Question about Building Materials
Our Liftmaster 520 LM wireless remote receiver will not open our garage door. It is a commercial setup and the door next to it opens when the receiver button on the adjacent door opens it. I don't think it is a remote problems because the remote lights up fine but when you push the receiver button (it is supposed to open the door) it doesn't. Any suggestions?
    Problem Solver:
  • 5 Answers
You have to program it to the garage you want it to open. There are codes that the remote and garage opener have and they must be insink.
Posted on Nov 16, 2014
4 Suggested Answers
  • 5 Answers
SOURCE: Liftmaster Garage Door Opener Problems...
The problem lies in the RPM sensor, most likely due to the interrupter cup assembly. The interrupter cup assembly is the black cap that runs through the RPM sensor. You may have forgotten to re-attach this piece or it is probably moving too far out when the garage sets in motion. To fix this, remove the cup assembly, unscrew the two screws on the top metal piece with a 1/8 allen wrench, push the metal piece as far in as possible and put the screws back on. This will give more room for the cup assembly to spin and be read by the RPM sensor. Hope this helps!
Posted on Jul 10, 2008
  • 3197 Answers
SOURCE: Liftmaster wireless keypad closes but won't open the door
If you are sure the battery is good you have a bad keypad. The signal strength is so weak it will not penetrate the door.
Posted on Aug 25, 2009
  • 3197 Answers
SOURCE: garage door opens a few inches and stops
On the rear of the motor unit near where all those white wires go you will find the 'up force'. Increase this 1/4 turn and try.
Posted on Dec 07, 2009
Garage door send receive signal
Caution: do not use LED bulbs with garage door openers. They are a possible source of signal interference between the transmitter and receiver on the opener.
Mar 22, 2013 | Sears Craftsman LiftMaster Chamberlain...
My garage door receiver does not have a "learn"
The 900 series remote control only works with door openers having an orange learn button see the liftmaster remote 971 manual 4th one down
Feb 19, 2011 | liftmaster 971 Lm Remote
Intermittent remote trouble
Your wall control is hard wired and doesn't use the receiver portion of the logic board. The remotes do. Your receiver is going bad.
Jan 12, 2010 | Sears Craftsman LiftMaster Chamberlain...
Replaced batteries.changed codes verified not in lock position checked wiring-checked breakers -remotes dont work have 2 different units-one commercial all stopped working on same day -need help
I have the Same Problem...
2 similar but independent 315MHz Craftsman door openers stopped receiving any remote signals at the exact same time. One hour they worked , next hour they didn't, no storms in area.
I know remotes are good because they still open our subdivision gate. the Only way to open door is with wall pad. Verified that they are not on vacation lock. 5 different remotes, 2 different keypads all no longer open door.
I tried resetting codes with learn button but they won't take new programming. Also before when an unlearned remote was used in the area, the learn light would at least flicker (as if it was receiveng a code, but rejecting it) It no longer even does that.
i even cycled the circuit breaker and the vacation lock, no help.
Does anyone know how to fix this?
Oct 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
We are having intermittent problems with our 2 garage doors opening. All three remotes as well as the outside door mounted opener, are having a problem with opening the two different garage doors. This...
sounds like condensation in the receiver window of the garage unit rather than the remotes. Try running a hair dryer over the area where the signal is received to get rid of any moisture and try using the remote from across the road or at the drive entrance.to check your success
There have been a few complaints about this on some of the other forums and the seals arn;t all that good
Please rate our help++++Thanks for using FIXYA
Oct 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Our garage door opener is not opening although I know it is receiving the signal from our remote controls. What should I check?
Try pairing them up agin which may require pressing the button on the opener itself and the button on the remote that usually opens the door.
Oh, before going to all that trouble, check the remote's battery if it's a few years old. If you have more than one remote and all of them don't work, try the process above.
If you have the owners manual, it should explain how to setup the remotes again. If not, you can go online and see if Sears has the manual on the web.
Jul 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
93 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
