Question about Vizio E552VL 55" 1080p 120Hz LCD HDTV
I have a VIZIO E552VL TV hooked up to an Over the Air Antenna and want to MANUALY put in channels NOT AUTO SCAN
I recently dropped Satellite TV and put up a Whinguard 100 mile Antenna with a rotor. When ever I rotate the antenna I have to do an auto scan to pick up any stations from that direction. I would like to put stations manually into memory so when I rotate the antenna all I have to do is go to the channel I put in manually.
    Champion:
  • 209 Answers
Not sure if your TV is digital or analog, but I think an analog TV does not have the ability to perform auto scan, so you may be able to manually input the channels. As a kid, my dad installed a rotary antenna, and as it rotated and TV pictures displayed on the screen, dad noted the specific spot on the rotary unit; and every time we turned the set on, we just pointed the arrow on the dial on the unit to where dad noted what the channel number was on the unit, and the antenna turned toward that direction, and the pictured appeared on the screen.
Posted on Nov 25, 2014
SOURCE: Trying to scan channels into my vizio, but no
I called my satellite provider. Problem solved!
Posted on Jul 07, 2009
  • 257 Answers
SOURCE: No digital channels when scanning.
Do you remember to swith between cable and air in the set up manu? It needs to be at air position to have full scanning.
Posted on Aug 18, 2009
dave1645
  • 834 Answers
SOURCE: Vizio l37
you cann not hook an antenna and cable to a splitter together and expect it to work
the only way that will work , if your tv had two tunners Try doing a scan with cable
only on the cable setting
Posted on Nov 03, 2009
electrotech1
  • 1126 Answers
SOURCE: I have a Vizio VW42LF TV that is 2 yrs old.
The TV processor could have some garbage in it do to a small power surge and if you leave your TV unplug for 40MIN., then that will reset it bad to normal, and if tuner still looks snowy and not getting channels, then the tuner, or main TV module needs replaced.
Posted on Dec 19, 2010
SD Tech
  • 14553 Answers
SOURCE: Vizio tv dropped a channel, won't rescan
Try with the remote to direct enter the channel number (with the number buttons and or enter) If set makes it there go into menu for option to manually add it to the set memory.
Not likely a problem with your set.
Posted on Dec 17, 2012
HDMI input works ok. Hooked up external antenna. Did channel scan. It will only scan for analog channels. Has analog raster on screen. It has no information on menu page for digital channel scan.
do you have the air option in the scan menu see
http://tv.manualsonline.com/manuals/mfg/sanyo/dp42841.html
page 9 important fact cable digital gets wiped by air digital channels
You may be able to get around this via a digital hd tv decoder box and then have it on a hdmi input on the TV as a backup to the cable if you can't have both cable digital channels stored and aerial digital channels stored
Oct 09, 2016 | Sanyo DP42841 42" LCD TV 1920x1080,...
Hooked up to antenna did channel scan in air mode not getting any channels. Hooked up a Vizio tv to same antenna line and got all the locals. Maybe something wrong with the Sharp?
Make sure that Sharpe is set to over the air/antenna and not cable. There are more than one scan modes. http://files.sharpusa.com/Downloads/ForHome/HomeEntertainment/LCDTVs/Manuals/tel_man_LC42_46_52D65U.pdf
See page 14 in the link. It is easy to mis-configure the setup to not receive the over the air digital channels. The input must be set to digital and air in setup. The VHF are no longer available.
Hope this helps?
Jan 15, 2016 | Sharp LC-32DA5U 32 in. HDTV-Ready LCD...
Televison station won't scan
If you are receiving a "No Signal" error message, verify that:
  1. All of the cables physically connected to the TV and the input device are secure.
  2. The input device is turned on.
Your TV needs to scan for channels before it can show programming from an antenna, from cable TV when the cable comes directly from the wall (no cable box), or from a cable or satellite box connected to the TV with a coaxial (RF) cable. Do not scan for channels if you have a cable or satellite box connected using AV (Composite), Component, or HDMI cables. The box selects the channel, not the tuner inside your television. If you are not using the "TV" input, press the INPUT button on your remote until the correct input mode is selected.
To perform a channel scan using the coaxial input:
  1. Press the INPUT button on your remote to view your current input source. The TV (coaxial cable) input must be selected. This may appear as "TV," "ANT," or the channel and call letters of a station.
  2. If the TV input is not selected, press INPUT until the TV input mode is selected.
  3. Open the on-screen menu and select TV or Tuner option. (This varies by model.)
  4. Highlight Tuner Mode and select the correct option:
    • Antenna-over-the air signals from an antenna
    • Cable-direct from the wall cable TV, or a cable or satellite box connected to the TV with coaxial cable
  5. Select Auto Search or Auto Channel Scan. (This varies by model.)
  6. When the search reaches 100% complete, exit to the menu.
  7. Check the available channels:
    • Antenna or direct-from-wall cable-Press the Channel Up and Channel Down buttons on your VIZIO TV remote to view the available channels.
    • Cable or satellite box- Will return only one channel. Use the cable or satellite remote's Channel Up and Channel Down buttons.
If this does not resolve the issue, power cycle the TV and then re-run the channel scan:
  1. Turn off the TV.
  2. Unplug the TV from the electrical outlet.
  3. While the TV is unplugged from the wall, press and hold the Power button on the TV for 30 seconds.
  4. Release the power button.
  5. Plug the TV back into the electrical outlet.
  6. Turn on the TV.
Note: There is also an option to reset the TV to the factory default settings. This option is in either the SETUP or SYSTEM section of the on-screen menu. The option may be "Reset all settings", "System Reset," or "Reset & Admin." Consult your TV's user manual for the location and steps for resetting your model.
  1. Remove the coaxial cable from the DTV/TV connector on the back of your television and perform a channel scan to clear the existing channels. See the procedure above. This should not find any channels.
  2. Re-attach the coaxial cable to the DTV/TV connector and perform a new channel scan.
This video shows troubleshooting steps to use when a "No signal" message appears.
Jun 25, 2014 | RCA 46 46LA45RQ LCD TV
32in Vizio getting no channels
You have to go to your menu screen and change the settings from antenna to cable that should take care of it, and should be able to do a auto scan to load channel memory
Mar 26, 2013 | Vizio VX37L Television
How do I set up my tv, for auto scan I thought I needed a digital converter, I just learned that I do not. Do I need an antenna of any kind at all. I am very confused. I really would like to talk with...
If you are trying to program free HD off air you will need a UHHF antenna attached to the ATSC hook up on back of TV then have TV scan for channels available. If you are hooking up a "cable" box or satellite receiver that will just get hooked up with the output of the box going to an appropriate input on your TV. If you are just taking a cable from wall (being used as an antenna) then hook that up to the QAM antenna connection on tv and scan for channels once that is hooked up.
Hope this helps - if not please be more specific on what you are trying to hook up to what input.
Mar 08, 2011 | Televison & Video
Why won't my new Vizio DTV work on an antenna without the digital box?
Do you have the antenna aimed correctly and the correct antenna for the distance between your location and the stations? Check antennaweb.org and tvfool.com for the directions to the stations you should be able to receive. Antennaweb assumes an external antenna and is very conservative in the station list. TVfool gives the stations you should get with various different types of antennas. Tall trees and buildings will block signal strength so consider the environment around you.
With digital signals, if you do not have enough signal strength for a given tuner, the channel will not come in. An amplifier may help you get the signal, particularly if the signal is shared to several devices. Failure of an amplifier or lightning surge protection can stop the signal from reaching the TV. A surge through the antenna can damage the tuner.
A damaged cable can also be a source of a problem. Check the outside portion of the wire as well as the interior wires. Replace any that have damaged insulation or ends.
For this TV, if you have done a channel scan with the TV set to the Input TV/DTV, and the Signal Source set to Antenna. Turn the antenna and then set the Additional Scan to On. (Menu > TV > Channels > Additional Scan.) Then do another channel scan.
If you need a copy of the manual, see: http://www.vizio.com/m220va.html#support .
Jan 22, 2011 | Vizio M220VA 22 in. LCD HDTV
Vizio l37 When I try to scan the channels automatically the TV can find all the ones that comes from the comcast cable (62) but when stars to scan the digital ones freeze make me cancel the process and...
Nov 03, 2009 | Vizio L37 Television
I can't scan DTV channels on my vizio 52''
do you have antenna or cable? if you have antena hook directly to the coax, go to menu, TV, tuner and pick antenna and scan. If you have cable hook directly to your coax repeat the previous step but pick cable instead of antenna. Notice if you have a cable box, you will not need to scan for channel since it will be on channel 3, 4 or any other input you may use.
Jun 20, 2009 | Vizio L32 32 in. LCD HDTV
My LXI TV won't allow me to get any channels above 13 after doing the auto scan for channels. I am using DirectTV.
The only way to fix the problem is to hook your TV to a standard cable hookup and go through the "auto memo" scan process. The auto scan progarm then automatically sets itself to the CATV mode, rather than the standard mode, so channels above 13 can be received after disconnecting and reconnecting to a DirectTV, satellite antenna.
Aug 29, 2008 | Televison & Video
Vizio E552VL 55" 1080p 120Hz LCD HDTV Logo
161 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
