Question about LG LFX25960ST Stainless Steel French Door Refrigerator
What caused fuse too fail on mother board
Unit just shut off with no warning
  • LG Master
  • 744 Answers
Hello Patrick;
My name is Peter. I am a retired field service refrigeration technician.
In your owners manual you will see the manufacturer recommends a surge protector. You can purchase individual wall socket surge protectors for $15.00-$20.00.
The slightest change in power supply will do this. Static electricity will knock out control board. Then, you ma have had a bad board.
I have gone on service calls, replaced the control board, only to find out that the board I put in was bad.
I was required to return failed electric boards to the manufacturer for reconditioning. So, if you were to purchase a board it may not be new. It could be reconditioned.
If you ever decide to replace a board yourself; ground yourself by rubbing your hands on steel. Remember static electricity will knock out a board.
Posted on Nov 16, 2014
  • Peter Goodwin
    Peter Goodwin Nov 16, 2014
    Oh, I forget to mention both LG and Samsung are wll known to technicians for this problem.
Proxima dp6150 shuts down unexpectedly
the interface between the mother-board and the power-supply is not work well
Add some solder on the interface , it will increase the contact surface
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, motherboard,
powersupply ... with high quality and competitive price.
Jerry China Lampdeng Limited
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Feb 18, 2014 | InFocus Proxima DP6150 Multimedia...
What does a heat fuse look like
A thermal fuse looks sort of like an old diode with a colored end.
Go search for help on your specific model. Others may have the same problem. Could be an electrical component fail, or the water valve. Neither would burn the board.
See
http://www.fixya.com/support/t1725640-bosch_dishwasher_shut_off_timer_says
Feb 23, 2012 | Bosch Dishwashers
Error code: 2000-0333
hello
error code 2000-0333.
Possible cause Graphic Card Test Failed, Mother Failed, if your Notebook is under Warranty it is better to bring it to Service Warranty Center. or you can repair it by checking the mother board or video card. This problem occurred when your graphic or mother board is failed to start or initiate during start up.
thanks
pls rate
Apr 07, 2011 | Dell Inspiron 1545 Notebook
I have a GE JE1660 Profile Countertop microwave oven and it just quit. No warning, no lights, no response to any button pushed. Fix or replace?"
there is a 20 amp fuse inside the unit ,but requires to gain access.. may luck out and it just blew the fuse... normally they are behind the control panel unplug unit and take screws out to gain access hopefully that will fix you up ...if the fuse is good i would suspect you have a failed control board on the unit.... good luck
Feb 11, 2011 | Microwave Ovens
My microwave just stop running while trying to re heat . how im going to fix it. is their any reset button
in most cases the reason for microwaves shutting down without warning is the fuse. in some cases the fuse will fail at its own fault. to test the fault we would do a tollerence test on the unit. but the best way for you to test it is to replace the ceramic fuse with another of the same value. if the unit works then its a faulty fuse. if the unit blows the fuse then the unit has a fault in the power supply that needs to be repaired by a service tech.
best of luck
Aug 03, 2010 | Microwave Ovens
System was up an running then, Then shut down
It sounds to me like it overheated and something burnt out, but I could be wrong. The main pieces in a desktop computer are: power supply, motherboard, cpu, ram, and video card (which is on the motherboard for lower end systems.)
Each one will need to be properly tested to find out which part(s) is(/are) failing, and the failing part(s) will need to be replaced.
Apr 19, 2010 | HP Compaq Presario SR1110NX PC Desktop
Our heater blows cold air.........
most boards have a small 3 or 5 amp fuse on the board it looks just like a car fuse. do not put in wrong size fuse it can allow damage to the board.
Nov 22, 2008 | Amana PTH153B50AE Air Conditioner
EMachine T3406 wont boot
is there a post beep when the pc is switched on. check the memory if it is a beep beep beep sound , also disconect the hard drive, dvd drive, floppy, and any usb devices and see if it boots up. if that fails it does seem like the mother board, also check the cpu fan has it stoped. also find out the power switch conector on the mother board, from the base unit switch to the mother board. also chech the power connector from the power supply to the mother board , on newer boards there are two that go to the mother board its self , a big one and a very small one .
Jul 05, 2008 | E-Machines eMachines Desktop PC
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
64 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
