Question about Crane Plumbing Home
Have to flush tollet twlce to get lt to flush properley
When you flush the flrst tlme very slow have toflush second tlme then goesdown normally.
    Director Badge:
    Uploaded 100 video answers.
  • 225 Answers
Here's a video I made on how I fixed that same problem on mine.
Posted on Oct 31, 2015
    Problem Solver:
  • 7 Answers
Hold down the handle for about 2 seconds and you will get a longer flush, but still use less water than 2 flushes.
Posted on Nov 19, 2014
Blown turbo with oil and smoke coming from exhaust, will I have to fit new exhaust?
no just flush out if in sections will be easier and dispose of liquids properley
Mar 13, 2015 | Cars & Trucks
Yellow blinking light . what does it mean
A blinking yellow for this model indicates the TV is too hot, unplug & allow 30-45 min to cool before re-plugging .
OR: lamp not installed or lamp door not closed. there is a lamp door switch that may not be closing, simulating door not closed
LED Indications
The front panel Status LED provides an indication of
the set's operation and the possible cause of a malfunction.
If an abnormal condition is indicated, perform the
Self Diagnostics procedure.
Self Diagnostics
To activate, press the front panel <ACTIVITY> &<CH
??> buttons at the same time and hold for 5 seconds.
The STATUS LED will then flash denoting a two digit
code.
• The number of flashes indicates the value of the
MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2
second.
• The LED then flashes indicating the value of the
(ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is "23", the LED
will flash two times, pause, and then flash three
times.
Table 2-2: LED Indications
Error Codes, descriiptions and the most likely cause of
the error are listed in Table 2-3.
Note: The TV must be in "Shut Down." The LED
will probably be indicating an abnormal
condition. If the TV is switched Off, AC is
removed, or a System Reset is performed, the
code automatically resets to "12" No Error.
See the Error Code Log to retrieve a history of
errors.
Note: Use the front panel buttons, not the remote
control.
Note: If there is no response, the front panel may be
locked by a V-Chip setting. To unlock, press
and hold <ACTIVITY> on the front panel for
8 seconds.
LED Indication Condition
Off Off (standby)
Green Power On
Slow Blink Green Power Off with Timer Set
Fast Blink Green (80 seconds) > Off Power Off (Cooling fan still working, 80 sec)
Red Lamp Failure
Yellow TV Too Hot
Slow Blink Red TV May Require Service
Slow Blink Yellow Lamp Door Open or No Lamp Installed
NORMAL INDICATIONS
ABNORMAL INDICATIONS (For details perform Self Diagnostics Procedure.)
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
My equinox jumps 1500 rpm from second to third could this be the # 3 cello noida it's almost like it slips but only at the shift
Could be a lazy solenoid, or a leaky seal in the apply circuit of that clutch pack. I would try a trans. service first in case it's just a buildup of crud making the shift slow. Do yourself a favor and take it to a shop with a flush machine rather than just changing fluid/filter as the machine will get the torque converter and valve body.
Jun 27, 2014 | 2007 Chevrolet Chevrolet Equinox LT
How do i know if my skywatcher 127 goto is alighning scope properley in daytime
You really can not verify goto alignment without stars. You can use planetarium software and roughly align and check
Dec 15, 2012 | Optics
My element mp3 player is playing music so fast how do i slow it down
Press the << button once or twice until music plays normally. If it plays too slow, press >> button.
Nov 28, 2009 | Element Electronics Zr-Element Digital...
I have a kia sedonna and when i slow down my thermostad goes up which makes the car slow down to almost stopping after i turn the motor of and wait for about 5 mins it starts up and returns to normal
I would first check the belt tension on the one that drives the water pump. Second, I would replace the thermostat if no loose belt is found. I recommend flushing the cooling system before replacing the thermostat to avoid refilling the system with coolant twice.
Oct 25, 2009 | 2006 Kia Sedona
How toflush heater core
take inlet and outlet hoses off(near firewall)and just run water through it,it will go in 1 pipe and out the other unless its blocked which it shouldnt be
Oct 18, 2009 | 2004 Audi A4
Home Logo
206 people viewed this question
Top Crane Plumbing Home Experts
Donni Steen
john h
Tom Chichester
Are you a Crane Plumbing Home Expert? Answer questions, earn points and help others
