Power red light on but tv not start
Tv not start power led on
    Top Expert:
  • Televison & ... Master
  • 74,198 Answers
Do a reset to this set, and check. If it do not help you, contact any service technician. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Posted on Nov 16, 2014
  • 579 Answers
SOURCE: Hitachi 32LD8700 - TV won't turn on although has power
The general problem with LCD type TV's is that the power supply fails. They are very sophisticated designs that are difficult to troubleshoot and generally best to just replace the module, but sometimes there is visible damage in some of the electrolytic capacitors (visibly bulged) and high voltage rated parts can be substituted.
Hope Ya Fix It
Posted on Feb 10, 2008
SOURCE: My Polaroid TV TDA-03211C will not turn on. It has
power supply problem bad capacitors the red light is power to check cap inside
Posted on Mar 30, 2010
cschindle725
  • 67 Answers
SOURCE: The TV will not power on anymore. It tries but
What you have wrong with your tv is in the power supply board, it is a very common problem which you can fix yourself for around $30 this is a MAJOR Samsung problem and thousands of people are having this problem. What you need to do is deenergize your tv and lay it face down on a table so you can work on it. Use a philips screwdriver to remove all the screws on the back cover of the tv make sure to remember where they go for when you put it back together. Remove the back cover and follow the two wired from where your tv power cord comes in and in the middle of your tv they will plug into a board, this is your power supply board. Look for blown capacitors, also check the fuses the tops will be bulging upward and caps have writing on them like 10v 1000uf or 2200 uf and 3300uf are the most common. What you will need to do is replace these with a 16v cap but be sure the uf number is the same, and you need 105 degree rated caps. There is also a negative side to the capacitor which is marked with a stripe and a shorter leg on the bottom, these have to go in the same way or you will blow the board, remove the board with screwdriver and disconnect all wires, now you will need your tools solder, soldering iron, and preferably a solder ****** to remove the old bad caps here is a youtube link that shows u step by step just go there and type samsung power supply repair, and whether you have a vizio, philips or another model that this is posted on they all have samsung power supplies in them so if you are having power problems this is your fix, you should be able to get all your parts at radio shack or on the web. Thank you and votes are welcome and if you cant find the parts get to me and I can help you get them
Posted on Jun 02, 2010
SOURCE: Clicking relay no picture no audio no power light red or blue
here is the schematics http://www.scribd.com/doc/33598674/Philips-42mf231d-Chassis-Tpe1-0u-Pa
Posted on Aug 14, 2010
  • 184 Answers
SOURCE: Panasonic viera Plasma TV model TH-P42X10A The tv
The power supply board of the television is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem....
Posted on Aug 01, 2011
Tda9380ps /n3/3/1664 using in sharp tv power supply ok ,but no EHT ,the power LED are glowing red light press program key to change green light to return in few miniutes to standby in red light position...
tda9380ps /n3/3/1664 using in sharp tv power supply ok ,but no EHT ,the power LED are glowing red light press program key to change green light to return in few miniutes to standby in red light
Aug 30, 2011 | Sharp 21" Multi System Stereo TV
Hello. My Panasonic PT-50LC13 is not turn on. First flashing green light for one minute on the power button then starts to blink red and at the same time it starts blinking red LED lights every five...
Check ur tv fan,if ur cooling fan are runnig,before all these LED lights are flashing.If not that ur tv problems.All these LED lights are flashing the tv making alots of clinking noises too like it trying turn itself on?Yes,than the tv board that called the Ballast board it is dead too,must be replace also.This tv Ballast board only job are to help to ignite the tv projection lamp only and keeping it on and running.
Aug 29, 2011 | Panasonic PT-50LC13 50" Rear Projection...
Sony KD-34XBR960....problem is that screen is black; LED light blinks 7 times in a row pauses and then starts blinking again. Have powered off and no improvement.
This tv have two power ICS left side of the FBT-The Flyback Transformer.The big black block of plastic with a red wire with a cap hook to a CRT(tv tube).Replaced those 2 power ICS,tv will solved this LED power light flashing,tv will have stable power again,tv will work.
Oct 23, 2010 | Sony FD Trinitron KD-34XBR960 34" TV
Red light power blinking
power supply problem this can be done by a professional tv repair
Sep 12, 2009 | Panasonic Viera TX-32LX70 32 in. LCD TV
Toshiba 57H81, power to transformer and flyback.
IF YOU REPLACED THE SAME PICO FUSE, YOU PROBABLY HAVE A BAD CONVERGENCE IC AGAIN . DID YOY SNUG UP THE IC TO THE HEAT SINK AND USE THERMAL HEAT COMPOUND ON THE NEW IC'S? ALSO CHECK SOLDER CONNECTIONS TO C810 AND C809 THE FUSE BY THE CAPACITORS MAY BE OPEN.
Jan 22, 2009 | Toshiba 57H81 57" Rear Projection...
DP23 LED not lit on deflection board no picture on tv
Good Day, Gil;
Your problem is in deflection circuit (115+v) check these: FP05, DP15, Q777, QH01, TH01, T701, etc. BUT suspect C707 1k pfd, 2kv, and check all the pico fuses (brown) 2" to the right of cap. Good Luck, big IRISH.
Jul 19, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Progressive power up problem
Yeppers. Sounds like the standby power supply has a bad capacitor in it and the regulator Ic is defective. These parts should only be replaced by quilified technician as there is very high voltage inside these sets. Good Luck
Jun 14, 2006 | JVC AV-K29MX1U 29" TV
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
