Question about Dryers
Water leaking from behind the condenser
There is what appears to be wet felt on the surface behind the condenser
  • Dryers Master
  • 744 Answers
Hello Paul;
My name is Peter. I am a retired field service appliance technician.
I suspect your question does not belong in the dryer category. A dryer does not have a condenser.
You must be talking about a freezer or refrigerator. I need your model number
Posted on Nov 17, 2014
WHERE IS THE DRAIN FOR MODEL 52CEC309351AA
Find the drain outlet and use a wet vacuum on the drain line to pull gunk clogging the drain line out. You may need to reclean on more periodic basis. Problems with drain line gunk buildup vary with location airborn contaminants. Your water leaking could also be not a drain problem, but an air leakage by the seals in the unit installation. If unit is not sealed properly, warm moist air can leak in past bad or missing seals and come in contact with cool surfaces and condense water out and leak out of unit.
Hope this helps
Oct 21, 2014 | Carrier Heating & Cooling
Why is the drivers foot well filling with water on my 2009 volvo XC60 ?
Try cleaning out the small holes between your rocker panels and the sub-structure. They can be barely perceptible, but if you look carefully under the car, they are actually little channels that direct the water flow out of the car that leaks on during heavy rains. Use a coat hanger or other wire to re-open them and let the water out. If not, the floor will continue to get wet until the rockers rust out. Other causes may be seal leaks behind the glass, or trunk seal leaks especially in sedans.
Aug 30, 2014 | Cars & Trucks
A hard to find water leak on 2005 chevy trailblazer 4.2. i think its the resivoir or a hose but not sure exactly, is there a common leak with this vehichle in that area?
Use a white paper towel and dip it on wet spot, if no color then it is water, probably from A/C accumulator which is normal for all vehicles with A/C, if Pink (dex-cool) or green its antifreeze which could indicate a problem. No towel?, taste it on end of your finger, sweet means coolant no taste means water. Do same thing for wet passenger floor area to determine fluid. If sweet or colored there is a coolant leak from the heater core , if water it would be from some other source unless heater housing broken and rani water leaking down from the heater fan cage.
May 25, 2014 | 2005 Chevrolet Trailblazer Ext
My handler is leaking. The drip pan has a little water in it, I see a slow drip outside during operation. Near the blower water is coming out of one of the air ducts.
Hello, most likely you have a clogged condensate drain or a cracked or leaking condensate pan. First use a wet/dry vac on the outlet of the drain line, this will usually unclog the line. If the line appears to be clean then the pan will have to be replaced.
Sep 27, 2011 | Heating & Cooling
Our A/C unit when running, the drain water isn now backing up and leaking over the side in our basement. we've never had this problem before.
Hello, this usually indicates a clogged condensate line or cracked condensate pan. Try using a wet/dry by attaching one end of it to the otlet of the comdensate line, the suction pressure should dislodge the clog. If the line appears clean the the pan is cracked and will require a technician to come out and fix it.
Sep 06, 2011 | Goodman CKL36AR36 Air Conditioner
Conia 3 HP, 5 yr old air con/ condensation from wall unit
NOW, THE EVAPORATOR COILS NEEDS CLEANNING OR THE DRAIN LINE PLUGGED,OR JUST CLEAN THE FILTER.
Nov 30, 2009 | Heating & Cooling
Water leak near front tyre on ford escort
Double check this by using a small container and catching some of what is dripping...If it is not green then it's your air conditioner condensation escaping as it's supposed to. If green then something important is leaking and you need to look further.
Aug 16, 2009 | 1984 BMW 3 Series
Water leaking into trunk of 2001 Subaru Legacy sedan
check your heater core they tend to leak..
Apr 05, 2009 | 1997 Subaru Legacy
2005 Rodeo
its going to be your heater core leaking. you may want to check the water level on the truck as well but the only thing that can leak there is the heater core.
Aug 11, 2008 | 1997 Isuzu Rodeo
Dryers Logo
69 people viewed this question
Top Dryers Experts
