Question about Krups Coffee Makers & Espresso Machines
How can I fix My Krups XN2125 Nespresso coffee machine that is not operating?
Model No: XN2125 Both small and large cup led buttons are off. I did a quick power check in the machines electric system with a tester screwdriver and seems OK. With the mains switch on there is power in the pcb board, both led buttons, pump, pressure regulator etc. I wonder if the pcb board is damaged or a fine wire fuse, that I could not find, is off.
2 Suggested Answers
Noggin
  • 944 Answers
SOURCE: Krups Nespresso FNA2 coffe/cappucino machine
First thing to try is a descale. Run the machine normally using it (as if making a cup of both types) a couple of times with a 50/50 mix of white vinegar and water. Leave the machine off but uncleaned overnight. run a couple of cycles with just water, and if there is still a slight vinegar taste then run a cycle with a teaspoon of baking soda in water, then flush with just water again. If this doesn't solve the problem, try again with 75% vinegar. If still not working, there is either a control board problem (may be solveable), or the valve/solenoid that stops/allows the water is sticking, almost certainly solveable by taking that apart and cleaning/lubricating. Definitely solveable by replacement. Let me know what you get after a descale if no luck. Hope this helps :)
Posted on Aug 20, 2007
How to programme it for larger cups of coffee
Press/Hold the large cup button until u reach the desired measure of your coffee... Release it when u think it is enough for your large cup..
Feb 09, 2013 | Nespresso DeLonghi Lattissima Plus...
The small and large cup buttons are alternatly
I had the same problem and was told it needed to be repaired by Nespresso and the cost would be 115 euros.
Jan 07, 2010 | Nespresso Le Cube C185 Espresso Machine &...
When you press the button for a large cup of espresso (Nespresso Essenza) only small amount comes out
You can adjust the fill of coffee by holding the large coffee cup down for as long as you want to fill it. Try holding the button down for 20secs., next cup of coffee should automatically fill for 20 seconds. The small cup that you are currently getting was probably set at the factory. Good luck
Nov 19, 2009 | Nespresso Essenza C100 Espresso...
Coffee not hot enough Is there a way to modify the factory settings to make coffee/milk warmer for the Nespresso Latissima machine?
Before placing first coffee capsule in the machine, run the large espresso cup button into a cup (clear water will come out). This primes the machine and makes for hotter coffee.
Oct 03, 2009 | Nespresso Lattissima 660.R
I lost power and now I get blinking lights on my le Cube 185
I had a similar problem where both Small and Large cup buttons on mine blinked intermittently. I did a reset of the large and small cup flow levels based on the following and it seems to work fine now:
1. Switch off power 2. Press and hold Large cup button 3. Switch on power while still holding down large cup button
See if that solves your problem.
Aug 24, 2009 | Nespresso Essenza C100 Espresso...
My nespresso does not make a full cup any more
Another good solution, though the previous one was good, is that you can factory reset the cup sizes. All you have to do is switch the machine off, and then press and hold the large cup button. After about 10 seconds, keeping your finger on the large cup button, switch the machine on -- then let go of the large cup button after about two more seconds.
Aug 15, 2009 | Nespresso Essenza C100 Espresso...
Water leakage inside
Use less water....
Apr 29, 2009 | Krups Nespresso 554
Aug 20, 2007 | Nespresso C190 Espresso Machine
Coffee Makers & Espresso Machines Logo
145 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
