Question about Vacuums
Why does the plug get hot when the heater is on
    New Friend:
  • 36 Answers
Sometimes the electric cord isn't made to handle the wattage of your heater....either change the cord or use a heavier extension cord.
Posted on Nov 21, 2014
My Bissell model 1970 won't get hot
If you are talking about the water not getting hot, Your Bissell 1970 is not supposed to get hot. It does not have a heater to heat the water.
Jan 22, 2017 | Bissell Vacuums
Steamer problems
The light is connected to the heater if it is not working but the unit still gets hot the light may be faulty
If the unit does not get hot then there is a problem with the power getting to the heater element.
The fault may be in the switch
Aug 08, 2014 | Eureka 313A Stick Steam Cleaner
My Bissell carpet shampooer will not dispense water or cleaning solution, nor is the "flow indicator" spinning
most of the Bissell carpet cleaners that have the water heating feature stop pumping water at one time or another. Make sure the belt is still on the pump and if it is then the problem is probably in the heater core in the handle. Hard water deposits plug the tiny little water ways inside the heater core. Pull the heater core and take it apart and clean it with a strong scrub brush and I think vinegar works for cleaning I was told. I just use soap and a brush. Then flush all your lines with hot water. The cause is from hard water deposits or leaving the soap in the cleaner after you use it. Both will stop it from pumping water
Apr 29, 2014 | Bissell 1698-1 PowerSteamer ProHeat Plus...
Heater keeps pluging up with recomined cleaning soluions
We're sorry to hear about the heater plugging up when using our formulas. Before storing your machine, we recommend running clean hot tap water through the machine.
You may want to have one of our Authorized Service Centers inspect your machine. Here's a quick link to locating one in your area:
http://www.bissell.com/service-centers/?cid=ccsocial
Mar 18, 2013 | Bissell 1698 PowerSteamer ProHeat Upright...
Hello, I awoke this morning to a room full of acrid smell. The timer controlling an electric radiator was extremely hot,and was also heating up the wall socket. The heat has distorted the plastic case...
I am sorry that no one picked up on this sooner-
I came across it, after reading a response from one of th persons I helped--
Good Question: Who to alert?
By now you have probably called an electrician?-- Or at least stopped using both the receptacle, as well as the heater?- right?
Now-- to fix the problem:
It sounds like some poor connections at both the wall plug/socket end, as well as inside the heater-
First the wall socket:
Is the plug nice and tight, as you plug it in, and as you pull it out?-- If not-- the socket needs to be replaced--
Is the plug end of the cord hot in one spot, but not others?-- If so, there are some broken wires right near the plug end of the wire--- It needs to be replaced, too.
Now-- Inside the heater-- you mention the Thermostat area is real hot-- It sounds like either a loose wire, or a worn set of contacts on the thermostat.. (How old is the unit?)
So-- if you can narrow down the places, and repair-replace defective parts, maybe you can restore the heater to a safe, dependable source of heat-- If not-- It sounds like a recyclers needs to take over, and safely return parts to the environment!
Let us know how it all turned out, OK?
Mack B
Jan 26, 2011 | Vacuums
I have a Bissell ProHeat 2x, and I did something dum. I had some powdered cleaner that said it works with carpet cleaners-well I mixed it in-and the next time I tried to use it, nothing came out. So, I...
Heck yeah, give it a shot. Try running some water through it too- fill it up, heat it just to where it's hot and unplug it, shake it around and dump it out. Repeat. You might have to get a wire or something to go through and get the powder loosened between the boiler and nozzle, but if the stuff will dissolve in hot water then once you get it going a little it'll flow better the longer you keep heating it and putting new water it.
I say I think you should unplug it once it gets mildly hot the first few times because if there is a pile of the powder stuck to the side of the tank you may find that the tank gets very hot there and overheats/fails.
You should be able to clean the solenoid too, hot water is your friend.
lp
Jan 11, 2011 | Bissell Vacuums
My hot water heater won't engage at all.
Sounds like the pilot light is not staying lit, provided you have one. The pilot light is used to keep the gas valve open by way of the thermocouple/switch. When the pilot light goes out the thermocouple cools down and shuts the supply of gas off to the water heater burner. It is not unusual for a thermocouple to go bad at which point it needs to be replaced. The thermocouple is the small rod that sits in or close to the pilot light flame. There is a small copper tube that runs from it up to the gas valve on the outside of the tank. This is where you control the temperature of the water as well as light the pilot light. If you are not experienced in dealing with hot water heater gas supplies, you should get professional help.
Oct 14, 2010 | Vacuums
Bissell power shoot carpet cleaner
It sounds like the heater may be plugged. This is a problem for an experienced technician. The heater is located in the handle and they are prone to plugging at the tubing connections. The heater is heating soap and water solution and this can cause the soap to coagulate and plug the lines. It must be addressed carefully to avoid damaging the heater.
Mar 23, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Prolectrix 3 tier steam
Is the unit spraying ok? If not then the heater may be plugged. Other than that, you should fill the tank with hot tap water, the the heater will only heat it alittle more, you won't really see steam.
Jan 19, 2008 | Bissell 1699 ProHeat Clear View Upright...
Steam cleaner
Most upright steam cleaners like Hoover and Bissell, you put in the hot water, bissell does have a heater, but it only helps get the hot water a alittle hotter. But a model number would help.
Dec 12, 2007 | Vapor PC2200 Ladybug Steam Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
