How to disconnect the connection that holds the drive by wire.
SOURCE: toyota yaris brakes how do you bleed the brakes on a toyota yaris
have someone pump the pedal and hold it, then you work from the right rear, left rear, right front, left front, while the person pumps and holds several times at each wheel.
SOURCE: Question to Toyota Ed:
Hello, Zman777.
According to the material provided by Toyota, the Denso pedal does not have the alleged acceleration issue.
Also, according to information that has been provided by Toyota, the alleged acceleration issues is being caused by two possibilities;
One is additional placement(s) of floor mats on top of the factory floor mat. The extra mats are not secured, and can move around the driver side footwell, and, in the worst case scenario, move on top of the accelerator pedal, and trap in into the 'applied' position. I myself have experienced this mat/entrapment issue during a road test.
The other possibility is that certain accelerator pedal mechanisms may mechanically stick in a partially depressed position or slowly return to the idle position. Over time, the internal mechanism in the accelerator pedal my become worn. As a result of this wear, combined with certain operating and enviromental conditions, friction in the mechanism may increase and intermittantly result in the accelerator pedal being hard to depress and/or slow to return or, in the worst case, stick in a partially open position, increasing the risk of a crash.
In short, according to what we have been provided, the issue is mechanical, not electrical. The modification that Toyota dealerships are performing rectify this issue, and, this modification has been approved by the NHTSA.
Nowhere has it been found that the vehicles with the alleged acceleration issue have 'accelerated' without warning, as in sitting still, and the car is suddenly going 100 mph. None.
What 'could' happen, if the pedal 'was' sticking, is, in my opinion, an 'Unexpected Non-Deceleration' condition.
If you were going 15 mph, and the alleged issue appeared, when you let off of the gas pedal, the car would continue at 15 mph, and NOT accelerate to 100 mph, as has been falsely mentioned in the media.
Regarding VW, sorry, I cannot comment on VW, or any of their systems, I am not a certified VW mechanic.
I hope that this info helps you out.
