light all the ACM display segments for five seconds, then turn all segments off. When the test is complete, DISPLAY TEST is displayed on the bezel.
    1. To enter these tests, press the preset button desired while in the Speaker Walk-Around Test. This will abort the Speaker Walk-Around Test and start the selected test.
    1. To exit ACM self-diagnostic mode, turn the ignition switch or ACM OFF.
    1. If the concern remains and the fault is not detected, proceed to Symptom Chart to continue diagnostics.
    the module is under the floor console. Do you have the phone user manual.
    Apr 03, 2009 | 2000 Lincoln Navigator
    USB charge point location
    YOu need to purchase and install the ACM (audio connectivity module).
    If you're in the US I know where to get the ACM. I have the instructions for the ACM install if you're interested. First you will have to spend money on the
    ACM - about 300 dollars....
    Feb 16, 2009 | 2002 Jaguar X-Type
    Manual
    You can just search 'Canon AE-1 manual' on google and a PDF file of the manual will come up. As long as your computer supports PDF files you can open it and print it or just read it!
    Apr 26, 2008 | Canon EOS-AE-1 35mm SLR Camera
    How to install mp3 in a v3i cellular phone?
    On your PC if you go into Start/Settings/Control panel/Sounds and Audio devices, under Hardware tab/Audio codecs, click Properties, you'll see the driver listed as "Fraunhofer IIS MPEG Layer-3 codec (decode only)". This confirms that the wrong driver is installed.
    Something you installed, probably to burn CDs, installed a playback-only version of the driver. The driver is l3codeca.acm, which is replaced by the playback-only version l3codecx.acm.
    You need to edit the Registry:
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Drivers32. Locate the item named msacm.l3acm.
    Its value should be changed from l3codecx.acm to l3codeca.acm.
    Note that you might have to use the full path name thus:
    C:\WINDOWS\system32\l3codeca.acm
    For its name to appear properly in the Audio codecs list.
    If that's not your problem, and you want to tranfer files to and from Mob/PC.
    Go here to learn more:
    http://www.knowyourmobile.com/motorola/motorolarazrv3i/motorolarazrv3iuserguides/167/backing_up_your_motorola_v3i_to_a_pc_by_bluetooth_or_sync.html
    Mar 31, 2008 | Motorola Mobility RAZR V3i Cellular Phone
    Kitchen Appliances - Others Logo
    52 people viewed this question
    Top Kitchen Appliances - Others Experts
    Angel Joseph Jr.
    Angel Joseph Jr.
    Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
