Question about AEG Ovens
Oven switches itself off - AEG Ovens
    Problem Solver:
  • 10 Answers
May be a faulty thermostat. Check model number documentation online under thermostat.
Posted on Nov 16, 2014
Main oven switches itself off
sounds like cooling fan not working. check the fan and a limpet stat that switches it on. without the cooling fan the oven cabinet overheats and a safety cuts out the oven.safety stat could be faulty if no prob with other stuff.
Jul 20, 2010 | Electrolux EOU6330 Electric Double Oven
Oven not workiing
If it is a double oven, then there will not be a plug fitted to it.
It should be hard wired directly into a main 30 amp switch box
If there is no power at all, then it could be a faulty main switch unit, or
the fault could be at oven connector block.
You really need a meter to check for power, both at the switch box and the oven itself.
Another possibility is a fault with the timer unit on the oven itself.
Apr 05, 2010 | Neff U1421 Double circotherm Electric Oven
Faulty programmer - oven switches itself off
Try powering everything off at the main switch, waiting a few mins, switching back on and set the clock. Make sure the oven clock is in manual mode and switch the oven on and see what happens.Let mw know.
Jan 01, 2010 | Stoves 720EF Electric Double Oven
Ge oven turns off by itself, and sometimes gives
F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor F2
Note: Also see fan thermal switches Indicates that oven is over temperature in one of the following modes within either a cooking or clean mode of operation.
· Control senses oven temperature above 650 degrees F with the door circuit in the unlock mode.
· Control senses oven temperature above 935 degrees F with the door in the locked mode.
· Stalled cooling fan or airflow problem. · Look for welded relay contacts. (Heating elements on in off mode).
· Look for open thermal switch in lock motor circuit. Switch is normally closed and will open if area overheats due to fan not operating. Look for cause - fan thermal switch not closing, fan stalled, etc.
· Look for high resistance in the oven temperature sensor circuit due to high contact resistance (poor terminal crimp, deformed terminals, loose connection) or intermittent solder joint on control or intermittent oven temperature sensor.
· Look for electrical noise interference in the oven temperature sensor circuit (Ham radio, cordless phone, etc.).
Nov 11, 2009 | GE Profile JTP18 Electric Single Oven
Oven switches on and off itself while cooking,
The element in the main oven switches on and off as it reaches the correct temp, this is supposed to happen, however, if you mean the oven is going off altogether, then I would suspect that it is overheating, and the safety stat is cutting the oven off.
Check to see if the top cooling fan is working o/k. because if it is not, then this will cause the prob.
Please rate my solution.
Thanks.
Nov 10, 2009 | Hotpoint UY46 Style Line Stainless Steel...
My oven keeps turning itself off
the oven may be trying to protect itself because of a faulty device that says "I'm too hot". As electric clothes dryers have a thermal high temp limit switch to protect them, look for this device (may be 1 inch round with 2 wires connected) and replace it
May 24, 2007 | De Dietrich UMP404 Powerclean Stainless...
Oven switches 'itself' off without the timer
I sorted it it is a simple solution, if you take the top of your oven you should see the problem...it will be big and black..dont spend a ortune getting it sorted i brought the part off ebay for less than a fiver.. just cant remember what it was called..very simple to fix though.  Mike
Dec 19, 2006 | Electrolux EOB6632 Electric Single Oven
Ovens Logo
Top AEG Ovens Experts
ashburton
Sal DeAngelo
Samyfam
Samyfam
Are you an AEG Oven Expert? Answer questions, earn points and help others
