Question about Samsung Cell Phones
WHAT IS THE VOLTAGE (SAMSUNG S3310 MOTHER BOARD SMALL BATTERY)
    Sergeant:
  • 320 Answers
It's a 460mah LI ION battery 19 Volt (roughly), replacements can be purchased at most cell phone shops and online at amazon, ebay, etc.
Posted on Nov 21, 2014
Bettary voltage is low
If you are getting a CMOS batter voltage low error, there is a small watch like battery on the mother board you can replace.
Dec 20, 2011 | Dell OptiPlex GX620 PC Desktop
Using samsung sch 339 cdma phone, his battery was not working .pl sending me solution
Check the voltage on the battery and if this is low then the battery must be replaced.You can try and swap a similar battery from a working set to confirm before you buy a new one. However if there is voltage then the fault can be with the mother board as it refuses to boot up or even come ON.
Check using a good observation lens/lamp for moisture in board or any chance of dry connection on the power side. if not the board is faulty and must be estimated.
Sep 22, 2011 | Health & Beauty
Nokia n73 mobile Set dead
Check the battery and adaptor voltage. If this is faulty then the battery may not charge . Also check the voltage on the charging pins in the phone. If low then there are issues in the mother board charging circuit.
If the battery is good then it is possible that the mother board is faulty- specially when there is no life on switch on.
Aug 01, 2011 | Nokia Lands Phones
My cmos battery goes discharged in 4 -5 days . after replacing the battery it works for again 4-5 days and again goes bad.. my motherboard is inteldg41ty
Possible that the mother board has a higer current drain on the back up circuit . You can remove the button cell and check on the board/connections around this section. If there is dirt or moisture wash the board after removing power- allowing time for voltage to drop - use petrol and a tooth brush to clean this section. if the fault does not clear then the mother board has to be checked.
Jul 21, 2011 | Samsung SyncMaster 740N 17" LCD Monitor
How to unlock bios of toshiba portege m500
two options
1. look on the mother board for a small round battery about the size of a nickle, remove it, start pc, after start up shut down, replace battery, start up again... or remove battery, let sit for about 30min, replace battery start pc.
2. look for a small red or yellow toggle switch or button on the mother board, (should say "reset bios") push button, restart pc.
i assume this is a lap top so there will be some disassembly of the unit, not to extreme though, usualy the battery and the switch/button are next to one another and located toward the front of the mother board, and if in lap tops the battery or batteries are in a plastic covering wired to the mother board with a small connector, just unplug connector if you cant find the reset button.
hope that helps
Mar 23, 2011 | Toshiba Computers & Internet
Need free unlock games code of samsung s3310
To get free unlock code for games
Search in these sites below.
->www.giveawayoftheday.com/samsung+s3310+games+unlocking+code+for+ s3310/ -
->www.dl4all.com/.../samsung+s3310+games+unlocking+code+midn.html .
Dec 14, 2010 | Cell Phones
Free themes for Samsung S3310
www.software112.com/search.../samsung+s3310+theme.html www.infibeam.com/...Samsung...S3310/P-E-M-Samsung-S3310-Metro.html www.topshareware.com/free-samsung-s3310-themes/. www.giveawayoftheday.com/free+theme+for+samsung+s3310/ - samsung3310.blogspot.com/.../finally-there-are-themes-for-s3310.htm
Sep 16, 2010 | Computers & Internet
Not able to switch on the mothere board. Green led on the board glows but the system is not powering on.
1. Check the mother board user manual 1st. To see how to properly install this mother boar to your PC cabinet or tower.
2. Check to see if you have the power from the power supply correctly connected
3. You may not have the proper watts or power from the power supply to power said mother board.
4. check the mother board battery it may not have proper voltage it should be 3.9 volts or more with a voltage meter check.
usually a 2025 button battery on the board
Feb 02, 2010 | Intel Computers & Internet
Battrey voltage low
The only battery in a desktop is the CMOS battery. This is a small round battery, looks like a watch battery and it is on your motherboard. The battery keeps a small amount of electricity going when your computer is turned off so that the clock and date can be kept current. If you take the cover off of your PC you will see it on the mother board. Write down the numbers on it and you can find another one at Radio Shack.
Dec 24, 2008 | Computers & Internet
Cell Phones Logo
117 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
