SOURCE: Admin Password
The master password for the Toshiba e-Studio 45 (using controller gl-1010) is 349845. Use a web browser to open the printer's built-in web access: TopAccess, and click the log-in link on the right hand side to use this password.
SOURCE: My Toshiba e studio 167 is showing a c44 error
the c44 error is an error in the fuser if you know how to take the fuser out check for toner buld up on the thermistors.. the sensors with the thin strip that presses against the hot roller gets toner build up and cant read temp properly.. you could also try turning machine off and then on whilst pressing 1 3 and * buttons together this might reset it temporarily for you.. Good Luck A
SOURCE: TOSHIBA E STUDIO 167 driver for windows vista home
http://copiers.toshiba.com/support/downloads.jsp
Select you OS from the list.
SOURCE: error c44 call for service
C44-Heater
abnormality after abnormality judgment: The temperature of the fuser
roller has exceeded the range of control or does not even reach the
range.
You
can try going into (08) mode by holding 0 and 8 while turning on the
copier. Once the copier starts up key in 400 and press start, input "0"
and press interrupt. Try rebooting the copier, if this doesn't clear
that call for service then you are going to need to get work done on
your fuser.
