Question about Peavey ESCORT 2000 Portable Sound System with Stand
I have a peavey escort 2000 used it regular then i went to turn it on one time and it just wont come on. tried the fuse but after that im stuck. please help
  • 6 Answers
SOURCE: Peavey Escort 2000
You'll need an interface for your computer. An interface takes your microphone or mixer signal and transfers it via usb or firewire to the computer so the software recognizes the signal. There are many available and most come with software.
Try to find an interface that will include full-version software, not a demo. Some interfaces have issues with Vista, just check with your local store of choice to make sure it will work. One of my favorites is the Tapco Link.USB which includes a full-version of software with a pretty simple interface.
Posted on Oct 31, 2008
SOURCE: Peavey Escort system
would you like to sell your system i need parts
wete502764@aol.com
Posted on Feb 11, 2009
  • 10865 Answers
SOURCE: What kind of fuse is needed for the Peavey Escort
Hello. It takes a 5amp fuse, available at any auto parts store. Regards, J.
Posted on Feb 25, 2010
  • 5603 Answers
SOURCE: how hard would it be to change a fader control on
Changing faders USUALLY involves removing all panel hardware so that circuit board can be removed to get at the fader. It is often a LOT of work with a boit of hazards along the way.
If the control is noisy I want you to try something before replacing the fader. Get a can of CRC226 available at Home Depot in the Electrical department... about $2.70 for a can. Using the included plastic spout tube, squirt a bit into the center of the control where the knob is. Work it back and forth and then put a little more in and test if it is better or fixed.
NEVER use DeOxit or Blue Shower in faders!!!!! It removes the lube that is required in the fader.
Posted on Jan 05, 2011
  • 5603 Answers
SOURCE: two time the peavey escort 3000 fault dawn then a
Sounds like an imminent failure ready to happen. If it takes a bit of time before functioning, it may be getting overheated.
This is a small system... don't overdrive it as it is intended for SMALL venues of say 600 square feet.
Posted on Feb 11, 2011
Peavey escort 2000 service manual
1/4 jacks are universal for the most part.
Jan 03, 2013 | Peavey Escort 2000 Microphone
No power
You could remove the cover and find the fuse and replace it with the same voltage and current rating.
Make sure you unplug the device before start working on it.
Jun 08, 2008 | Peavey Escort 2000 Microphone
My peavey escort 2000 system starts up works and runs for about 10 to 15 minutes then shuts down and and green light flashes system restarts then shuts down continuously
If after you shut it down and after a while turn it on again and it works the same way. It sounds like a heat problem. We here at Pro Line Music are a Peavey service center. If you can not get any local help you can send it to us.
servicedepartmentprolinemusic@comcast.net
Jun 17, 2011 | Peavey 00511800 Escort Portable Sound...
The power of the Peavey Escort 3000 Portable PA Sound System went off while in use, and since then power is not showing any more
A failure probably occured in one of the power amps and has blown the fuse or worse. DO NOT replace the fuse and try to operate it as further damage may occur. Take it in for repair.
Feb 15, 2011 | Peavey Escort 3000 300 Watt Portable PA...
What kind of fuse is needed for the Peavey Escort 2000?
Feb 25, 2010 | Peavey Escort 2000 Microphone
My Peavy 2000 Escort does not turn on . I checked power caple,power etc and nothing .. it is a good product and would like to fix it , any help?
We here at Pro Line Music are Peavey dealers, and service. If you can get the unit to us we could fix it.
215-736-8055
Jan 02, 2010 | Peavey Escort 2000 Microphone
Engine will start but wont idle
has it always been on premium? you may have to advance the timing a little to get it running right on premium if it was set for regular before.
Nov 07, 2009 | 1983 Ford Escort Gt
wete502764@aol.com
Aug 24, 2008 | Peavey Escort 2000 Microphone
Repair manual or schematic
nesecito la numeracion de los integrados de potencia para peavey escort 2000
May 21, 2008 | Peavey Escort 2000 Microphone
Peavey ESCORT 2000 Portable Sound System with Stand Logo
47 people viewed this question
Top Peavey Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Michial Gueffroy
Are you a Peavey Audio Player and Recorder Expert? Answer questions, earn points and help others
