My HD Ready TV loses the picture intermittently for 1-2 seconds at a time , it happens about 4 times in an hour.
    Problem Solver:
  • 5 Answers
Check cables and make sure they are not cracked or damaged. Also make sure they are properly secured to the connector on the t.v.
Posted on Nov 16, 2014
My TV was moved and has since had this problem. The standby light is permanently on whether the tv is on or not. When on, it periodically (every half hour or so) goes blank for a couple of seconds and all...
Most possible that the memory board has encountered some loose connection in the connectors or inthe IC mounts.Open and check on all connectors, look for possible dry soldering or loose joints inthe microprocessor section or in the mP section regulator supply.
Use a good solderring iron to solder all such suspected points.
test and repeat once again. Since the fault is intermittent, you will have to keep doing the soldering in the suspected sections and then trying to trial.
If the fault seems to wander, it might be an IC possible the memory,or the crystal in the processor.
Hope you check this out.
Aug 27, 2010 | Samsung LE32R41BD 32 in. HD-Ready LCD...
I lose volume on HD channels with Directv
Reset the Directv box,by unplug it,replug it and hour later to let the last software to update.Replaced the HDMI cable,goto ur tv menu,goto sound functions,go down to reset it back to the factory setting.After this the the sound functions should be stable,and work.Not,than ur Tuner signal board have some kind of intermittion short in the board.Than must replaced the Tuner board to solved this problems.
Apr 16, 2010 | Samsung LNT3242H Television
Intermittent audio loss with 42 inch 2007 Sharp HD( not plasma) TV. Happens 2-4 times/hour for a second or two during most HD programs. It has gotten more frequent over the past month. We have...
Are you running the sound directly from the DirecTV box to the Onkyo reciever? or is it routed through the TV first? Personally if you have it routed through the TV you are losing out on true 5.1 surround. To ge that you need to have the DirecTV box connected via optical or digital output (orange connector) to your Onkyo amplifier. If you need further assistance please email me at tvtek(at)msn.com
Nov 17, 2009 | LG 42PC1DA 42 in. Plasma HDTV
No Picture. Started with picture intermittently
COULD BE GENERAL SERVICING, THIS INCLUDES DRY JOINT..RESOLDERING THE HEATED PLACES, ON BOARD, SECONDLY, IF PICUTRE IS COMING AND GOING OUT CAN BE ALSO A VERTICAL IC PROBLEM, NOT TO REPLACE, RESOLDER THE UNIT AND TRY TO ON, SHOULD SOLVE THE PROBLEM
Oct 14, 2009 | Samsung HPT5054 50 in. HD-Ready Plasma...
My Samsung TV takes up to 2 hours to come on
Replace any swolen capacitor on the power board.
Sep 01, 2009 | Samsung LE40R73BD 40 in. HD-Ready LCD...
DIM PICTURE
Have you replaced the lamp yet?
3 signs the lamp is getting ready to take a dump on you is:
a. Dim Picture.
b. Longer turn on time.
c. Intermittent picture loss.
Any of the above or none can happen before the lamp expires.
Aug 07, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Sharp LC-46SB54U Keeps losing picture intermittantly
i believe your tv is getting overheated, possibly from dust getting onto the electronic components inside. or the inverter board for the lcd panel inside is going bad, alot of times it is the capacitors on the lcd inverter board going bad.
Jun 12, 2009 | Sharp LC46SB54U 46 in. LCD TV
High definition reception
You should have 2 cables going into the Sky HD box not just 1
Oct 31, 2007 | Toshiba 52WM48 52 in. HDTV-Ready...
Televison & Video Logo
Top Televison & Video Experts
